How to detect finalgrom99 using assembly language ?
fg99
2 replies to this topic
#1 retroclouds OFFLINE
retroclouds
  • 1,621 posts
Posted Tue Dec 26, 2017 8:40 AM
Hoping that Ralph can chime in on this.
My question is, if it's possible to detect if there is a finalgrom99 installed ?
That would be intereresting if you'd like to use the more advanced features like writing to RAM/GRAM.
#2 ralphb OFFLINE
ralphb
    Dragonstomper
  • 569 posts
Posted Fri Jan 5, 2018 6:52 AM
Sorry for not seeing this question earlier ...
Just enable RAM or GRAM (by putting R or G into the fourth byte) and see if you can write to the cart space.  If you're not running on the FinalGROM 99, the RAM/GRAM information will be ignored, so you cannot modify values in cart space.
#3 retroclouds OFFLINE
retroclouds
  • 1,621 posts
Posted Fri Jan 5, 2018 9:52 AM
Thanks. That sounds like a good idea. Should be easy to implement :-)
Also tagged with one or more of these keywords: fg99
