Altirra 3.00 released
altirra emulation
585 replies to this topic
#551 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Mon Jul 16, 2018 9:41 PM
Regular execution history is limited to 128K instructions. The performance analyzer tracer can buffer more and will allow searching within a window of 400K instructions within the trace.
Another option is the heat map (hme, etc.). It tracks read and write accesses to addresses and can tell you the 'source' of the current value stored at an address.
Using "r; g" as the condition can cause stepping to run away due to resuming execution when the breakpoint hits. Using the -n option to the bx command with just "r" as the breakpoint action is better as that sets a non-stopping breakpoint. Current test versions also have bta command that makes this easier; it is the memory access version of the tracepoint (bt) command.
#552 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Tue Jul 17, 2018 9:30 PM
http://www.virtualdu...3.10-test34.zip
http://www.virtualdu...-test34-src.zip
  • Fixed a regression that caused a hang when resetting input maps to default.
  • Fixed a bug in Fast Boot that sometimes caused a few bytes in memory to not be cleared, breaking a couple of programs.
#553 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,921 posts
Posted Thu Jul 19, 2018 3:22 AM
i need to ship a standalone Altirra with my next release.
Where can I see the ".ini" file?
In a perfect world I would like to configure to the desired settings, copy/paste Altirra and .ini file and bundle it with my demo. Jac did it with his SillyPack. Or do I have to manually edit that ini file?
another option would be save state file? but a file with ini-segments ($2e2) does not stop altirra (break at run adress) as its not $2e0...
ideas/help?
#554 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Thu Jul 19, 2018 3:51 AM
The easiest way would be to make a folder with ALtirra and its needed  OS roms (unless its works ok under Avery's internal bios) in the main dir, then run it with a /portable command line..(If you don't use the command line initially it will use the registry settings it has stored (if any))
Then setup the release as you want it and altirra to do out with all the settings done, close altirra and there it is..A stand alone version of Altirra with its own special ini for your release..
And that way your own Altirra if its using the registry is untouched..
Paul..
(Sorry about the hand held look of the post Heaven, its just incase anyone else wants to have an Altirra with an ini file to do something special away from their own Altirra settings)
Methinks you are able to use basic and the like ;)
Lol...Sorry...Looking forward to the new release...
Edited by Mclaneinc, Thu Jul 19, 2018 3:55 AM.
#555 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,921 posts
Posted Thu Jul 19, 2018 3:57 AM
Thx Paul, sounds good. will try later today. just want to make sure that it works "out of the box" for ppl without any Altirra knowledge. So your way could be perfect. I let you know.
#556 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Thu Jul 19, 2018 4:01 AM
Should be fine, If it needs IDE stuff etc just stuff the roms in with altirra and do a firmware scan  before you shut it down so they are known to the setup, as long as its all self contained in that folder it should be fully transportable..
Have fun
Paul..
#557 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,921 posts
Posted Thu Jul 19, 2018 5:13 AM
works flawless... thx.
#558 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Thu Jul 19, 2018 5:48 AM
Glad to help...
#559 R0ger OFFLINE
R0ger
    Moonsweeper
  • 267 posts
Posted Thu Jul 19, 2018 6:11 AM
What !? You can do THAT ? I've been pulling my hairs over settings in registry for years ! :D
#560 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Thu Jul 19, 2018 3:54 PM
Sorry ROger, you only had to ask :)
#561 rdea6 OFFLINE
rdea6
  • 2,741 posts
Posted Wed Jul 25, 2018 5:46 PM
Attached File  AltirraCrash.zip   20.37KB   15 downloads
I am trying to mount folders as virtual SpartaDos Disk.
#562 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Wed Jul 25, 2018 10:03 PM
Fixed:
http://www.virtualdu...3.10-test35.zip
http://www.virtualdu...-test35-src.zip
#563 mr_gw454 OFFLINE
mr_gw454
    Space Invader
  • 48 posts
Posted Fri Jul 27, 2018 4:25 PM
Phaeron -- thanks for all the updates.  This is a fantastic emulator!  A bonus is that it runs extremely well in wine 3.x in Linux.
#564 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Sun Aug 5, 2018 4:50 PM
Release candidate:
http://www.virtualdu...3.10-test36.zip
http://www.virtualdu...-test36-src.zip
  • Fixed a few regressions in disk drive debugging: issues with intermittent stepping and not being able to set PC, and 8048 R0/R1 registers being reported incorrectly in history.
#565 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Mon Aug 6, 2018 4:09 AM
Another milestone in completeness...
2600 emulation?
Lol...Just joking, I know that's a whole different ball game...
Regarding Altirra, to quote Paulie from Rocky III (1982 Sylvester Stallone film) when looking at the newly put up Rocky statue by the city, he looks at it and says "Its a thing of beauty"....That's Altirra :)
Edited by Mclaneinc, Mon Aug 6, 2018 4:10 AM.
#566 massiverobot OFFLINE
massiverobot
    Star Raider
  • 84 posts
Posted Mon Aug 6, 2018 7:10 AM
I downloaded and ran Altirra yesterday for the first time... I use OSX and have run atari800 for years. Yes, I'm used to no sound, I don't run it for everything.
But I did shed a small tear- Altirra is so nice and has so many features. I cried because there isn't something like this for OSX (yet..?)
It would be nice to have a master config file generated that could be edited (to cut down on too much UI clicking to setup a working profile) but the features and the setup.... nice job.
Thanks for building this amazing software.
The first time I had it booting with the U1M BIOS after just 5min of fiddling I was speechless!
#567 DrVenkman OFFLINE
DrVenkman
  • 3,491 posts
  • Back off, man! I'm a scientist.
Posted Mon Aug 6, 2018 7:58 AM
2600 emulation?
Stella is already pretty damn good. Check out the current v5 releases. :)
#568 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Mon Aug 6, 2018 8:55 AM
If you run it via command line with a /portable switch at the end you will get the cfg / ini file you want, it will then use that until you delete it and then it will go back to using the registry..
#569 fujidude OFFLINE
fujidude
  • 5,028 posts
Posted Sat Sep 29, 2018 1:18 PM
Yep there is that and it's great.  But also within a "single" Altirra configuration you can have endless setups and easily choose between them from within Altirra itself too.
#570 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,921 posts
Posted Tue Oct 2, 2018 1:47 PM
To Avery: thanks to my Turbo Freezer debugger I might found another VBXE emu bug.
In XDL Altirra interprets x3 as wide screen while real hw switched back to narrow wide.
Real hw
0 narrow
1 normal
2 wide
And 3 is narrow again while 3 Altirra remains in wide.
Core 1.26. Havent checked core 1.24.
#571 Mclaneinc OFFLINE
Mclaneinc
  • 5,926 posts
Posted Tue Oct 2, 2018 3:13 PM
Indeed, that was just for someone doing stuff by command line only to be easy.....The profile system on Altirra is great, could do with a spruce up which have been mentioned in the past (so no repeat requests)...
Paul.
#572 _The Doctor__ OFFLINE
_The Doctor__
  • 5,205 posts
Posted Tue Oct 2, 2018 3:53 PM
I always think warp and OS 'X' as something other than apple os ten (X)
No tears, I eat apples... :)
#573 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Tue Oct 2, 2018 9:47 PM
Real hw
0 narrow
1 normal
2 wide
Yes, confirmed from the VHDL, I'll fix it for 3.20.
#574 pajero_pn OFFLINE
pajero_pn
    Star Raider
  • 75 posts
Posted Sun Oct 7, 2018 9:13 AM
Altirra Command-Line
Usage: Altirra [switches] <disk/cassette/cartridge images...>
Please add a switch to indicate to the debugger the source code:
/source <txt.asm>
#575 phaeron OFFLINE
phaeron
  • 2,583 posts
Posted Sun Oct 7, 2018 11:47 AM
/source <txt.asm>
I'm not sure what this would do...? The debugger has source code support so it can map between addresses and source code lines. If it doesn't already know the source file, it won't know any line mappings either and this switch won't fix that.
Also tagged with one or more of these keywords: altirra, emulation
2 user(s) are browsing this forum
2 members, 0 guests, 0 anonymous users
