Thanks Thomas. I followed the link, but understood almost none of it even with the DASM manual by my side. I'm sure it would have to be heavily commented for me to follow it better.
Posted Thu Dec 20, 2018 5:44 PM
So of those EF could be made to work with my example. As Thomas mentions, if you do it this way the overhead increases (as more of each 4K bank is dedicated to bank switching code) so finding a better way to do it would be in your best interesting.
One side affect of my switching to ARM support for my games is they only use 1 bank of 6507 code, and the ARM sees everything without needing to bankswitch, so I've not looked into better ways to do it.
Thinking about this some more, I thought of a way to greatly reduce the overhead. I'm curious to know if this will work. If I were to expand to 16 banks of 4K, 12 of these banks would be kernels and therefore, would always return to "Overscan" in the jump table. Couldn't I move "Overscan to the top of JUMP_TABLE, then delete the remainder the jump table that follows "Overscan" in those 12 banks? Further, couldn't I get rid of all but the last SelectBank in BANKS_AND_VECTORS in those 12 banks, always jumping to the last bank? (Which doesn't get me to "Overscan" right now but I suppose I could move Overscan to the last bank.) These changes would probably also apply to the voice banks as well, leaving only one bank requiring the full JUMP_TABLE and BANKS_AND_VECTORS macros. Does that work?
MAC JUMP_TABLE ; start of every bank RORG $F000 SystemStart ; inititialize system nop SelectBank1 jmp SystemStartCode MCP ; game logic nop SelectBank1 jmp MCPCode Overscan nop SelectBank1 jmp OverscanCode IntroKernels ; kernels nop SelectBank2 jmp IntroKernelsCode Kernels3 ; kernels nop SelectBank3 jmp Kernels3Code Kernels4 ; kernels nop SelectBank4 jmp Kernels4Code Voice1 ; voice bank 1 nop SelectBank5 jmp Voice1Code Voice2 ; voice bank 2 nop SelectBank6 jmp Voice2Code Voice3 ; voice bank 3 nop SelectBank7 jmp Voice3Code Voice4 ; voice bank 4 nop SelectBank8 jmp Voice4Code ENDM MAC BANKS_AND_VECTORS ; end of every bank RORG $FFF4 SelectBank1 .byte $00 SelectBank2 .byte $00 SelectBank3 .byte $00 SelectBank4 .byte $00 SelectBank5 .byte $00 SelectBank6 .byte $00 SelectBank7 .byte $00 SelectBank8 .byte $00
Posted Thu Dec 20, 2018 6:29 PM
MAC JUMP_TABLE_OS_V ; start of Overscan and Voice banks RORG $F000 SystemStart ; inititialize system nop SelectBank1 jmp SystemStartCode VerticalBlank ; game logic (Vertical Blank) nop SelectBank5 jmp VBCode Overscan nop SelectBank1 jmp OverscanCode Voice1 ; voice bank 1 nop SelectBank2 jmp Voice1Code Voice2 ; voice bank 2 nop SelectBank3 jmp Voice2Code Voice3 ; voice bank 3 nop SelectBank4 jmp Voice3Code ENDM MAC JUMP_TABLE_VB_K ; start of Vertical Blank and Kernel banks RORG $F000 SystemStart ; inititialize system nop SelectBank1 jmp SystemStartCode VerticalBlank ; game logic (Vertical Blank) nop SelectBank5 jmp VBCode Overscan nop SelectBank1 jmp OverscanCode IntroKernels ; kernels nop SelectBank6 jmp IntroKernelsCode Kernels3 ; kernels nop SelectBank7 jmp Kernels3Code Kernels4 ; kernels nop SelectBank8 jmp Kernels4Code ENDM
Posted Fri Dec 21, 2018 8:25 AM
Hmm.. That would certainly help. Thanks!
I went on a nice long run and thought this over again and partially reversed my conclusion. It seems to me that BANKS_AND_VECTORS is unchangeable- so I get that. But, with JUMP_TABLE for example, if Bank 3 didn't use the JUMP_TABLE macro, and only had:
and I left the rest of the banks off, then you could always jump to it. And if that bank only needed to jump to bank one, its covered there too- right?
Additionally, if I had 16 banks, then bank 16, for example, could have something like
ORG $F000 ;????? SUBROUTINE: ; insert any subroutine here rts ; ORG $F0?? ; Wherever the macro has it Bank16 nop SelectBank16 jmp SelectBank16Code ; a larger subroutine could jump to here then rts
I'm still a little weak on ORGs and RORGs nor do I know exactly what address Bank 16 is in the macro.
Does this work?
