Sophia rev.C - DVI board
168 replies to this topic
#151 _The Doctor__ OFFLINE
_The Doctor__
  • 5,194 posts
Posted Sun Aug 19, 2018 9:44 AM
what? I though he provided a path for artifacting....or did I just jumble up projects in my head again?
#152 Faicuai OFFLINE
Faicuai
    Dragonstomper
  • 843 posts
Posted Sun Aug 19, 2018 1:58 PM
Image ovality and differences resulting from the properties of NTSC and PAL systems are a disadvantage, not a desirable feature. Tolerated because it is indelible. So far.
From an pure / absolute point of view, yes, you are correct.
But considering the historical value / weight of our experience, the name of the game here is FIDELITY. Or, in other words, an as FAITHFUL reproduction of our user experience as materially / technically possible.
Most past software titles (which make up the vast majority of Atari's SW library) were coded with these machines visual properties' in mind. Therefore, if we are not able to recreate such visual properties, we can hardly re-create the original experience itself. This is a problem within NTSC itself, as color-decoding for this standard actually changed, and so the actual color palette extracted from the Atari (very hard to reproduce accurately, indeed).
For instance, some software like Flags of Europe and Summer Games, somehow thought that that it was a good idea to source red color for the flags from the LAST vertical row of the color palette, specifically patches #1 or #2 from left to right (instead of true red-primaries located way above and closer to the first rows). But, as it turns out,  that last row is VERY, VERY hard to decode accurately with modern NTSC electronics (as it used to look on early days), no matter how much you (mindfully) fiddle the color pot AND the color phase (hue) adjustments.
The bottom-line is NTSC is not and will not be a 1:1 output aspect ratio. It is shrunk horizontally by a factor of (pretty close) 11/12.
In any case, if the machine still outputs its native COMPOSITE and Y/C output while Sophia is working (and all outputs are routed through a decent, powerful video processor), this discussion has no real impact or relevance, anyway.
Edited by Faicuai, Sun Aug 19, 2018 2:04 PM.
#153 Frankie OFFLINE
Frankie
    Moonsweeper
  • 471 posts
Posted Sun Aug 19, 2018 4:55 PM
I guess you could always install a UAV along with it, then you get all three output with excellent quality,
#154 MagicMarc-er ONLINE
MagicMarc-er
    Space Invader
  • 18 posts
Posted Thu Aug 23, 2018 1:45 PM
Does anyone know what type of connectors are used on the ends of the ribbon cable that is supplied with the Sophia board?  I have been trying to find a longer version of the same thing because, depending on where you mount Sophia inside a 1200XL, the ribbon cable could stand to be a few inches longer.  I've been searching around on ebay but can't seem to find that type of connector.
#155 jc13 OFFLINE
jc13
    Star Raider
  • 66 posts
Posted Thu Aug 23, 2018 2:29 PM
Attached image is what I ordered from DigiKey...  If just making a new cable, you won't need the 2nd one.
#156 MagicMarc-er ONLINE
MagicMarc-er
    Space Invader
  • 18 posts
Posted Thu Aug 23, 2018 2:52 PM
Thanks!  I also found part number A128014-ND, which is a 250mm (approx 10") cable with the appropriate connectors.  I think the ribbon cable that is provided is 200mm (8") so this might be 2" longer.  If I go with the A99461CT-ND connector that you showed, is there a specific type of ribbon cable that needs to be used or will any 10 position cable work?
#157 jc13 OFFLINE
jc13
    Star Raider
  • 66 posts
Posted Thu Aug 23, 2018 3:23 PM
I just used an old IDE drive cable and split off 10 conductors.  Not sure if you have a way to crimp the connectors (I used a bench vise with some wood spacers to keep from destroying the connector), but if that's a concern I'd get the cable assembly for sure assuming it's long enough.
Edited by jc13, Thu Aug 23, 2018 3:27 PM.
#158 adamchevy OFFLINE
adamchevy
  • 1,494 posts
Posted Mon Aug 27, 2018 9:48 AM
I am very impressed with this mod and I look forward to placing an order for my 5200. My 5200 was already previously Svideo modded by electronic Sentimentalities. I know the Svideo mod requires soldering onto the GTIA. Has anyone tried installing the DVI mod inside a previously modded 5200? I think it would work fine just putting the soldered GTIA in to the Sophia. I am curious if anyone has tried this yet. It might even clear up the Svideo signal?
Edited by adamchevy, Mon Aug 27, 2018 9:48 AM.
#159 mytek OFFLINE
mytek
  • 3,017 posts
Posted Mon Aug 27, 2018 11:35 AM
Should work. I use this board on a UAV modded system without any issues. Sophia is designed to work in harmony with the GTIA chip, so any 'standard' video enhancement should work the same as always.
#160 adamchevy OFFLINE
adamchevy
  • 1,494 posts
Posted Mon Aug 27, 2018 4:11 PM
#161 MagicMarc-er ONLINE
MagicMarc-er
    Space Invader
  • 18 posts
Posted Tue Sep 11, 2018 10:25 AM
I've made some great progress and will post some pictures of my mod soon.  Sofia works great and picture is incredible.  I have only one remaining issue and that is sound.  To the monitor port, I connected a Din 5 Pin To 3.5mm Male Stereo Jack Audio Adapter Cable.  This I used to connect to some standard powered computer speakers and also to a pair of headphones.  I can hear the sound but, even at maximum volume, it is very quiet.  When I connected to a standard tv using the RF connector, the volume was fine.  What am I doing wrong?
#162 kheller2 OFFLINE
kheller2
  • 1,255 posts
Posted Tue Sep 11, 2018 5:58 PM
Was that a custom built cable? Didn’t think such a cable existed.
#163 MagicMarc-er ONLINE
MagicMarc-er
    Space Invader
  • 18 posts
Posted Tue Sep 11, 2018 6:42 PM
Yes. I found it on ebay for about $6.50 (U.S.).
Sent from my Pixel 2 XL using Tapatalk
#164 adamchevy OFFLINE
adamchevy
  • 1,494 posts
Posted Fri Sep 14, 2018 2:17 PM
Does anyone know if the Sophia supports 144hz monitors? I’ve been looking into getting one because it looks like they would be better for most of the arcade style games I love on the 5200. Also, does it support DVI-D(dual link)?
#165 killersquirel OFFLINE
killersquirel
    Dragonstomper
  • 719 posts
Posted Fri Sep 14, 2018 5:57 PM
How much are the Sophia DVIs going for? Are they still available?
#166 Simius OFFLINE
Simius
    Dragonstomper
  • 512 posts
Posted Fri Sep 14, 2018 10:53 PM
Sophia board required 50Hz (PAL) or 60Hz (NTSC) v-sync range monitor with DVI-D single link.
#167 Simius OFFLINE
Simius
    Dragonstomper
  • 512 posts
Posted Fri Sep 14, 2018 10:59 PM
Yeah, Sophias are still available. Ordering info on PM
#168 slx OFFLINE
slx
  • 1,512 posts
Posted Sat Sep 15, 2018 10:55 PM
Does anyone know if the Sophia supports 144hz monitors? Ive been looking into getting one because it looks like they would be better for most of the arcade style games I love on the 5200. Also, does it support DVI-D(dual link)?
Why would you need that? Your Atari cant produce more than 60hz anyway, nor will it use a resolution that would require dual link to send to the monitor. If your monitor supports 144kHz it will happily accept the Ataris 60.
#169 adamchevy OFFLINE
adamchevy
  • 1,494 posts
Posted Tue Sep 18, 2018 6:51 PM
Finally had some time to give this a try. Wow! It looks great! Thanks so much for making this!1f3efdcabb8ec5cbadeecf8b057e284e.jpg
This is at 1600x900 at 60hz
This is on a Dell U3011t Monitor.
Edited by adamchevy, Tue Sep 18, 2018 6:52 PM.
