Editor Assembler Sound examples question
TheBF
Has anyone ever coded the example sound programs that begin on page 321?
I ran the CHIME sound list with my Forth language player and the data is fine.
Then realized it was not hard to make a sound list in VDP RAM and write to the PAD memory addresses in the examples.
I run my system with interrupts running most of the time, so I expected something to happen however nothing happened.
Things that make you say hmmm...
BF
As I mentioned, the sound tables work fine. I can play them with direct 9919 control.
I was curious what it takes to run them under ISR control. It looks simple in assembler.
I am trying it in Forth with no luck.
Here is the code:
\ ISR Sound player for Camel99 Forth   Jan 10, 2019 BJF
\ VDP RAM manager
VARIABLE VP    \ VDP memory pointer (4K block)
HEX 1000 VP !   \ start of free VDP RAM
: VHERE   ( -- addr) VP @ ;   \ FETCH the value in VDP pointer
: VALLOT ( n -- )    VP +! ;  \ add n to the value in VDP pointer
\ Compile a byte in the next available VDP memory location
: VC,    ( n -- )  VHERE VC!  1 VALLOT ;
: VCREATE  ( -- <text>)
            CREATE VHERE ,   \ compile VDP address in CPU RAM
            DOES> @  ;       \ run time: fetch the VDP address
\ setup ISR sound
: ISRPLAY ( vaddr -- )
            LIMI0                     \ interrupts off
            83CC !                    \ load sound table address
            01 83CE C!                \ trigger sound processing
            83FD C@  01 OR 83FD C!    \ set VDP flag
            LIMI2 ;                   \ interrupts on
\ VDP BYTE directive: read bytes and compile into VDP RAM
: VBYTE ( -- )  \ read input stream of bytes and compile to VDP mem.
         BEGIN
           [CHAR] , PARSE-NAME  DUP  ( -- adr len len )
         WHILE
            EVALUATE  DUP FF00 AND ABORT" Not a byte"
            VC,
         REPEAT
         2DROP ;
: /END   ( -- )  0 VC,  ;              \ compile a zero BYTE into VDP RAM
VCREATE PACMAN
       VBYTE 6,86,0D,97,AC,1A,B7,8
       VBYTE 2,8F,08,2
       VBYTE 2,AB,23,5
       VBYTE 2,86,0D,4
       VBYTE 1,BF,3
       VBYTE 2,8E,0B,8
       VBYTE 2,8A,0A,2
       VBYTE 3,AC,1A,B7,8
/END
BF
I have run it from Assembly, GPL and RXB even has a demo using the same code.
Yup. I am sure it works. I just can't understand why, when I do the equivalent things with Forth that I see in Assembler in the book, it doesn't play the list. I even made some little routines in the kernel to start and stop interrupts like in the assembler code.
I will have to study Lee's code more closely.
It's funny cuz I made the TMS9919 direct sound driver very quickly. :-)
I notice that the assembler code is in a loop. Perhaps I am only running the first string of bytes?
I am not sure studying my code will help because it is talking directly to the sound chip just as your code does. The ISR I wrote to do that does not involve the console ISR’s sound routine at all. I will post the console ISR’s sound routine in a bit.
...lee
Here is the Assembler listing of the console ROM code: attachicon.gifROM-4A.lst
The ISR begins at “REMOTE” at line #1580 and the sound servicing section begins at “TSTSND” at line #1710.
...lee
Thanks Lee. This is wonderful to have.
Yes I noticed that your code talks to the chip and uses some of the same code as Turbo Forth too.
I am swimming upstream here maybe but it's fun to try and craft these things in Forth to see what can be done.
Thanks again for the listing. Will post what I find.
B
