Colecovision won't power on - help?
9 replies to this topic
#1 reverendshoebox OFFLINE
reverendshoebox
    Star Raider
  • 85 posts
Posted Sun Jan 14, 2018 4:38 PM
Hey all.
I have a Colecovision that won't power on.  No black screen, no BIOS screen, nada.
I've verified via multimeter that the power supply seems to have 12, 5, and -5 volts where it should, including where it connects to the board, but when I switch the power on, the 5 volt reading jumps down to 1.6.
Is this an expected drop, or an indication that I've got a bad power supply?
If the former, where should I look next?
Thanks much,
-=ShoEboX=-
#2 SignGuy81 OFFLINE
SignGuy81
  • 1,685 posts
Posted Sun Jan 14, 2018 4:41 PM
That isn't an expected drop and more than likely indicates a bad component pulling the power supply down.
#3 reverendshoebox OFFLINE
reverendshoebox
    Star Raider
  • 85 posts
Posted Sun Jan 14, 2018 7:04 PM
Thanks for the response.  Do you mean a bad component in the power supply or in the Colecovision itself?  And if it's in the Colecovision, how do I go about diagnosing the issue further?
-=ShoEboX=-
#4 SignGuy81 OFFLINE
SignGuy81
  • 1,685 posts
Posted Thu Jan 25, 2018 7:23 PM
I believe you have a shorted component inside the Colecovision itself.  Is any part inside the Colecovision feel hot?  See if any of the chips feel hot.
#5 grips03 OFFLINE
grips03
  • 3,788 posts
Posted Thu Jan 25, 2018 8:22 PM
Measure +5v to ground on top of all the ICs, ohm leads right on top of the IC legs.  Write down the resistance going as many places as the ohm meter supports.
Example 50.001 and 50.009 ohms.
Does the hot to the touch IC also show the least amount of the resistance?
If yes, perhaps that is the bad IC.  Clip the ground leg of that IC, does the resistance change between ground and +5v?
If resistance does not change, then resolder that ground you just cut and keep trying.
#6 reverendshoebox OFFLINE
reverendshoebox
    Star Raider
  • 85 posts
Posted Fri Feb 23, 2018 10:30 PM
Hey all.  I ended up trying another AC adapter and I'm up and running.  Thanks for the advice, greatly appreciate it!!
#7 paulderr OFFLINE
paulderr
    Combat Commando
  • 1 posts
Posted Fri Dec 28, 2018 2:02 PM
Wait! You said the power supply was putting out the correct voltages. How did just changing to a new power supply fix the issue if the one you were using to begin with was working? I am having the same issue but only have one power supply. I have two Colecovisions and neither power up at all. I test the power supply and the voltages are correct but get nothing from the Colecos.
#8 ChildOfCv ONLINE
ChildOfCv
    Star Raider
  • 94 posts
Posted Fri Dec 28, 2018 2:21 PM
If the power supply has a bad regulator, it can still read correct voltage with no load, but fail under load.
As someone mentioned though, the board will have a characteristic DC resistance to ground on the +5V rail.  On mine (rev J) it will be about 72 ohms.  Any less than that, and you might have a component drawing too much power, which can also lead to power supply failure.
#9 alortegac OFFLINE
alortegac
    Chopper Commander
  • 177 posts
Posted Sat Jan 5, 2019 8:26 PM
Hi, would please explain the process of doing this measurement? I just want to be completely sure I will do it correctly when needed. I have come accross a couple of CV consoles that appear to draw too much power. I thought it was a component is short or failing but I did not know how to best identify it. Thanks a lot! Al
#10 ChildOfCv ONLINE
ChildOfCv
    Star Raider
  • 94 posts
Posted Sat Jan 5, 2019 8:51 PM
The easy way is to unplug the CV, turn it on, open the expansion port, and check the resistance between the two large contacts on the left side (one on top, one on bottom).  On my board that reads about 75 ohms.
