data statement?
12 replies to this topic
#1 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,073 posts
Posted Sun Jan 14, 2018 9:26 PM
Can anyone see what I'm doing wrong here? I'd like to use data to build some graphics, this is a simplified excerpt from my program... if I hardcode pixels 20,21,22 in row 5 it's fine, but when I try to use simple data/offsets on line 7 or slightly more complex usage for line 9, I get odd, flickering results
  dim ptr = a
mainloop
  COLUBK=$00
  COLUPF=$08
  pfpixel 20 5 on
  pfpixel 21 5 on
  pfpixel 22 5 on
  pfpixel golemShape[0] 7 on
  pfpixel golemShape[1] 7 on
  pfpixel golemShape[2] 7 on
  ptr = 0
  pfpixel golemShape[ptr] 9 on
  ptr = ptr + 1
  ptr = ptr + 1
  drawscreen
  goto mainloop
  data golemShape
  20, 21, 22
end
#2 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 691 posts
Posted Mon Jan 15, 2018 5:01 AM
Sorry I'm stumped on this as well. It just does not like data statements.
#3 bogax OFFLINE
bogax
    Dragonstomper
  • 791 posts
Posted Mon Jan 15, 2018 5:07 AM
try something like this
  temp1 = golemShape[0]
  pfpixel temp1 7 on
#4 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 691 posts
Posted Mon Jan 15, 2018 6:20 AM
It kind of worked. The flicker is gone.  But it still doesn't look right.
dim ptr = a
mainloop
 temp1=golemShape[ptr]
 temp2=golemShape[0]
 temp3=golemShape[1]
 temp4=golemShape[2]
  COLUBK=$00
  COLUPF=$08
  pfpixel 20 5 on
  pfpixel 21 5 on
  pfpixel 22 5 on
  pfpixel temp2 7 on
  pfpixel temp3 7 on
  pfpixel temp4 7 on
  ptr = 0
  pfpixel temp1 9 on
  ptr = ptr + 1
  pfpixel temp1 9 on
  ptr = ptr + 1
  pfpixel temp1 9 on
  drawscreen
  goto mainloop
  data golemShape
  20, 21, 22
end
#5 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,073 posts
Posted Mon Jan 15, 2018 6:42 AM
bogax has the right idea, I think.
somehing like this seems to work
 dim ptr = a
 dim reader = b
 rem ................
 ptr = 0
 reader = golemShape[ptr]
 pfpixel reader 9 on
 ptr = ptr + 1
 pfpixel reader 9 on
 ptr = ptr + 1
 pfpixel reader 9 on
I think the general principle is "don't assume you can put in a 'array like data read' anywhere you can use a normal variable". This sort of makes sense to me based on what I remember of addressing modes etc in straight assembly
@RandomTerrain I wonder if the command list #dataarrays section should say something like
Please note that you will often need to use a temporary variable to hold the value being read via the array-like syntax, for example
_temp = _My_Data[3]
and then use the _temp variable in the actual command. (Many commands support use of simple variables inline, but not more complex looks up like this.)
#6 bogax OFFLINE
bogax
    Dragonstomper
  • 791 posts
Posted Mon Jan 15, 2018 7:45 PM
dim ptr = a
mainloop
 temp2=golemShape[0]
 temp3=golemShape[1]
 temp4=golemShape[2]
  COLUBK=$00
  COLUPF=$08
  pfpixel 20 5 on
  pfpixel 21 5 on
  pfpixel 22 5 on
  pfpixel temp2 7 on
  pfpixel temp3 7 on
  pfpixel temp4 7 on
  ptr = 0
  pfpixel temp1 9 on
  ptr = ptr + 1
  pfpixel temp1 9 on
  ptr = ptr + 1
  pfpixel temp1 9 on
  drawscreen
  goto mainloop
  data golemShape
  20, 21, 22
end
pfpixel uses temp1 and temp2
#7 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,073 posts
Posted Tue Jan 16, 2018 8:35 AM
Sorry, what?
#8 Mr SQL OFFLINE
Mr SQL
  • 2,090 posts
Posted Tue Jan 16, 2018 10:29 AM
The pfpixel command uses the temp variables for calculations so their initial values are lost.
#9 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,073 posts
Posted Tue Jan 16, 2018 10:57 AM
does that apply to my first example? is there some memory bleed in that?
#10 Mr SQL OFFLINE
Mr SQL
  • 2,090 posts
Posted Tue Jan 16, 2018 12:50 PM
From Mountain Kings example, " pfpixel temp2 7 on"
On the first example I think you are right about not always being able to pass array variables in place of regular variables in Batari BASIC.
Flashback and SuperCharger BASIC support passing array members, here is a simple example in old-school mode:
10 data myarray 9,4
20 vwpixel(myarray(0),myarray(1),on)
#11 mojofltr OFFLINE
mojofltr
  • 2,632 posts
Posted Wed Jan 17, 2018 8:03 AM
It's early, so I may be completely missing the point.  I played with your .bas file and found that I was able to draw a shape with data and a data statement.  The playfield and background colors were hosed if the for loop ran every frame.
So I labeled a bit to limit the for loop.  This fixed the colors, so I went ahead and added some player control to set some offset values to move the shape around the screen.
I don't know if this will at all be helpful.  If not, please disregard.
/edit
I noticed the for loop has a duplicated line... duh.  It was meant to be:
 for i=0 to 35
 temp3=xData[i]+xOffset : temp4=yData[i]+yOffset
 pfpixel temp3 temp4 on
 next
Even so, it seems that each time the for loop is called, the fps gets messed up slightly.
Edited by mojofltr, Thu Jan 18, 2018 7:56 AM.
#12 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 28,952 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sat Jan 20, 2018 4:49 PM
_temp = _My_Data[3]
I've been away from my computer for a while, so I'm just now getting to this. I stupidly played with your program without scrolling down first and reinvented the wheel:
Attached File  dataweird_2018y_01m_20d_1723t.bas   621bytes   31 downloads
Attached File  dataweird_2018y_01m_20d_1723t.bin   4KB   31 downloads
I basically did the same thing you guys did, except I used temp5. It would be nice if any commands that use temp variables had them listed next to them on the bB page so we would know how far down the list (6, 5, 4, 3, 2, 1) we can go with our own use of temp variables when using a certain command. If we're using a command that uses temp1 and temp2, we'd know it's safe to use temp6, temp5, temp4, and temp3, then use them the way you mentioned above.
#13 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Mon Feb 12, 2018 8:39 PM
I did this in the documentation for the standard libraries in C02 (http://atariage.com/...4-c02-compiler/).
It may not be too hard to figure this out for batari Basic.
