running out of time or what?
4 replies to this topic
#1 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,058 posts
Posted Mon Jan 15, 2018 9:36 AM
So, here's a stripped down version of my golem moving - the most relevant bit is this loop, which I do to erase all the old squares of it and then again to put them in the new place
cursorX = golemX
cursorY = golemY
for counter = 0 to GOLEM_END
  cursorX = golemShapeX[counter]
  cursorX = golemX + cursorX
  cursorY = golemShapeY[counter]
  cursorY = golemY + cursorY
  pfpixel cursorX cursorY on
next counter
GOLEM_END is 21 (because golemShape data goes up to 22)
If i set GOLEM_END to like 10, things are fine.
Am I running into a simple out of time problem, so dropping a frame?
Trying to confirm that is the problem, and ways around it:
* maybe sread() is more efficient?
* maybe drawing pixels "hardcoded" (though each would be an offset from golemX and golemY) and/or doing pfvlines would be faster?
* in theory i could just used fixed playfields for a set number of positions of the golem, and do a full screen clear
Of course there's always
* just accept the screenflick and say the earth shakes as the golem walks :-D
I don't know if a hardcoded set of draw instructions (maybe even pfvline ) would be more efficient, or if I should draw it once
Edited by kisrael, Mon Jan 15, 2018 9:43 AM.
#2 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,058 posts
Posted Mon Jan 15, 2018 11:41 AM
Quick answer: unrolling the loop, so to speak, and setting the pfpixels I want "by hand" seems to work better
#3 bogax OFFLINE
bogax
    Dragonstomper
  • 738 posts
Posted Mon Jan 15, 2018 8:15 PM
sped it up a little, but not enough
#4 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,058 posts
Posted Tue Jan 16, 2018 8:33 AM
Thanks for looking!
Made a lot of progress yesterday, with the "unpacked to a lot of inc/dec" version. Still getting the odd blank frame, and still a bit more code to write, but we'll see
#5 bogax OFFLINE
bogax
    Dragonstomper
  • 738 posts
Posted Tue Jan 16, 2018 5:57 PM
If you can clear the whole screen instead of just the Golem
