Jakks plug and play ms pac man
20 replies to this topic
#1 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Mon Jan 15, 2018 2:24 PM
I have a version that has the fake "metal" look on top....I see multiple styles on the internet...is this version unique in any way?Thanks!
#2 chas10e OFFLINE
chas10e
    Dragonstomper
  • 780 posts
Posted Mon Jan 15, 2018 8:49 PM
is it this one ?
namco-ms-pac-man-plug-and-play-5-in-1-tv
#3 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Tue Jan 16, 2018 9:40 AM
is it this one ?
that's it......also do you have any repair advice?It powers on,has audio,the games come on but are scrambled/filcker,thanks!
#4 chas10e OFFLINE
chas10e
    Dragonstomper
  • 780 posts
Posted Tue Jan 16, 2018 3:10 PM
the one I have has is solid blue on top . IMO probably the most solid built PNP of them all
fresh batteries, clean battery terminals if a previous set of batteries corroded (white vinegar / baking soda / q-tips)
if above ok, try bending the cable up or down where it enters the unit, it may reveal conductor broke inside cable
also do you have component connection on TV? (yellow) or is it R-B-G ?
I hadn't disassembled this particular unit before.
I hope others can chime in with any more advice
#5 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Tue Jan 16, 2018 4:54 PM
Thanks for these tips...will try new batteries when I get home and hopefully that does the trick!Although if a fail at least I donated $4 to Goodwill and will have a nice display piece....has the yellow/white connections.Prior batteries didn't look to be corroded hopefully just on the way out
#6 chas10e OFFLINE
chas10e
    Dragonstomper
  • 780 posts
Posted Tue Jan 16, 2018 11:32 PM
I check the individual batteries with a volt meter ( OCD :P )
yeah I snagged most all my PNP's @ thrift store where ever I could find 'em for about that price *coughs (Hoarder)
my only complaint with the unit is the button is on the wrong side of stick for Galaga , especially the bonus rounds
#7 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Wed Jan 17, 2018 9:37 AM
Cleaned battery area and put new in..nothing...also tried bending the cable...nothing..any other possibilities??
#8 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Wed Jan 17, 2018 9:55 AM
Since the audio is working, alludes that the PCB is fine. Very likely the video cable pinched or pulled. Should be an easy fix of soldering in a new two wire RCA cable to the PCB inside. Once you fix it, the stick has a "spinner" twist for Pole Position.
EDIT
In a real car when driving a stick, you have to release the gas pedal, push in the clutch and shift gears. Okay where am I going with this? I have a spare Ms Pacman PlugNPlay that had a bad fire button contact inside, the plastic broken. I combined both contact pads to the one remaining button. Two games were affected which added a change to the game play.
Pole Position - Momentary release "gas pedal", then press again to upshift and downshift.
Xevious - Both shoot and bomb are now single button. No big deal with unlimited ammo.
PlugNPlay Review (See OP for more) - http://www.racketboy...=483424#p483424
Edited by CRTGAMER, Wed Jan 17, 2018 10:09 AM.
#9 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Wed Jan 17, 2018 10:14 AM
EDIT
awesome....that will be my next attempt!!  should be worth the $4 if I can get her fired up
#10 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Wed Jan 17, 2018 10:19 PM
Do you have component connection on TV? (yellow) or is it R-B-G ?
In case you missed this, slipped by me as well. If HDTV shared component composite jacks, try plugging the yellow cable to the green jack. Use the remote to change to composite.
#11 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Thu Jan 18, 2018 8:16 AM
yup did that too....will take it apart today and see what's going on inside....is anyone on here willing to try and get it to work if I ship it and pay for shipping back?Now it's just the principle of wanting to get it to work,nary the cost!!
#12 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Thu Jan 18, 2018 8:46 AM
Its only two wire solder connection for a replacement RCA cable.
#13 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Thu Jan 18, 2018 8:51 AM
yup ....gonna try that today...hopefully will do the trick
#14 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Thu Jan 18, 2018 9:20 AM
Can you post pictures of the PCB, maybe with old cable removed and new video cable soldered in? This would be a great reference for many PlugNPlay repairs; the cable usually damaged buried in a thrift store container.
#15 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Thu Jan 18, 2018 12:00 PM
will do!!!
#16 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Thu Jan 18, 2018 3:34 PM
deleted pics
Edited by Jacro017, Thu Jan 18, 2018 4:15 PM.
#17 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Thu Jan 18, 2018 3:35 PM
Here are pics of the open unit...ran a continuity test on audio and video.... all circuits came back ok-I'm at a loss
Edited by Jacro017, Thu Jan 18, 2018 4:10 PM.
#18 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Thu Jan 18, 2018 3:52 PM
Thanks for the pictures. Concerning the video cord, did the meter show if the ground and middle wire connected to each other? Either way if you have an spare video cord, maybe try replacing it anyways? A simple solder job, you just might luck out and not too costly a try.
I see where the video red and audio white connect to the PCB, appears the ground black shares a pad. Where is the connection that splices in the two ground wires? You have a phone number underneath, maybe delete the picture and retake? I hid your text in the picture below.
Edited by CRTGAMER, Thu Jan 18, 2018 4:17 PM.
#19 chas10e OFFLINE
chas10e
    Dragonstomper
  • 780 posts
Posted Thu Jan 18, 2018 4:49 PM
board on one of mine is slightly different: but what I noticed ,
  • a bead of hot melt glue over the joints ( mine may not have been altered)
  • you have an extra white wire from your video & looks like is bugger-soldered to other side of board
#20 Jacro017 OFFLINE
Jacro017
    Star Raider
  • 60 posts
Posted Fri Jan 19, 2018 12:00 PM
Could that extra white wire be the cause for the rolling/flickering/scrambled off color video?
#21 chas10e OFFLINE
chas10e
    Dragonstomper
  • 780 posts
Posted Fri Jan 19, 2018 3:13 PM
mebbe try & clean up them connections on the left side of the board (2 whites & red) looks like some work had been done to them
looking again the red video wire on the right looks like there is a blob of solder bridging a component on the other side of board ( I am not sure if it's supposed to be that way or not, (perhaps it does) on mine I can see a trace that connects to something
