2018 Contest Chat
146 replies to this topic
#51 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Sat Mar 24, 2018 7:00 PM
Given the number of objects in screen at same time, this is done with 16 GRAM predefined.
The object is moved one bit to right for 8 times, the extra goes into another card.
Then you use an array to select the card for the pixel coordinate AND 7.
Essentially infinite objects of same type on screen.
OK, I'm still working on how to do this. but, in my search around the forum I found the paralax scrolling discussion and that led me to an animation from "Inty-B Volume 2". Is this available anywhere? the code for it etc.  I can't find it and was wondering if it was ever released.
#52 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,836 posts
  • Coding something good
Posted Sat Mar 24, 2018 7:02 PM
I think Tarzilla is still developing volume 2 and didn't feel like source code was ready.
#53 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
  • The P-Machinery AGE is almost here!
Posted Sun Mar 25, 2018 6:40 AM
fsuinnc, unfortunately there doesn't seem to be any ready-made IntyBASIC code of this technique, but it is quite simple, you should be able to give it a try.  Here's the simple algorithm:
  • First, decide whether you will be "scrolling" a repeating pattern (like a light marquee) or "moving" an object (like in the meteor example).  There is a difference in the implementation because moving the object requires shifting it out of the card and into a new one, which requires more animation cards.  In any case, the technique is the same.
  • Draw the pattern or object on an 8x8 picture card.  Here's my sample object, just an oval:
  • Now, repeat the picture as many times as it takes to shift it in and out of the 8x8 card space, one pixel at a time.  That will be our animation sequence:
:0       :1       :2       :3       :4       :5       :6       :7       :8       :9       :10      :11      :12      :13      :14      :15
  • Now, decide where your object starts on the screen.  It'll probably be on the edge of the screen so that you can smoothly transition it into the visible field.  You set a BACKTAB card the first picture in our sequence, tile #0 above.
  • Decide the direction you are moving.  The sequence above moves the object from the right to the left.  Animating it in reverse will result in moving the object from left to right.
We're ready to "move" our object by animating it across the BACKTAB.  First, since it is a "moving object," we'll want to keep track of some information on it, similar to how we do for a MOB:  it's speed, it's position in the play-field (in case there's a "logical" coordinate system), and its actual position in the BACKTAB (which will change as it moves across the screen), and its current animation frame.
This last one is important, as you'll see, because it tells us the "offset" within a BACKTAB card in which the object resides.  Together, the BACKTAB card number and the animation frame, tells us precisely where in the play-field our object is.
One other thing to remember is that, as the object moves across the field, it will occasionally straddle two BACKTAB cards.  We'll have to keep track of both (or at least one of them, and derive the other from it).
To simplify things, we'll track the "leading edge," that is, the BACKTAB card containing the front of the object.
There's also a few things we need to know about our animation sequence.  It'll be useful to keep these constants around.
  • First frame for moving left:  picture #0.
  • Last frame for moving left:  picture #15.
  • First frame for moving right:  picture #14.
  • Last frame for moving right:  picture #0.
  • First frame shifting out of card for moving left:  #8.
  • First frame shifting out of card for moving right:  #6.
In the algorithm below, we are going to move from the right edge of the screen to the left.  To move in the other direction, just reverse the signs on all maths operations, e.g., turn all additions to subtractions, and vice-versa.
Now, Let's animate it!
  • FIRST_FRAME = 0
  • LAST_FRAME = 15
  • FIRST_SHIFT_FRAME = 8
MAIN LOOP:
  1. Increase animation frame number for the LEADING BACKTAB.
  2. Is the frame number less than the FIRST_SHIFT_FRAME?
    1. Yes:  The object is still in the same card.
      1. Go to ANIMATE LEAD
      2. Go to ANIMATE TRAIL
    2. No:  The object moved into a new card.
      1. Go to ENTER NEW CARD
  3. Go to Step 1.
ANIMATE LEAD:
  1. Set LEADING BACKTAB to new frame card.
  2. Return
ENTER NEW CARD:
  1. Set animation frame number for TRAILING BACKTAB to current leading animation frame.
  2. Set animation frame number for LEADING BACKTAB to FIRST_FRAME.
  3. Update LEADING BACKTAB to point to new leading frame (FIRST_FRAME).
  4. Return
ANIMATE TRAIL:
  1. Is current animation frame for TRAILING BACKTAB equal to LAST_FRAME?
    1. No:  Update TRAILING BACKTAB with current animation frame.
    2. Yes:  We're done with TRAILING BACKTAB.  We can discard its information for the moment.
  2. Return
By doing the above for multiple objects on the screen, you can simulate "scrolling."  The parallax effect comes when you animate multiple objects at different speeds and different starting animation frames -- all the objects at the same speed appear to be on the same "perspective plane."
Also, by keeping the animation frames as powers of two, you can shortcut some steps by just using bitwise operations rather than more expensive comparisons and go-tos.
I hope the above helps.
    -dZ.
EDIT:  Re-wrote algorithm for clarity.
EDIT:  Added Step 2.1.1 to clarify that the LEADING BACKTAB needs to be updated.
Edited by DZ-Jay, Tue Mar 27, 2018 5:30 AM.
#54 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Tue Mar 27, 2018 5:19 AM
(sorry for the delay)  Thanks for the detailed help. Pretty amazing. This was all very helpful and I am playing with some ideas. It's amazing how much time and effort you guys put into helping people (me).
Thanks again.
#55 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Tue Mar 27, 2018 5:23 AM
Thanks again.
No worries.  If I were a good programmer (or at least knew IntyBASIC), I would offer code.  So I leave that to the experts here. :)
   -dZ.
#56 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Tue Mar 27, 2018 5:27 AM
Your outline is just about as good as code, maybe better.  I'm playing with code myself. Downside is now that I can make one image move I want to move ten. Then timing becomes a problem because I don't quite get that. and on and on. Thankfully, I find the processes very enjoyable even if I never get a game out of it.
#57 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Tue Mar 27, 2018 5:53 PM
Just in case anybody wants to see (and maybe can make it better). a couple of examples of moving things horizontally accross the screen. At present it goes only left to right.
Attached File  scroll_test.bas   4.96KB   51 downloads (this is the source for the first animation. code is the same for the second just the bitmaps change)
Now, I need to work on better ways to control the timing of things.
Thanks again to DZ-Jay and nanochess for putting up with me.
Edited by fsuinnc, Tue Mar 27, 2018 5:53 PM.
#58 nanochess OFFLINE
nanochess
  • 5,836 posts
Posted Tue Mar 27, 2018 5:59 PM
You're welcome :) :thumbsup:
#59 emerson ONLINE
emerson
    Chopper Commander
  • 170 posts
Posted Tue Mar 27, 2018 6:55 PM
Well done fsuinnc!
#60 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Wed Mar 28, 2018 3:07 AM
attachicon.gifscroll_test.bas (this is the source for the first animation. code is the same for the second just the bitmaps change)
That's great!  I'm glad I was able to help.   :)
Hipnotic!  Nice work. :thumbsup:
   -dZ.
#61 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Wed Mar 28, 2018 7:08 PM
I know this is dumb, but i didn't even think about multiple colors when I was messin with this.  and then it hit me.  I just thought it was cool so I posted it.
(sharing is caring)
#62 digress OFFLINE
digress
  • 1,124 posts
Posted Tue Apr 3, 2018 6:29 PM
wow 4 entries now. Pretty cool. just need 2 more or I'll have to enter twice.
#63 Kiwi ONLINE
Kiwi
  • 1,675 posts
Posted Tue Apr 3, 2018 9:58 PM
I'll join in. I haven't thought of what game to make.
#64 cmart604 OFFLINE
cmart604
    Intellivision Hoarder
  • 12,345 posts
  • Running out of things to buy.
Posted Tue Apr 3, 2018 11:30 PM
Bacon. Make a bacon game please. Just sayin. :)
#65 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,642 posts
Posted Wed Apr 4, 2018 12:27 AM
2/3 of the contest time remains. I'm sure there will be additional entries. Last time I think about 50% of the entries were submitted in the last month, though it might be different this time depending on how many spend their summer vacation programming video games.
#66 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Wed Apr 4, 2018 5:16 AM
OK, I'll give you a hint...
Spoiler
    -dZ.
#67 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Wed Apr 4, 2018 2:14 PM
I am planning to have an entry.  Not sure exactly how far I will get but I am hoping to make something similar to the classic arcade 'Lunar Rescue'. If your not familiar here is a video https://www.youtube....h?v=6oeAsbC2xKA
After much looking I felt this game and it's single screen was better suited to my thinking process than the taxi game or most of the other great ideas people shared.
(there is a good A2600 homebrew game very similar called "This Planet Sucks").
#68 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,642 posts
Posted Wed Apr 4, 2018 3:11 PM
What a lovely little gem! Previously unknown to me, despite it's from Taito.
#69 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Wed Apr 4, 2018 4:26 PM
Oh yeah!  I remember that game.  I used to play it at a pizza parlor close to my grandparents house when I was a kid.  I would imagine that game would be harder to implement than Space Taxi, but if you can pull it off it would be great! :)
    -dZ.
#70 emerson ONLINE
emerson
    Chopper Commander
  • 170 posts
Posted Wed Apr 4, 2018 4:40 PM
Lunar Rescue reminds me of Cosmic Ark, just more complicated.
Also, I plan to have an entry as well. I know what I want to do, and am slowly figuring out how to do it.
#71 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,642 posts
Posted Wed Apr 4, 2018 6:21 PM
It reminds me, is there somewhere an equivalence list of Intellivision games and any arcade games or other formats they've been based upon? While I can find lists with just the titles and even ROMs to download, I haven't really come across any good sites with screenshots, like a Gamebase64, Lemon Amiga, Generation MSX or any other similar site out there. Of course just looking at a screenshot not always is enough to determine how the game plays, but it gives a hint which games are worth studying more carefully if one wants to extend the wheel rather than redo it. But yes, an equivalence list even without screenshots would be a great start, and for those games that don't really have a match on another format just leave it blank.
#72 Intymike OFFLINE
Intymike
  • 3,358 posts
Posted Thu Apr 5, 2018 10:59 AM
Cool, Jupiter Lander meets Space Invaders meets Choplifter. With the twist that this game was there before two of this games.
#73 Rev OFFLINE
Rev
    IntellivisionRevolution
  • 16,405 posts
Posted Sun Jun 10, 2018 9:20 PM
Any new entries coming? 😃
#74 nanochess OFFLINE
nanochess
  • 5,836 posts
Posted Sun Jun 10, 2018 9:25 PM
I've heard there are at least two games in the works and possibilities of two more :)
#75 Rev OFFLINE
Rev
  • 16,405 posts
Posted Sun Jun 10, 2018 9:44 PM
