[Final] Monkey King
100 replies to this topic
#76 Arenafoot OFFLINE
Arenafoot
  • 1,375 posts
  • videogamestores.net
Posted Sat Sep 15, 2018 3:29 PM
Major AI overhaul, it now chases after stones and gives you a good challenge.
I also changed the graphics of the UI a bit.
2 bytes left, I want to add two more if statments, so need to free up space somehow. After that I think that its done.  :)
Oh wow! This version 23 is REAL challenging (for the 1 player game)!!!!
#77 Karl G OFFLINE
Karl G
    Dragonstomper
  • 821 posts
Posted Sat Sep 15, 2018 3:53 PM
It will only gain you a few bytes, but putting initializations of variables to the same value on the same line will save a little bit.  So, e.g.:
 _invisible0 = 0
 _invisible1 = 0
Should be:
 _invisible0 = 0 : _invisible1 = 0
#78 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,677 posts
  • Braindead
Posted Sat Sep 15, 2018 4:25 PM
I just played v0.23 a bit and the AI is really challenging now. An old bug returned - the game speed doesn't reset after game over. When you start a new game it starts at high speed.
#79 Arenafoot OFFLINE
Arenafoot
  • 1,375 posts
Posted Sat Sep 15, 2018 4:30 PM
I didn't see that happen on mine.....it reset on the next game.
#80 fluxit ONLINE
fluxit
    Chopper Commander
  • 210 posts
Posted Sat Sep 15, 2018 7:17 PM
A way to provoke the bug is to use enough low speed powerups to flip the speed to 'hi.'  Games from from that point on will start at a hi speed.
Edited by fluxit, Sat Sep 15, 2018 7:17 PM.
#81 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,677 posts
  • Braindead
Posted Sun Sep 16, 2018 2:27 AM
The bug only happens once you reach high speed (around 200+ points).
#82 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sun Sep 16, 2018 2:31 AM
All bugs fixed! I managed to make the framerate stable by changing the pfread to a playfieldpos check and using it at playfieldpos=1. This shifted the top block creation to playfieldpos 1 instead of 0 and for some reason that fixed everything. I think that that is a good reason to stop touching it and just tweak some starting numbers. (Unless more bugs are found of course!) I'm quite happy with the game in this state. :)
I also added an option to play vs the old AI (non moving one) by flipping the B/W switch. See it as a practice mode.
Glad you like it. I think that the AI is quite cool no.
 _invisible0 = 0
 _invisible1 = 0
Should be:
I tried some of that and removed 2 pfchecks which gave me a lot. They are super heavy commands!
Glad you like it! Bug is fixed in v24
#83 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,677 posts
  • Braindead
Posted Sun Sep 16, 2018 6:18 AM
The gamespeed works correctly now, will play some more later to check everything.
You probably don't need it anymore but you could save 7 bytes by drawing the playfield directly with playfield variables:
var1 = %00000001 : var2 = %00000001 : var5 = %00000001 : var6 = %00000001 : var9 = %00000001 : var10 = %00000001 : var13 = %00000001
var14 = %00000001 : var17 = %00000001 : var18 = %00000001 : var21 = %00000001 : var22 = %00000001 : var25 = %00000001 : var26 = %00000001
var29 = %00000001 : var30 = %00000001 : var33 = %00000001 : var34 = %00000001 : var37 = %00000001 : var38 = %00000001 : var41 = %00000001 : var42 = %00000001
http://www.randomter....html#playfield
#84 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sun Sep 16, 2018 6:55 AM
Do you put that into the playfield enviroment or outside? It gives me errors. However I just tried pfvlines and that freed a lot up, got 43 now.
 pfvline 8 0 10 on
 pfvline 24 0 10 on
I'm almost sad, it feels like I should fill it. :P
#85 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,677 posts
  • Braindead
Posted Sun Sep 16, 2018 7:51 AM
 pfvline 8 0 10 on
 pfvline 24 0 10 on
You use the variables instead of the playfield - delete the playfield and paste the code from my post where your playfield was.
D'OH! I forgot about pfvline, that works even better for straight line playfields like yours. :D
#86 fluxit ONLINE
fluxit
    Chopper Commander
  • 210 posts
Posted Sun Sep 16, 2018 5:32 PM
The AI is quite aggressive, which is fun.  Where before I would take the occasional coconut to the face in order to save 'player 2,' I've now seen it bang right through a coconut, beating me to the stone.  It can be challenging at times to actually collect that third stone to replenish your life while the AI is active.
#87 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sun Sep 16, 2018 11:51 PM
I'm glad that you like it. Is the behaviour good you think? I could make it keep going for stones even after getting 3, but that seemed a bit much.
Got some space left though so open for suggestions.
#88 Muddyfunster ONLINE
Muddyfunster
    Moonsweeper
  • 312 posts
Posted Mon Sep 17, 2018 5:51 PM
 _invisible0 = 0
 _invisible1 = 0
Should be:
I didn't know that tip, that's helpful, thanks Karl G.
#89 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sat Sep 29, 2018 9:40 AM
New version up.
Feedback welcome!
#90 fluxit ONLINE
fluxit
    Chopper Commander
  • 210 posts
Posted Mon Oct 1, 2018 3:45 PM
The 10,000s digit on one of the scores has a '1' in it at boot.  This is seen in MAME and Stella.
The AI can kick my butt at speed now if I don't use 'add branch' to kill it off.  I let it play out after a silly death on my part, and it reached a high score of 7155.
#91 ZeroPage Homebrew OFFLINE
ZeroPage Homebrew
    Dragonstomper
  • 609 posts
Posted Wed Oct 17, 2018 2:52 PM
We'll be featuring the NEW FINAL UNRELEASED version Monkey King LIVE on today's ZeroPage Homebrew stream on Twitch at 6PM PT/9PM ET! We'll also be playing the boxed version of Zippy the Porcupine!
Twitch Stream: https://www.twitch.t...ropagehomebrew/
Games Today:
- Alien Attack (2018) by Edward Smith (easmith)
- Alien Revenge (2018) by Edward Smith (easmith)
- Monkey King (FINAL) (2018) by Alex Pietrow (coolcrab)
- Zippy The Porcupine by (2015) by Chris Spry (Sprybug)
#92 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Thu Oct 18, 2018 1:06 AM
Big Update! Added new powerup and fixed the framerate. However there seem to be sound glitches. :(
I'll work on those when I'm back from travel.
New manual also up in main thread!
#93 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Sun Oct 21, 2018 10:56 AM
 The code wont compile (missing goto's)
 The invicible icon in score_graphics.asm is different than shown
 You don't need pfvline here it's already in the branch clearing stuff
 ; pfvline 8 0 11 on
 ; pfvline 24 0 11 on
 gosub clearP0left
 gosub clearP0right
 gosub __sprite_color : drawscreen
 gosub clearP1left
 gosub clearP1right
 you don't need all these joy0fire clauses in the if statements
 you already tested that in the first if statement
 ; power up activation
 if !joy0fire then __skipfire
 ; if joy0fire && player0score > $0 then gosub __firesound
 ; if joy0fire && player0score = $a then gosub __slowdown : player0score = $0
 ; if joy0fire && player0score = $b then gosub __killbranch1
 ; if joy0fire && player0score = $c then gosub __livesplus1
 ; if joy0fire && player0score = $d then player0score = $0 : _invisible0 = 1
 ; if joy0fire && player0score = $e then player0score = $0 : gosub __mkbranch1
 ; if joy0fire && player0score = $f then player0score = $0 : _invincible = 25 : _left_right{6} = 1 : _F0 = 25
 if player0score > $0 then gosub __firesound
 if player0score = $a then gosub __slowdown : player0score = $0
 if player0score = $b then gosub __killbranch1
 if player0score = $c then gosub __livesplus1
 if player0score = $d then player0score = $0 : _invisible0 = 1
 if player0score = $e then player0score = $0 : gosub __mkbranch1
 if player0score = $f then player0score = $0 : _invincible = 25 : _left_right{6} = 1 : _F0 = 25
 You can flatten the killbranch routines a little (but you still need the labels for the individual routines
 since you're calling them to setup the playfield)
killbranch1
   player0score = $0 : bally = 100
   gosub sprite_color
   if left_right{4} then clearP0left
clearP0right  var1 = 1 : var5 = 1 : var9 = 1 : var13 = 1 : var17 = 1 : var21 = 1 : var25 = 1 : var29 = 1 : var33 = 1 : var37 = 1 : var41 = 1 : var45 = 1 : return
clearP0left   var0 = 0 : var4 = 0 : var8 = 0 : var12 = 0 : var16 = 0 : var20 = 0 : var24 = 0 : var28 = 0 : var32 = 0 : var36 = 0 : var40 = 0 : var44 = 0 : return
 Since you allways call the sprite_color routine before drawscreen you can move drawscreen into sprite_color and get rid of a bunch of calls to drawscreen
 and you can do it with a tail call optimization (you need the prepended dot because that's what bB assumes
 ie "goto drawscreen" becomes "jmp .drawscreen" so you need to declare .drawscreen)
   if startgame then sprite_color_return
   ;Check if player is invisible
   if invisible0 then invisible0 = invisible0 + 1 : COLUP1 = $C4
   if invisible0 = 200 then invisible0 = 0
   if invisible1 then invisible1 = invisible1 + 1 : COLUP0 = $C4
   if invisible1 = 200 then invisible1 = 0
   const .drawscreen = drawscreen
sprite_color_return
    goto drawscreen
 I think you're calling drawscreen a lot more than you need to
 Since your pfreads are with constants, just use the screen variables
  ; if pfread(9,1) then return
  ; if pfread(25,1) then return
  if var5{1} || var7{1} then return
Edited by bogax, Sun Oct 21, 2018 11:00 AM.
#94 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sun Oct 21, 2018 3:57 PM
 ; pfvline 8 0 11 on
 gosub clearP0left
 gosub clearP0right
 gosub clearP1left
 gosub clearP1right
killbranch1
   gosub sprite_color
sprite_color_return
    goto drawscreen
Strange it worked when I uploaded it, but I was in a rush so maybe I messed up :S I'm stuck on a mountaintop on a island until the end of the month (looking at the Sun, or trying at least), but maybe I can get bB to work on my Mac. All my saves are on my home PC though, so I can't access them. I'm hoping that its just the .asm files that are wrong. I'll get back to you asap.
Thanks for the upgrades also, this should shave off quite some bits again. :)
#95 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sun Nov 18, 2018 5:10 AM
RC5 has the sound glitch fixed and I think is basically done now. Unless people find anything terrible. :)
#96 fluxit ONLINE
fluxit
    Chopper Commander
  • 210 posts
Posted Tue Nov 20, 2018 7:52 PM
The ghost monkey is a cool addition.
It's a very small thing and may only be an emulator issue, but the leftmost pixel of the left ghost monkey shows up on the right side of the screen.
I need to spend some more time with this release, but I've not seen any real issues so far.
#97 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Wed Nov 21, 2018 3:57 AM
The ghost was not intentional, I changed the BG a bit and forgot the players. :P
But it could become a feature as a controllable monkey that does not collide with things to keep the loser entertained in keep going mode.
I'm glad that you like it though!
#98 Karl G OFFLINE
Karl G
    Dragonstomper
  • 821 posts
Posted Wed Nov 21, 2018 7:33 AM
Kinda like the "ghosts" of dead players in Warlords when the screen flashes.  I doubt those were intentional, but it was a neat effect, so she probably decided to keep it instead of fix it, at a guess.
#99 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Thu Nov 22, 2018 6:03 AM
Having similar inclinations now. Will work on that this weekend.
#100 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 419 posts
Posted Sat Nov 24, 2018 4:58 PM
Added a ghost function in 'keep going mode' that behaves as a normal monkey but does not interact with any objects. As suggested by Fluxit and KarlG
Edited by Coolcrab, Sat Nov 24, 2018 5:00 PM.
