New Coleco RGB board?
ColecoVision RGB Coleco
157 replies to this topic
#51 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Sun Mar 4, 2018 1:12 PM
I just ordered more boards yesterday because the first run I did are almost gone.
#52 omf OFFLINE
omf
    Dragonstomper
  • 773 posts
Posted Sun Mar 4, 2018 3:50 PM
will this work on a PAL machine?
#53 citrus3000psi OFFLINE
citrus3000psi
    Space Invader
  • 45 posts
Posted Mon Mar 5, 2018 8:48 AM
I've never tried it in a Pal System.  The PAL TMS9929 has color bursts which should make my board not supported.  However I have design a PAL variant based off this: https://hackaday.io/...mponent-adapter
This board is 100% untested: https://oshpark.com/...ojects/ogorMaoU
#54 grips03 OFFLINE
grips03
  • 3,664 posts
Posted Mon Mar 5, 2018 8:59 AM
Soldermasked vias, what a great idea.
#55 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 453 posts
Posted Mon Mar 5, 2018 9:18 AM
Have you found that you needed the pots, or did the colors look fine with just the jumpers.
#56 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Mon Mar 5, 2018 9:22 AM
I am building them with the pots right now. I plan to investigate the the values as I have more consoles to test with but all of the boards I have built so far are being sent to others that wanted a DIY.
I do intend to see if there is a happy medium value that citrus3000psi can change the boards to use or with his permission I can change them, if I find a magic value.
#57 citrus3000psi OFFLINE
citrus3000psi
    Space Invader
  • 45 posts
Posted Mon Mar 5, 2018 9:42 AM
The pots have been different for all the boards I've done.  I think its related to power supplies etc for each console.
@mobiusstriptech, on the latest revision on my oshpark, there is a jumper so you can bypass the pot and drop a straight resistor in.
#58 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Mon Mar 5, 2018 9:46 AM
Yeah those are the ones I am building right now. I just meant if there was some sort of sweet spot we could remove the pot and jumpers all together. Either way, I and many others thank you for bringing this to everyone.
#59 grips03 OFFLINE
grips03
  • 3,664 posts
Posted Mon Mar 5, 2018 12:31 PM
You guys are all hand soldering?
#60 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Mon Mar 5, 2018 12:32 PM
Right now I am building them by hand. If I do a large batch I am going to look at having them assembled.
#61 Gaztee OFFLINE
Gaztee
  • 1,698 posts
Posted Wed Mar 7, 2018 6:30 PM
Boards ordered, so we will see if they work on a PAL coleco in about a months time :)
#62 citrus3000psi OFFLINE
citrus3000psi
    Space Invader
  • 45 posts
Posted Thu Mar 8, 2018 7:25 AM
Great let me know, if it works for you  :-o
#63 omf OFFLINE
omf
    Dragonstomper
  • 773 posts
Posted Thu Mar 8, 2018 8:59 AM
i beleive that ordering the boards will only deliver the board, the components will need to be obtained and soldered on.  what size of surface mount components need to be purchased to go on those boards?  i will be populating the boards gaztee has purchased so need to know what i need to order for the parts.
#64 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Thu Mar 8, 2018 9:01 AM
Correct the boards are blank. Component sizes are 0603.
#65 citrus3000psi OFFLINE
citrus3000psi
    Space Invader
  • 45 posts
Posted Thu Mar 8, 2018 9:10 AM
I just updated the oshpark link with sizes and some digikey part numbers for the not so obvious parts.
https://oshpark.com/projects/ogorMaoU
Edited by citrus3000psi, Thu Mar 8, 2018 9:11 AM.
#66 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Tue Mar 20, 2018 7:56 AM
I will have a couple more boards available shortly. Just need to assemble. I am trying to gauge interest overall on these. If there is enough interest I will do a large run. So if you are looking to buy a board or get one installed please let me know.
#67 grips03 OFFLINE
grips03
  • 3,664 posts
Posted Tue Mar 20, 2018 5:35 PM
Looking to buy one board.  It would be great if it had the POTs on it.
#68 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Tue Mar 20, 2018 5:46 PM
I am fully assembling the boards so they do have the pots. It's a drop in and go operation.
#69 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Thu Mar 22, 2018 7:26 AM
This morning I submitted for a large production order. Hopefully it will be enough to meet the demand. Thank you to everyone who messaged me to let me know you were interested. None of this would be possible without the hard work of citrus3000psi.
I am not making any changes to the boards or even the silkscreen. My whole goal here is to help get these out to the people who want them. If you want to assemble them yourself and don't want to purchase one pre-assembled, that is totally fine as well. Just remember the components are 0603 so it does require some skill to assemble by hand.
#70 grips03 OFFLINE
grips03
  • 3,664 posts
Posted Thu Mar 22, 2018 8:58 AM
and very good eyesight too :)
#71 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Sun Mar 25, 2018 3:07 PM
Boards are assembled and ready to go. This is the last small batch. Likely will not last long. If you want one shoot me a message.
After these the large production batch will hopefully be enough to cover everyone else that wants one.
#72 5l4k3r OFFLINE
5l4k3r
    Combat Commando
  • 6 posts
  • Have you played ATARI today?
Posted Sun Mar 25, 2018 7:45 PM
Finally got around to installing the one I got from mobiusstriptech's first batch. Colecovision looks GREAT!
Thanks to both citrus3000psi and Mobiusstriptech!
#73 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 180 posts
Posted Sun Mar 25, 2018 7:48 PM
Awesome! So far everyone from the first batch has said they have had great results. Eventually I will keep one of these for myself.
I definitely have to give huge thanks to citrus3000psi. Without him this wouldn't be possible.
#74 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,079 posts
  • I am the one who knocks!
Posted Sun Mar 25, 2018 7:55 PM
Are you talking about the PIN#1 indicators?
#75 grips03 OFFLINE
grips03
  • 3,664 posts
Posted Sun Mar 25, 2018 8:46 PM
Talking about this picture.  Great job citrus3000psi !
Also tagged with one or more of these keywords: ColecoVision, RGB, Coleco
