New Coleco RGB board?
ColecoVision RGB Coleco
161 replies to this topic
#151 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Sun Jul 15, 2018 1:49 PM
The Colecovision only had RF originally. This isnt exactly like those as they use a fpga or cpld with custom firmware. However it is more involved than just a RGB bypass board like the ones for the SNES. The colorspace is being converted from YUV to RGB.
#152 panzeroceania OFFLINE
panzeroceania
    Space Invader
  • 36 posts
Posted Sun Jul 15, 2018 2:19 PM
thanks! yeah I know the CV only had RF externally but was trying to figure out what it outputs internally. to reference a newer system the PC Engine had a standard RF out but it had RGBS available internally. I believe the Atari VCS only has RF externally but has Y/C ( Luma-Chroma / S-Video) internally.
So what you're saying is on the TMS9928A Pins 35, 36, and 38 output B-Y (Blue difference) Y (Luminance) and R-Y (Red difference), and that in this mod it is a simple color Transcode from Y,B-Y,R-Y to RGBs, which is a much simpler process than a from scratch digital to analog Encode which these other devices like the F18A, NESRGB, etc are doing, which basically bypass the entire native analog encoding process of the Colecovision video IC. Whereas the solution in this thread works with what the original Colecovision IC natively outputs and performs a simple transcode on. right?
Thanks!
Edited by panzeroceania, Sun Jul 15, 2018 2:21 PM.
#153 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Sun Jul 15, 2018 2:24 PM
Yes. Precisely.
#154 grips03 OFFLINE
grips03
  • 3,896 posts
Posted Thu Jul 26, 2018 8:48 PM
was there a 50Hz European version of this mod?
#155 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Thu Jul 26, 2018 8:50 PM
There is a PAL board as well. I don't know if anyone ever tested it though. A few people said they were going to order them. Citrus put them up on oshpark if you want to make some.
#156 adamchevy OFFLINE
adamchevy
  • 1,805 posts
Posted Fri Aug 10, 2018 12:49 AM
Would this work on the Adam Computer?
#157 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Fri Aug 10, 2018 5:38 AM
Technically it should. As long as it has the same series vdp equipped. I don't know if anyone has actually tried it yet.
#158 NIAD OFFLINE
NIAD
  • 6,267 posts
Posted Fri Aug 10, 2018 2:57 PM
No reason that it shouldn't seeing as the CV board on an Adam is nearly identical... just rearranged a little.
#159 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Tue Aug 28, 2018 12:10 PM
Just FYI, I am almost out of stock on these. I will be ordering more but making a few alterations to the board. The changes will not be require current owners to upgrade. They are mainly minor changes based on data I have compiled.
There also will not be a price change for the next revision. If anyone wants bare boards to build themselves, I do have a few bare boards of this current revision that I could sell without components.
#160 ZeroPage Homebrew OFFLINE
ZeroPage Homebrew
    Dragonstomper
  • 676 posts
Posted Thu Sep 6, 2018 11:55 PM
Thanks for the update mobiusstriptech! I'm looking forward to buying a board kit from your new batch.
Right now I broadcast an all homebrew Twitch livestream show using an RGB Atari 2600 and I'm looking to get into showing off the latest Coleco homebrew as well, in the best quality possible of course! :-)
#161 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Tue Sep 11, 2018 8:52 PM
New prototype boards should be here soon. I have a few Colecovision consoles to test these on so with any luck I will be ordering the new batch very soon.
On a different note, I have had 2 people report issues with green color bleed on white lines, specifically the lettering. It is most prominent in cases where a digital display and a scaler (Framemeister/OSSC) are in use but it might be visible on some PVM/BVM. In both cases there has also been an issue with screen brightness. If anyone has purchased a board from me and encountered this, please let me know. I am interested in finding a solution to this, if it is possible.
On one board I had to use a much larger value pot for green to drive the signal down to spec. It was seeing 1VPP with the 5k pot maxed out.
Again this has been limited to only 2 reports so far and the same RGB board does not exhibit the issue on a different Colecovision board. So I do believe it is the main board that is causing the heavy green saturation and dark image.
#162 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Fri Sep 28, 2018 9:15 PM
As a small update. I have the newest revision prototypes in hand. These boards are currently in test and from my testing thus far they perform on par with the previous boards.
Now that being said, I have begun to make modifications to the circuit from what citrus originally put out. All of these modifications are based on my findings from all of the installs. I believe I have located the source of the green bleed issue, as well as the dark/narrow line issues that those consoles were displaying. I am currently investigating a few other minor things I would like to see changed or improved.
So no ETA on a new batch yet but hopefully in the near future.
Also tagged with one or more of these keywords: ColecoVision, RGB, Coleco
