Reading multiple serial ports in GFA Basic 3.5
2 replies to this topic
#1 Fletch OFFLINE
Fletch
  • 1,064 posts
Posted Mon Jan 22, 2018 9:36 PM
Is there a way to read data from the other serial ports on a TT in GFA Basic 3.5?  I have used the inp(1) command to read from the main serial port, but am not sure how to read from the others.
Any suggestions?
-Pete
#2 ggn OFFLINE
ggn
  • 1,472 posts
Posted Tue Jan 23, 2018 12:44 PM
Hi,
Serial ports were never my strong point but I had a quick look through the compendium and came across this: http://cd.textfiles..../HTML/CHAP4.HTM
BIOS input and output calls to device #1 and XBIOS calls which configure the serial port always refer to the currently 'mapped' device as set with Bconmap(). The Modem CPX allows a user to map any installed device as the default.
Then it gives a table of serial port numbers depending on the machine. If I read this correctly then you can use bconmap (xbios 44) to map the serial port you like to device 1 and then use inp(1) to read data off the port.
Not sure that this will do the trick but I think it's a good starting point :). Let us know how you get on.
#3 Fletch OFFLINE
Fletch
  • 1,064 posts
Posted Tue Jan 23, 2018 8:43 PM
Hi,
Thanks for the tip!   I'll give that a go.
