[Newbie] DASM fatal errors
3 replies to this topic
#1 Fuselage OFFLINE
Fuselage
    Combat Commando
  • 4 posts
Posted Mon Jan 29, 2018 3:05 AM
Hey all,
I was studying Hugg's book but instead of relying on his IDE, I wanted to make sure I could compile the code into a .bin myself.
I downloaded DASM, set up a commandline to open in its folder, copied vcs.h and macro.h into that folder, as well as my red.asm file, using the first program in the book:
	processor 6502
	include "vcs.h"
	include "macro.h"
	org  $f000
Start   sei		; disable interrupts
	cld		; disable BCD math mode
	ldx  #$ff	; init stack pointer to $FF (grows upward)
	txs		; ... transfer X register to S register (stack pointer)
	lda  #$00	; set A register to zero ('#' denotes constant)
Zero    sta  $00,X	; store A register at address ($0 + X)
	dex		; decrement X by one
	bne  Zero	; branch until X is zero
        sta  $00	; the loop doesn't cover address 0
	lda #$30	;load value into A ($30 is deep red on NTSC)
	sta COLUBK	;put the value of A into the background color register
	jmp Start
	org $fffc
	.word Start
	.word Start
I've run DASM with a variety of line options, and each time I get the 'dasm.exe stopped working'.
I also tried compiling the kernel snippet from this forum, along with the exact parameters suggested (dasm kernel.asm -lkernel.txt -f3 -v5 -okernel.bin) and the best I get is "START OF PASS: 1" before the program shuts down.
This is the latest version of DASM and I'm working on a Vista computer.  I have seen 'read the manual' but that's not included with this release.
Any ideas?
#2 vidak OFFLINE
vidak
    Moonsweeper
  • 458 posts
Posted Mon Jan 29, 2018 4:01 AM
I had a similar problem!
I think it's -v2 and not -v5
See Kirk Israel's beginner Atari 2600 programming guide.
#3 Fuselage OFFLINE
Fuselage
    Combat Commando
  • 4 posts
Posted Mon Jan 29, 2018 12:59 PM
Thanks for the reply.  This got me thinking that it couldn't be a parameter issue, since none of them should affect the execution of the assembler itself.
I went back and got an older version of DASM and that solved the issue.   :grin:
Edited by Fuselage, Mon Jan 29, 2018 1:03 PM.
#4 vidak OFFLINE
vidak
    Moonsweeper
  • 458 posts
Posted Mon Jan 29, 2018 6:35 PM
Ahhhh okay :)
