dragonfire cart won't work.
1 reply to this topic
#1 bradhig1 OFFLINE
bradhig1
    Dragonstomper
  • 781 posts
Posted Tue Jan 30, 2018 8:53 PM
I cleaned the contacts and it says turn power off before inserted cartridge or expansion module.    I have the black things on the circuit board in the cart facing the label is that the correct way the the board should be facing?
#2 rodge2001 OFFLINE
rodge2001
    Star Raider
  • 88 posts
Posted Fri Feb 2, 2018 4:22 PM
That should be correct; the black memory chips should face front/label side of cart which should face front of ColecoVision.  After full insertion, turn power on and then try slightly pulling cart out just a smidge and then hit reset to see if that works.  Might not be good for the system to do so while powered on but it can sometimes get a temperamental cart to work.
