GRAM & BASIC & VDP
59 replies to this topic
#51 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 536 posts
Posted Fri Feb 2, 2018 9:09 AM
It's a little like the PME, which can run Pascal, or rather p-code, from RAM, VDP RAM and GROM. Just pick your choice.
#52 mizapf OFFLINE
mizapf
  • 3,486 posts
Posted Fri Feb 2, 2018 3:03 PM
Here you go Michael. This was the whole disk archived.
There is a problem, as my TIMT tells me. Only the first four files can be read, all others result in "Archive truncated", including MSAVE/6.
#53 RickyDean OFFLINE
RickyDean
  • 1,022 posts
Posted Fri Feb 2, 2018 3:46 PM
Okay, I haven't tried your tool yet on arks,HFEs, and so forth, just on dsk images, sometimes. At least I know the problem is in the file. This was archived over 15 years ago, never tested as I was just trying to get alot of disks archived, to keep them useful far after the disks were worthless. I will search through some other storage devices I have, I know I have TI stuff from over 20+ years stored to in the GKUTILITIES.
#54 mizapf OFFLINE
mizapf
  • 3,486 posts
Posted Fri Feb 2, 2018 4:31 PM
Just to avoid confusion, I should add that TIMT cannot open ARKs directly because an ARK file is a file, not an image. HFE and DSK (v9t9 and pc99 style) are images. If you try, you'd have to import the ARK file to a (possibly new) disk image.
#55 arcadeshopper OFFLINE
arcadeshopper
  • 4,079 posts
Posted Fri Feb 2, 2018 5:00 PM
Yea, you know I should... EA GROM plus a ram chip, right? I need to find some instructions and source some components.
http://www.mainbyte....cart_4bank.html
I built this one, also Jim makes a supercart board so you don't have to sacrifice a munchman or ti invaders, if you need an extra of either game I have them in bulk.   I'm out of jim's boards but he's ordering more he says. my board I built with a ti-invaders board looks like frankenstien's monster and won't fit in a console :)  but it works fine on a widgit
Greg
#56 arcadeshopper OFFLINE
arcadeshopper
  • 4,079 posts
Posted Fri Feb 2, 2018 5:01 PM
also I have a gk and probably those utilities somewhere in my library if need arises
Greg
#57 Opry99er OFFLINE
Opry99er
  • 10,411 posts
Posted Fri Feb 2, 2018 5:21 PM
Awesome!!! Thanks Greg!
#58 Opry99er OFFLINE
Opry99er
  • 10,411 posts
Posted Fri Feb 2, 2018 5:23 PM
I know trev005 is the current owner of my former GK. I had all utilities for the GK, both MG and 3rd party... its possible that he may have digital copies of those made up. Ill measage him and see. :)
#59 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Fri Feb 2, 2018 8:15 PM
GKStuff has a utilities disk image and a binary file there too for some kind of conversion program.  PGRAM loader too.
GK.zip is the GK rom to use with MAME.
#60 FDOS OFFLINE
FDOS
    Chopper Commander
  • 246 posts
Posted Tue Feb 20, 2018 7:22 PM
Awesome! The first test will be to determine if we can break out of a BASIC program while it is in the module space.
Test #1:
Step #1: Write a BASIC program, use MSAVE6 to save it to GRAM 3
Step #2: Save module to disk (make sure no cartridges are inserted into the GRAM Kracker when you do this)
Step #3: Completely shut down your system, then start up and INIT your module space on the GRAM Kracker to make sure it is clean.
Step #4: LOAD the module from disk that you saved earlier. This will put the BASIC program in module space, cleanly, with no residuals of our previous efforts. We will know that the VDP contains no BASIC code at this point
Step #5: Run the module from the title selection screen. While running, try a FCTN+4 break of the program.
Step #6: If you were allowed to break out of the program, type LIST.
Then report your results here. :)
Owen. I just came across this topic.  I can probably provide all the info you need for running TI Basic programs in GROM/GRAM space, as I've been doing this for many years new.  I'm also just about ready to open the new topic on TI BASIC Plus (TIB+) which depends heavily on GK MSAVE & MSAVE6 for 80K/56K GramKracker, HSGPL & FG99.  i also have found most all of my emails about the progress and difficulties encountered during the early development.  Do you want to do this here or on the TIB+ topic?  I had to modify the objectives document For MSAVE & BCART, buti I think I will have to do it again, as It's pretty confusing without doing it for each type of TI environment; CF7+/NanoPEB, Mini Memory, Editor Assembler, Winfried Winkler enhanced Assembler & Editor, and standard PEB peripherals.  I'll know based on comments.
