800XL Audio volume
800XL
5 replies to this topic
#1 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 240 posts
Posted Thu Feb 8, 2018 7:35 PM
I have an 800XL that suddenly is having audio problems.  The volume will be OK for a few minutes then will go almost completely out.  The problem occurs only with the monitor cable.  The RF audio output seems to be constant.  Any ideas about where I could start trouble shooting.
#2 DrVenkman OFFLINE
DrVenkman
  • 3,710 posts
  • Back off, man! I'm a scientist.
Posted Thu Feb 8, 2018 7:38 PM
Have you swapped monitor cables? I have one with a breaking/broken audio wire; I have to wiggle the wire around the base of the strain relief housing where it flows into the DIN plug to get audio. Fortunately, I have other cables.
#3 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 240 posts
Posted Thu Feb 8, 2018 8:07 PM
I have used two different cables on two different monitors.
#4 DrVenkman OFFLINE
DrVenkman
  • 3,710 posts
Posted Thu Feb 8, 2018 8:12 PM
Start working your way back - have you checked the solder points of the DIN jack on the computer motherboard? Do that, and if you have a soldering iron, reflow the solder for all the pins while youre at it. Then do a continuity check back from there, component by component, back along the audio line.
#5 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,246 posts
Posted Thu Feb 8, 2018 9:12 PM
I had a bad cord, the cord got wiggled enough times to 'make the sound work' that it worked the jack in the monitor loose. I had to replace the cord and re-solder the rca jack.
other than that I've had to replace the amp on at least two Atari's over all these years...
#6 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 240 posts
Posted Wed Feb 14, 2018 10:06 AM
It seems that I had two bad cords. Probably have to recheck the solder connections.
Also tagged with one or more of these keywords: 800XL
