Any ESD suppressors for 8-bit controller ports?
3 replies to this topic
#1 Swami ONLINE
Swami
  • 2,373 posts
Posted Mon Feb 12, 2018 7:30 PM
I live in Minnesota where you can count the percent humidity on one hand in the winter. Are there any ESD suppressors for the Dsub connectors on 8-bit computers and consoles? I saw this, but I imagine the flow is backwards on some pins. Maybe just invest in a large humidifier?
https://www.ebay.com...3.c100705.m4780
#2 citrus3000psi OFFLINE
citrus3000psi
    Space Invader
  • 45 posts
Posted Tue Feb 13, 2018 9:11 AM
I don't know of any machines built in, but It would be pretty easy to add them in on the controller side.  They are referred to as TVS Diodes.
#3 Swami ONLINE
Swami
  • 2,373 posts
Posted Wed Feb 14, 2018 1:41 PM
Thanks. Should work for Ataris. I think we're probably SOL on ColecoVision and maybe Segas, which I believe have two grounds depending on state (e.g., for CV state 1 is joystick, left button and pin 8 as ground, state 2 is keypad and right button with pin 5 as ground). Although, you could use one on the CV steering wheel which only uses state 1.
#4 Swami ONLINE
Swami
  • 2,373 posts
Posted Sun Feb 18, 2018 11:44 PM
This one works well. No problems. Data Shield DB9 surge protector. These are a little pricey. Watch for a deal for $10 or so.
https://www.ebay.com...lgAAOSw23NZndPT
This one causes both fire buttons to work at once with fire 1 (L button), for some reason. B&B DB9 surge protector. You also have to do a lot of hacking away to remove bits that interfere with plugging the cable in. With the Data shield, you just have to unscrew the dealies on the sides. BTW, this ad has them for $45 a piece (not for 4). I paid $11 for mine.
https://www.ebay.com...voAAOSw5cNYLbbF
