easmith Posted February 13, 2018 Share Posted February 13, 2018 (edited) This was buried in my previous thread , so I thought I would start a new one... One question I never asked was this :Incrementing x or y position of enemy 1 pixel/scanline per frame creates the relatively slow movement in waves 1 and 2 of my game. In wave 3 to 8 , the movement is 2 pixel/scanline per frame ( at least in one direction), and this is quite an abrupt ramp up in speed.I tried moving one pixel , then moving two , then one, or waiting a frame ,but that just created jerky movement .Are there any tricks for more finely controlling speed of movement ? Specifically, something in between my two speeds . With other processors you can just add a delay ( like nops) at the end of the program loop, but here you have to keep up with TV picture.... Surely there are games with AI movements that are between 1 and 2 pixels per frame. I am certainly missing something obvious. Edited February 13, 2018 by easmith Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 13, 2018 Share Posted February 13, 2018 search on fractional or subpixel https://alienbill.com/2600/cookbook/subpixel.html 1 Quote Link to comment Share on other sites More sharing options...
easmith Posted February 15, 2018 Author Share Posted February 15, 2018 (edited) search on fractional or subpixel https://alienbill.com/2600/cookbook/subpixel.html But how does this affect positioning routine? The positioning routine I am using is from Collect I believe, and loops through bytes which are in order xp1, xp0 to position p1 and p0 . now that my p1 x is two bytes , how should I adjust? Is it just using the integer byte for x positioning ? This seems to work for controlling speed a bit , but I have a jitter again now in my enemy movement when they are near the left side of screen .Perhaps it is something else causing the jitter, my cycles must be off . Edited February 15, 2018 by easmith Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 15, 2018 Share Posted February 15, 2018 You don't have to keep the 2 bytes next to each other. Instead of changing ObjectX: ds 5 ; player0, player1, missile0, missile1, ball to this: ObjectX: ds 10 ; player0, player1, missile0, missile1, ball you could change it to this: ObjectXlow: ds 5 ; player0, player1, missile0, missile1, ball - FRACTIONAL part of position ObjectXhigh: ds 5 ; player0, player1, missile0, missile1, ball - INTEGER part of position then your position object routine becomes: PositionObjects: ldx #4 ; position all objects POloop lda ObjectXhigh,x ; get the object X position jsr PosObject ; set coarse X position and fine-tune amount dex ; DEcrement X bpl POloop ; Branch PLus so we position all objects sta WSYNC ; wait for end of scanline sta HMOVE ; use fine-tune values to set final X positions Quote Link to comment Share on other sites More sharing options...
easmith Posted February 15, 2018 Author Share Posted February 15, 2018 ok that did it. Since I am only positioning 2 objects and only one fractional, I was able to define XPosPlayer .byte XPosAhigh .byte XPosAlow . byte in that order and the routine works. Quote Link to comment Share on other sites More sharing options...
