Atari 800 S-Video Problem
800 video s-video problem
7 replies to this topic
#1 thom0707 OFFLINE
thom0707
    Combat Commando
  • 2 posts
Posted Sat Feb 17, 2018 8:43 AM
Hello,
I'm looking to solve an issue I am having with my Atari 800.
I bought an S-Video cable years ago off of eBay.  It produces crisp video on my Atari 800, but the colors seem off.  Additionally, bright colors seem to produce a ghosting effect.  Please see my attached screenshot of River Raid.  I'll also include a screenshot of Basic to show how characters look (A, M, N, and W in particular).
Any thoughts on what the problem is?  With an RCA cable, I don't get the ghosting effect, but the colors still seem off.  I have an 800XL and the colors look fine with this cable.  It's been years since I've used these systems, and I never looked closely at the video output until now.
EDIT: In Basic, lowering the luminance of the text seems to help with the ghosting issue.  Is there any way I can fix this at a hardware level?
Thanks in advance!
Edited by thom0707, Sat Feb 17, 2018 8:53 AM.
#2 _The Doctor__ OFFLINE
_The Doctor__
  • 4,467 posts
Posted Sat Feb 17, 2018 11:01 AM
Try a different cable, a different CRT, I had a toshiba that did that, it needed a bit of work, the bleeding and tearing was evident on television, and recording as well. Wasn't the computer at all.
https://www.repairfa...g/sam/tvfaq.htm
http://www.e-repair.co.uk/tips.htm
If you find it's present from other sources hooked up to it, you may have delve into the set/monitor itself, be protected insulated and keep one hand out using fiberglass or plastic tools, check voltages and caps, this requires discharging everything inside the crt to be safe.
Eliminating those items it's time to dig into other causes.
Edited by _The Doctor__, Sat Feb 17, 2018 11:23 AM.
#3 1050 OFFLINE
1050
    Dragonstomper
  • 993 posts
Posted Sat Feb 17, 2018 6:51 PM
Sure, you can construct a resistor network to cut
back on the level of luminance and/or chroma both.
Some insist on a 75 ohm resistor in line to 'match'
impedance to the TV/monitor but this is misapplied
#Fake News nonsense for RCA type connections in the
first place. Make it to be what works but understand
that it's probably only going to work with that
computer and that monitor both. Change one or the
other and the problem may show back up and in reverse
this time. 75 ohm inline wouldn't be a bad place to
start either. Which doesn't help any with the repeated
rumor that it's the only proper fix.
It's well known that the output levels of these
computers is quite variable, one is way to hot on
luminance and the next has chroma just a screaming.
Thanks in advance!
Most welcome - it's what we do.
#4 JR> OFFLINE
JR>
    Moonsweeper
  • 274 posts
Posted Sat Feb 17, 2018 9:05 PM
Could the color differences be due to CTIA vs. GTIA? Do you know which chip your 800 has?
#5 BillC OFFLINE
BillC
  • 1,801 posts
Posted Sun Feb 18, 2018 1:36 AM
I don't remember any color difference between the CTIA & GTIA, but is has been over 30 years since I have had a CTIA. The GTIA does have more video modes.
The color on the Atari computers can be adjusted via a potentiometer.
On the 800 this potentiometer is on the CPU card, and can be adjusted through a hole on the back of the RF shield when the cover for the RAM/OS card bay is removed.
#6 thom0707 OFFLINE
thom0707
    Combat Commando
  • 2 posts
Posted Sun Feb 18, 2018 6:42 PM
I found an another screen with an S-Video input.  I didn't see the "ghosting" issue as much, but the discoloration was the same.  My SNES seems to produce proper colors via S-Video.
I'm not sure.  How can I find out?
I'll see if adjusting that potentiometer helps.  If so, I'll post before and after pictures.
Thanks!
#7 1050 OFFLINE
1050
    Dragonstomper
  • 993 posts
Posted Sun Feb 18, 2018 7:33 PM
I'm thinking by the part number on it.
https://www.atarimax...rg/achgtia.html
When using google for our beloved Atari, I find it
best to include Atari in the search term to cut
down on worthless hits, but really CTIA wasn't hard
to search for...
http://www.atarimani...uments_3_8.html
http://www.atarimani...0-xl-xe-_8.html
#8 JR> OFFLINE
JR>
    Moonsweeper
  • 274 posts
Posted Sun Feb 18, 2018 11:31 PM
A few methods are mentioned in this thread.... http://atariage.com/...test for ctia
Also tagged with one or more of these keywords: 800, video, s-video, problem
