FastBasic - Summer Release
basic compiler interpreter ide
104 replies to this topic
#101 dmsc ONLINE
dmsc
    Moonsweeper
  • 478 posts
Posted Thu Jan 10, 2019 9:41 PM
Hi!
Hello,
So, I'm a little lost.
How much free memory fastbasic provides ?
Cheers
Devwebcl
Booting the FastBasic 3.5 atr disk, loading FBI.com, entering PRINT FRE() in the editor, then pressing CTRL-R to parse/compile/execute shows 30755 after that tiny bit of code. When compiling as an executable to disk, the FRE() amount will be less (around 2K less or so) bc of the inclusion of the runtime. Using FB.COM the above sample will yield about 29467.
dsmc has done a fantastic job with his BASIC.
Yes, in the IDE you have about 31200 bytes free at the start, this will be used by the program source (in the editor) and the compiled code.
But, if you compile the program to disk (pressing CONTROL-W on the ide) you have about 37600 bytes free, because you don't have the compiler, editor and source in memory, only your program code and runtime.
And finally, if you compile with the cross compiler (from a PC), you will have more free memory because the cross compiler includes only the parts of the runtime that are used.
#102 777ismyname OFFLINE
777ismyname
    Star Raider
  • 70 posts
Posted Fri Jan 11, 2019 2:41 AM
I had no clue there was a cross compiler...I must check this out! You have developed a fantastic piece of software.
Hi!
Sent from my ASUS PadFone X using Tapatalk
#103 tebe OFFLINE
tebe
    Dragonstomper
  • 786 posts
Posted Tue Jan 15, 2019 5:48 AM
curiosity COMAL-80, still in use
https://en.wikipedia.org/wiki/COMAL
#104 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,272 posts
Posted Wed Jan 16, 2019 12:00 AM
but alas not on any Atari save possibly Amiga?
#105 dmsc ONLINE
dmsc
    Moonsweeper
  • 478 posts
Posted Wed Jan 16, 2019 2:25 PM
Hi!
Well, almost all "extended" BASICs for the Atari are really similar to COMAL, as the keywords are an extension to the BASIC ones, like "PROC/EXEC", "WHILE", "REPEAT", "IF/ELSE/ELIF/ENDIF", etc. Main difference is the ":=" for assignment in COMAL instead of "=" in BASIC.
Comparing FastBasic and COMAL, I think the main differences are:
- COMAL allows line numbers (but only as an editor facility)
- COMAL has procedure parameters. I did not add procedure parameters to FastBasic (yet) as my goal was 8kB for the integer version.
- FastBasic does not have GOTO, COMAL allows GOTO to labels. Adding GOTO to FastBasic is really complicated, as you have to unroll the stack to jump from inside a FOR or PROC to outside, and I don't like needing "POP" (like Atari BASIC) to fix the stack.
- FastBasic does not have CASE/WHEN. I don't think this is that useful a feature, as the same can be written with "IF/ELIF".
- FastBasic uses the Atari I/O statements (OPEN with numeric arguments and IOCB number).
I tend to see COMAL as another step in the evolution from the classic BASICs of the '60 to the advanced BASICs of the '90 like QuickBasic.
Also tagged with one or more of these keywords: basic, compiler, interpreter, ide
