This is the law..... ahem v2.2
23 replies to this topic
#1 marc.hull OFFLINE
marc.hull
  • 1,275 posts
Posted Wed Feb 21, 2018 6:29 PM
I keep seeing people posting about v2.2 consoles and going round and round and round so I thought I would f* everybody up with some knowlege ( Eb and D joke so don't get butt hurt yet.) If I get something screwed up then feel free to set me straight but the following is correct as I see it.
V2.2 as used correctly does not apply to the console or motherboard with 1 exception (later.) It only applies to the particular iteration of part of the OS contained in GROM 0.
This GROM can exist in a beige or black console as well as in an original or QI motherboard. It may have been factory installed or added later by someone (or replaced by an original GROM 0 by the same or other someone.)
There are two types of plastic console cases. Black and beige-ish. If you have one of these it simply means your plastic is either black or ish. Nothing more.
Inside the case will be the MOBO. This MOBO may either be one of several iterations of the original or a redesigned QI (read this term as cost savings/ evolution) MOBO. At any rate this MOBO is not a v2.2 item anymore than the plastic is.
So what the hell makes a v2.2 console (this is the later part) ? At this point only the presence of the correct GROM 0. I am sure there was QI plastic shipped with QI MOBOs that contained the correct GROM zero and I guess these would be considered v2.2 consoles. Don't know how you would tell now though as all the parts were completely interchangable. 30 years later the untold doings have made this virtually impossible to determine (with few exceptions.)
Now the question becomes this. Since the v2.2 grom did nothing but restrict access to the console, why would anyone want one other to complete the set.
#2 save2600 OFFLINE
save2600
  • 15,105 posts
Posted Wed Feb 21, 2018 6:42 PM
Variants? See the Intellivision forum for further study...
#3 OLD CS1 OFFLINE
OLD CS1
  • 5,323 posts
  • Technology Samurai
Because it's there.
#4 atrax27407 OFFLINE
atrax27407
  • 1,013 posts
Posted Wed Feb 21, 2018 6:52 PM
I don't have any GROMs in my console(s). I am using the GROM0 that was done for me by "The Great Gazoo" many years ago for my HSGPL system. I guess that would make my system a 3.0 :)
#5 Casey OFFLINE
Casey
    Moonsweeper
  • 259 posts
Posted Wed Feb 21, 2018 7:09 PM
I think you've answered the question as you've asked it.  I want one because I want one.  I don't have to have any reason other than that.  Was there another reason for your post?
Edited by Casey, Wed Feb 21, 2018 7:09 PM.
#6 digdugnate OFFLINE
digdugnate
  • 1,473 posts
Posted Wed Feb 21, 2018 7:12 PM
/munches popcorn
#7 marc.hull OFFLINE
marc.hull
  • 1,275 posts
Posted Wed Feb 21, 2018 7:21 PM
Don't know who you are or care what you want. Wasn't directed at you or anyone else so take a breath and step off.
I saw a lot of misunderstanding and offered my two cents. That was the reason for my post.
#8 Casey OFFLINE
Casey
    Moonsweeper
  • 259 posts
Posted Wed Feb 21, 2018 7:28 PM
I think most people in these parts probably know what makes a V2.2 console a V2.2 console.  I though perhaps you were reacting to my question about when they were produced in the Ebay thread because I have been trying to find one based on the LTA date code, and I assumed a late 1983 build code or a 1984 build code would increase the odds that it'd be a V2.2 console.  If your question then is "why would anyone want one?" after listing out the deficiencies of one compared to the non-V2.2 models, the real answer must be either to complete a set, or just to have one because it exists, which you already stated in your post.  Hence, my question - not here to rough you up.
#9 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Feb 21, 2018 7:46 PM
Good info, Marc. :)
Begs the question: who has a black console with a v2.2 GROM0?
#10 marc.hull OFFLINE
marc.hull
  • 1,275 posts
Posted Wed Feb 21, 2018 7:52 PM
You can't rough me up so don't worry.
Would you be interested in a black and silver console with and original MOBO that was v2.2 ?
#11 acadiel OFFLINE
acadiel
  • 1,404 posts
  • www.hexbus.com
Posted Wed Feb 21, 2018 8:17 PM
Thanks, Marc. There was a lot of disinformation around about V2.2 Os = QI motherboard, and that wasn’t really true.
#12 Retrospect OFFLINE
Retrospect
  • 1,017 posts
Posted Wed Feb 21, 2018 8:42 PM
Are TI-99's after 1983 a bit like the C64 in the way that you don't know what you're getting inside unless you look? The 64C was always a mixed bag of old motherboards/new motherboards, crappy sids (new sid) and better sids (old sid).
#13 save2600 OFFLINE
save2600
  • 15,105 posts
Posted Wed Feb 21, 2018 8:50 PM
No. Most of us don't concern ourselves with that stuff.
#14 helocast OFFLINE
helocast
    Chopper Commander
  • 165 posts
Posted Wed Feb 21, 2018 8:51 PM
Good info, Marc. :)
#11 in my personal queue has a week/year code of LTA5084 (black console, standard MB), but I haven't cracked the case for troubleshooting/refurbishing, let alone yet to see what GROM 0 is installed. A date that late is either a mis-strike or whoever ended up with final inventory assembling down to the last screen in the assembly line parts box. Slightly backed up recently with some new hardware that's distracted me
#15 marc.hull OFFLINE
marc.hull
  • 1,275 posts
Posted Wed Feb 21, 2018 9:00 PM
Pretty much spot on retro. What any business would do.
#16 OLD CS1 OFFLINE
OLD CS1
  • 5,323 posts
Posted Wed Feb 21, 2018 9:32 PM
Not too much these days, it seems, but I remember at the time there were two distinct camps: those who absolutely wanted the Revision E motherboard (the full 64C half-board with the 8580 SID et al) and those who absolutely did not want it.  The latter really looking for what was essentially a factory rendition of the bread-board in the upgrade case.
#17 save2600 OFFLINE
save2600
  • 15,105 posts
Posted Wed Feb 21, 2018 9:42 PM
No, you misunderstood or took out of context my response... was replying to the primary question. We TI people do not and don't need to concern ourselves with such shit. C64 is a totally different story.
The 2.2 rev. mobo for us TI'ers is a relatively trivial thing comparatively. ;)
#18 Retrospect OFFLINE
Retrospect
  • 1,017 posts
Posted Wed Feb 21, 2018 10:29 PM
I was using the C64 as an example of how TI would have put odds n sods in later computers. Old boards/new boards etc. Just like they did.
#19 OLD CS1 OFFLINE
OLD CS1
  • 5,323 posts
Indeed.  Yeah, for the most part it is irrelevant whether we have a "QI" or one of the standard iterations unless, and until Ralph fixes the issue, you are trying to use a FG99 :)  Although, the coffee warmer is significantly cooler on a "QI" console.  When I was able to empirically prove my retro-desk console (a beige console with "QI" motherboard) had problems with the FG99, I swapped around parts until I had a console with a standard motherboard and a "QI" power supply.  This was also when I discovered there is a molding difference in the cartridge slot support for use with a "QI" motherboard.
While the v2.2 OS is a curiosity for me it will also make a demonstration piece.  I have a beige one now which does not work but I hope to fix, and it would be rather neat to find a black-silver console, as well.  See, I was also of the misunderstanding that only the beige consoles came in a v2.2 flavor, but somewhere in mind memories I swear I had seen a black-silver one, as well.  Marc confirmed that memory for me.
#20 OLD CS1 OFFLINE
OLD CS1
  • 5,323 posts
Posted Wed Feb 21, 2018 10:38 PM
As a for-instance, I recently came to know some of the 64C short-boards (non-Rev E, I think they are a later Rev B) were actually made with variant of the 6581 SID, and some 64Cs were made with the large bread-board boards and were not case upgrades.  1986-ish to 1988-ish a 64C was definitely a mixed bag :)
You know, there could be a market there: reclaimed black-silver console shells for those who want to upgrade their beige ones!
#21 Ksarul ONLINE
Ksarul
  • 4,678 posts
Posted Thu Feb 22, 2018 8:11 PM
@Helocast, a date of 5084 is definitely an oddity/misprint. Someone probably reversed the first two numbers. The last US consoles were made in May of 1984--and they were the ones TI built for Control Data. The last TI-badged consoles were supposedly from the end of April 1984 (weeks 16-18 of 1984, although I may have seen one or two from week 19 over the years). Of course, the Argentine consoles were assembled as late as 1986, so there are later consoles out there. I've never seen a definitive end date for consoles manufactured in Europe, so some additional research is necessary there.
#22 helocast OFFLINE
helocast
    Chopper Commander
  • 165 posts
Posted Thu Feb 22, 2018 9:53 PM
Thanks, we had this discussion before, but I couldn't find our conversation to include in the previous post.
I took the time last night to "check it out". Broke it down; nothing strange popped out at me - standard MB, GROMS, sound, latest of the many keyboard builders (Mexico).
I'm stumped too.
Doug
#23 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,325 posts
Posted Fri Feb 23, 2018 4:10 PM
For those with yellowing beige TI's... the official cheese grading scale!  ;)
#24 acadiel OFFLINE
acadiel
  • 1,404 posts
  • www.hexbus.com
Posted Fri Feb 23, 2018 4:41 PM
CD2155ANL - which I think might be GROM 0 - it's funny when you can buy lots of those from China.
https://www.aliexpre...2535795059.html
Someone in the US has over 2000 of them:  https://www.netcompo.../CD2155ANL.html
There is a nice page of what the CD #'s of the chips were in certain carts: http://www.webalice.it/facele/ti99.htm
