CFFA3000 PREORDERS OPEN AS OF 3PM TODAY!
60 replies to this topic
#51 Polymorph OFFLINE
Polymorph
    Space Invader
  • 45 posts
Posted Thu Apr 19, 2018 4:33 PM
The one thing where I think the Floppy Emu has an advantage is in games that require a lot of disk flipping. I was trying to play Competition Karate the other night (one of my favorites from my youth) and it was *torture* on the CFFA3000. Maybe there's some shortcut that I don't know about, but it seems like the only way to "flip" a disk in the CFFA3000 is to cmd-shift-esc, select the CFFA3000, select "assign disk II volumes", select side 2 of the disk, select drive 1, then esc, select quit without rebooting, and select quit from the control panel menu to get back to the game. That's a pain in the ass to do even once, and Competition Karate and some other games like it require you to do it over and over.
This was annoying but not such a hassle with an actual physical disk. It was a lot quicker.
Some games also don't let you get into the control panel menu to select the CFFA3000 to eject the disk. I'm not sure what to do in those situations.
With the Floppy Emu, I think this same thing is accomplished with 2 or maybe 3 button presses. It's been a while since I used mine, but I'm pretty sure you just press a button to eject the first side image, then select the second side image from the list (which should be just below it, unless you have some crazy naming scheme). In this case, it's an advantage to have an external device with its own screen and controls.
Again, please do tell me if there's some shortcut way of doing this on the CFFA3000, because I've decided I just can't play games like Competition Karate with this card otherwise. It's too painful.
In other situations, though, you're right that the CFFA3000 is a better experience than the Floppy Emu. I still think the Floppy Emu is a great device, though.
This is what the CFFA3000 remote switch is intended for. If you add each disk to the Disk ][ assignment screen, you can cycle to the next disk by pressing the respective button on the remote. So  advancing to the next disk (in a set of disks) usually requires only one push of a button.
#52 spacecadet OFFLINE
spacecadet
  • 2,972 posts
Posted Thu Apr 19, 2018 6:07 PM
I thought the remote only let you switch between disk 1 and disk 2 (that's what's printed on the buttons). I confess I never really understood what the remote was really useful for, and everybody says it's not necessary on the IIGS because you have menu access. Will it really let you switch to a different image in the *same* drive with the click of a button? That's what it does?
(Actually back and forth between two images, not just to the next image in the list.)
Edited by spacecadet, Thu Apr 19, 2018 6:08 PM.
#53 Polymorph OFFLINE
Polymorph
    Space Invader
  • 45 posts
Posted Thu Apr 19, 2018 7:43 PM
I must confess to not using my remote very often - but from what I remember you can load multiple disk images for drive 1 and 2 and pressing the drive 1 button will switch to the next image in the list for drive 1, and vice-versa for drive 2.
#54 Arnuphis OFFLINE
Arnuphis
    Moonsweeper
  • 360 posts
  • Loading...Please Wait
Posted Thu Apr 19, 2018 10:13 PM
My two cards arrived today. Will be a fun weekend with the IIe and IIGs!
#55 spacecadet OFFLINE
spacecadet
  • 2,972 posts
Posted Fri Apr 20, 2018 11:58 AM
Ok I'll try it out. I'm still a little worried about the "next image in the list", because I need to go back and forth between two images (meaning backwards too). But maybe if I just make individual folders for games that require this with only two images in the folder, it'll just go back to the top of the list and work that way.
I have a remote but didn't bother hooking it up because I didn't see the point initially. But if it'll do this, then it's definitely worth having.
#56 david__schmidt OFFLINE
david__schmidt
    Chopper Commander
  • 163 posts
Posted Fri Apr 20, 2018 1:26 PM
Take a look at page 7 of your Fine Manual (Figure 1: Selecting "Disk II Assignments" from the menu.).  You can pick a set of disks to cycle through on drive 1, and a (potentially different) set of disks to cycle through on drive 2.  That's what "Drive1" and "Drive 2" mean on your push buttons - "Drive 1" cycles through disks on the drive 1 list, and "Drive 2" cycles through disks on the drive 2 list.  Folder membership doesn't mean anything - images can be assigned wherever they are on your USB or CF media.  Only membership that you pre-populate on that configuration screen matters.
#57 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,848 posts
Posted Fri Apr 20, 2018 2:48 PM
TimeZone!
#58 spacecadet OFFLINE
spacecadet
  • 2,972 posts
Posted Fri Apr 20, 2018 3:16 PM
Ooooh thanks. Yeah I couldn't really figure out the point of having multiple images assigned to the same drive either. That makes a lot of sense.
I don't know why some people say (and I think Rich even says, somewhere, either on his site or in the manual) that the remote isn't useful for the IIGS. It most certainly is if it'll do this!
#59 Arnuphis OFFLINE
Arnuphis
    Moonsweeper
  • 360 posts
Posted Sun Apr 22, 2018 9:16 AM
Well on the IIGS you can just jump back into the CFFA menu and change disks there but a clicky button is very useful.
#60 sm3 OFFLINE
sm3
    Dragonstomper
  • 635 posts
Posted Sat Apr 28, 2018 5:36 PM
It seems R&D found a way to build some additional cards from spare parts from the previous run. He's allowing you to order an additional 2 boards if you have the need.
http://dreher.net/?s...ppleII/main.php
#61 Zap! OFFLINE
Zap!
  • 1,761 posts
Posted Wed Nov 7, 2018 9:21 PM
I ordered mine a few days ago. I was pleasantly surprised to see that they were still available!
Reply to this topic
