dabone Posted February 25, 2018 Share Posted February 25, 2018 I'm working on a unit with a single horizontal line, and checking voltages, I have no ground on the CD4066 @ IC305 and the MC34004 @ IC303.Any suggestions to start with? Thanks. Later, dabone Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted February 26, 2018 Share Posted February 26, 2018 Does it make sound, etc.? Quote Link to comment Share on other sites More sharing options...
dabone Posted February 28, 2018 Author Share Posted February 28, 2018 Yes, movement on the line, and sound. Just missing ground on part of the main board. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 1, 2018 Share Posted March 1, 2018 Yikes...with the monitor being vertical mounted I'm guessing that is a vertical collapse condition then. Not sure right off hand but I would guess an IC somewhere in the Veccy is responsible. Although I did have an arcade monitor with a similar condition and it was an issue with the tube's actual deflection being the problem and I ended up having to replace that tube out since it kept blowing chassis boards all the time. Not saying that is the case here, but just my experience with something similar. Quote Link to comment Share on other sites More sharing options...
dabone Posted April 13, 2018 Author Share Posted April 13, 2018 Ok, I was chasing the wrong thing with the ground issue. Didn't realize that that section used a different voltage. I found this on the web... "You can also get a slightly different display if only the Y-axis side of the LM379 has failed. In this case you still get normal sound. The display will show a single raster line centered vertically on the screen. In other words you will only see a single line reaching from the right to left side of the screen. Typically this line will have 'dancing dots' on it as objects are being drawn to the screen. You get this display instead of the blank picture as before due to the deflection detection circuits that enable J-FET's 401 and 402 are only taking their sense signal from the horizontal deflection. " So, I ordered a nos lm379s from ebay along with a cap kit, replaced both, and now I have this display instead of the single flat line. Any thoughts? I'm wondering if the lm379 I got was wrong. Thanks. Quote Link to comment Share on other sites More sharing options...
