some guidance, stuck with masked sprites
zilog_z80a
Hi, i'm really stuck with this subject. can't find a simple kernel where masked graphics are set.
i mean animated ones, can't find really really, i can't, may be i'm not looking at the right place?
google may be not showing good results or i'm doing perhaps the search with the wrong words?
donno.... i will love to know how to set up masked graphics pointers in two simple scenarios.
127 1LK
AND
127 2LK
please, there are some examples but can't understand the kernel context.
if somebody helps will be the push i need to try my first kernel.
ty in advance.
cheers.
PS: I DON'T CARE IF IS AN EXAMPLE WITH A DIFFERENT KERNEL HEIGHT, JUST HELP.
Edited by zilog_z80a
Don't have time to comment it for you. If the code isn't self explanatory, feel free to ask some follow up questions. I left out some optimizations for the sake of reduced complexity, if you intend to have a single kernel for the entire screen the mask could be reduced to 256 bytes.
mask_draw_demo.asm
mask_draw_demo.bin
attachicon.gifmask_draw_demo.asm
attachicon.gifmask_draw_demo.bin
Thank you very much for the code ZackAttack!!,
i wanna do an asymmetrical playfield with six writes to PFX and two writes to GRPX per line in a 2LK, monochrome sprites.
with your info once i have understood all.... then will try to implement this in Darrell Spice's 2LK Playfield found in COLLECT.
this is what i was looking, i found it in other code but i was needing what you did a...... THIS IS ALL YOU NEED AND CLEAR.
ScanLoop
LDA (pGraphics),y
AND (pMask),y
STA GRP0
DEY
STA WSYNC
BNE ScanLoop
not now.... but i think will need a bankswitching (ram/rom both) scheme,
was looking them, but still looking cos will use MASKED SPRITES for all so i suspect that will need more ram and rom
step by step, for now i will take a look at your code.
ty again ZackAttack!! cheers!
Happy to help. Just for fun I went ahead and optimized for the 1LK variant. The mask only takes 256 bytes because it exploits the natural wrap around of the 8 bit Y register. Keeping everything aligned properly is critical to avoiding a 1 cycle penalty for crossing pages. So the net is a couple bytes of RAM, 150 bytes of ROM, and 2 cycles during the kernel.
Of course a 2LK will consume much less ROM space for mask and graphics and single colored sprites would save a bunch of resources too.
mask_draw_demo.asm
wow, i'm learning the code from the first mask_draw_demo.asm
about SPRITE... there is some kind of POINTERS OF POINTERS ARRAY OF POINTERS
ZackaAttack, about memory space at $80.... this means.....
FrameCount: DC.B ; always gonna be a byte?
P0y: DC.B ; always gonna be a byte?
pGraphics: DC.W ; always gonna be a word?
pColors: DC.W ; always gonna be a word?
pMask: DC.W ; always gonna be a word?
AM I RIGHT?
will continue reading. ty.
cheers.
sorry i'm losing my brain lol
isn't a sprite 8 bits long per slice? this sprite is 11 bits per slice!!
bump :-o
i'm trying to compile the first mask_draw_demo.asm and there is an error about labels that i cannot solve.
have changed the labels name but still can't compile.
I'm not sure what you mean by slice. Atari doesn't have the notion of sprites built in. It keeps drawing the 8 bit wide player graphic every line. So you create a sprite by changing the GRP0 register each line, or every other line in 2lk. The height is controlled by the software you can make the Sprite as tall as the screen if you want.
hi, i mean not height,
i mean width, is 11 bits wide the sprite in the source code you post first
eg
MegaMan_RunF03:
BYTE %00000111100 ; <----- is not an 8 bit limit here? :(
BYTE %00000110000
BYTE %01010111000
BYTE %01110110000
BYTE %00101100000
BYTE %11001110110
BYTE %11011110111
BYTE %01110000011
BYTE %00001111000
BYTE %00001000100
BYTE %00011111110
BYTE %00011001010
BYTE %00001001010
BYTE %00111111110
BYTE %00111110010
BYTE %00011100100
BYTE %00001001000
BYTE %00000000000
another thing is that source code gives me this error
--- End of Symbol List.
mask_draw_demo.asm (124): error: Label mismatch...
--> MegaMan_Color f217
mask_draw_demo.asm (127): error: Label mismatch...
--> MegaMan_Run_LowBytes f229
mask_draw_demo.asm (133): error: Label mismatch...
--> MegaMan_Run_HighBytes f22d
mask_draw_demo.asm (140): error: Label mismatch...
--> MegaMan_RunF01 f231
mask_draw_demo.asm (160): error: Label mismatch...
--> MegaMan_RunF02 f243
mask_draw_demo.asm (180): error: Label mismatch...
--> MegaMan_RunF03 f255
mask_draw_demo.asm (200): error: Label mismatch...
--> MegaMan_RunF04 f267
Unrecoverable error(s) in pass, aborting assembly!
Complete.
dasm treats all numbers as 32 bit values. When outputting for byte it only uses the lowest 8 bits, so the left 3 bits are lost. You can see how that works if you generating a listing using dasm's -l option.
mask_draw_demo.asm (120): error: Label mismatch...
 --> MegaMan_RunF01 f200
    120  f300        00 00 00 00*MegaMan_RunF01 ALIGN 256
    121  f300        1e       BYTE.b %00000011110
    122  f301        18       BYTE.b %00000011000
    123  f302        9c       BYTE.b %10110011100
    124  f303        b8       BYTE.b %11110111000
    125  f304        c0       BYTE.b %01011000000
    126  f305        bf       BYTE.b %00010111111
    127  f306        7f       BYTE.b %11001111111
    128  f307        43       BYTE.b %11101000011
    129  f308        38       BYTE.b %00000111000
    130  f309        44       BYTE.b %00001000100
    131  f30a        fe       BYTE.b %00011111110
    132  f30b        ca       BYTE.b %00011001010
    133  f30c        4a       BYTE.b %00001001010
    134  f30d        fe       BYTE.b %00111111110
    135  f30e        f2       BYTE.b %00111110010
    136  f30f        e4       BYTE.b %00011100100
    137  f310        48       BYTE.b %00001001000
    138  f311        00       BYTE.b %00000000000
The label mismatch means something moved during the compile process - first time it evaluated MegaMan_RunF01 it ended up at $F200 in the ROM, but on this last pass it ended up at $F300 for some reason. I took a quick look, but didn't see the source of the shift.
Hi Darrell, ok just 8 bits are read.
i`m lost again with this is like a naightmare lol
ty. with the rest of errors i'm lost sorry.
Darrell there are two mask_draw_demo.asm
i`m looking the first.
Looking at dasm.txt, the manual for dasm:
PSEUDOPS:
[label] DC[.BWL]    exp,exp,exp ...
   Declare data in the current segment.  No output is generated if
   within a .U segment.  Note that the byte ordering for the
   selected processor is used for each entry.
   The default size extension is a byte.
#if OlafByte
   BYTE, WORD and LONG are synonyms for DC.B, DC.W and DC.L.
#endif
So the line
  BYTE %00000111100
is comprised of the pseudop BYTE (means same as DC.B) followed by the expression %00000111100.
Elsewhere in dasm.txt:
EXPRESSIONS:
	[] may be used to group expressions.  The precedense of operators
	is the same as for the C language in almost all respects.  Use
	brackets [] when you are unsure.  The reason () cannot be used to
	group expressions is due to a conflict with the 6502 and other
	assembly languages.
#if OlafBraKet
	It is possible to use () instead of [] in expressions following
	pseudo-ops, but not following mnemonics. So this works:
	if target & (pet3001 | pet4001), but this does not:
	lda #target & (pet3001 | pet4001).
#endif
	Some operators, such as ||, can return a resolved value even if
	one of the expressions is not resolved.   Operators are as follows:
	NOTE WELL!  Some operations will result in non-byte values when a
	byte value was wanted.	For example:	~1  is NOT $FF, but
	$FFFFFFFF.  Preceding it with a < (take LSB of) will solve the
	problem.  ALL ARITHMETIC IS CARRIED OUT IN 32 BITS.  The final
	Result will be automatically truncated to the maximum handleable
	by the particular machine language (usually a word) when applied
	to standard mnemonics.
Key bit of info there is ALL ARITHMETIC IS CARRIED OUT IN 32 BITS. So for binary numbers there can be a total of up to 32 1s and 0s after the %. If you have fewer than 32 digits it will pad 0s to the left of what you see.
DC.B / BYTE will use the rightmost 8 bits of the 32 bit value, and ignore the rest.
DC.W / WORD will use the rightmost 16 bits of the 32 bit value, and ignore the rest
DC.L / LONG will use all 32 bits.
PSEUDOPS:
#if OlafByte
#endif
So the line
BYTE %00000111100
EXPRESSIONS:
assembly languages.
#if OlafBraKet
#endif
can't make it work :(
I took those sprites from the free sprites thread and didn't notice that they were more than 8 bits wide. So yeah, let's just call that a bug in the example code.
but i have changed them to 8 bits and can't make it work. please i need just one working example about this.
can't understand the mismatch.
Quick update of Collect to replace DoDraw of the players with a Mask
attachicon.gifCollect_mask_20180228.zip
THIS ARE THE ACTIONS AND PERSONS WHOM MAKES A NEW CHAPTER IN THE ATARI'S PROGRAMMING LIFE, A NEW STEP, MORE NEAR THAN EVER FOR US, FOR ALL THOSE PEOPLE THAT ARE TRYING TO LEARN.
THANK YOU DARRELL SPICE JR. IF YOU NEED SOMETHING FROM ARGENTINA, WHAT EVER YOU NEED, JUST ASK,
KIND KIND REGARS. AND TY AGAIN. THIS IS AN EXTRA HAPPY DAY.
If you run into any more problems, please attach the asm file instead of pasting it's contents into your post. You have to use the "More Reply Options" to attach files to your post.
DASM treats any line without white space as a label and wouldn't assemble what you pasted above because most of the indentation got lost. It appears as though all the leading tabs were removed at some point.
hi ZackAttack!! I have tried to compile your first asm file
please try it, i did a graphic cut for 8 bits and still it does not compile.
ty.
Interesting. I got those errors too, but didn't notice before because DASM keeps going and generates a working bin file for me. My build script automatically runs the bin so I don't bother looking at the output if stella pops open with a working program.
The macro below couldn't be expanded in the first two passes, so it takes up 0 bytes. Then after SPRITE_HEIGHT is calculated it evaluates the REPEAT macro and causes an extra 18 bytes to be inserted into the bin, moving the location of everything after it. I've reordered things to prevent this problem. I assume you guys are using a different OS or different version of DASM, and that's why the error failed the build completely for you, but not me.
	REPEAT SPRITE_HEIGHT
	BYTE $ff
	REPEND
Here's an updated asm file that should build for you too.
mask_draw_demo3.asm
	BYTE $ff
	REPEND
attachicon.gifmask_draw_demo3.asm
DASM 2.20.11 20140304
Copyright © 1988-2008 by various authors (see file AUTHORS).
License GPLv2+: GNU GPL version 2 or later (see file COPYING).
DASM is free software: you are free to change and redistribute it.
There is ABSOLUTELY NO WARRANTY, to the extent permitted by law.
ty ZackAttack !! i will try your new source!!
what version of dasm are you wearing?
HI, i'm doing some tests with all this but there is a weird situation
i have a 127 lines HEIGHT kernel, one line kernel for now. 1LK,
there is no cross page boundaries, all graphics are less than 200 lines and all of them comence with ALIGN 256
here is the kernel loop ( i have omitted SLEEP macros, STA WSYNC and other things) to let this clear and easy to read
the weird thing is that if i'm using MASKED SPRITES i cannot make two of them fit in a single line with six writes to playfield.
and it's weird cos there is time and still some cycles to waste? any clue?
ty in advance. this is a nightmare lol.
kerneloop
   lda PLAYF0,y	        	;+4
   sta PF0	        	;+3 7
   lda PLAYF1,y		        ;+4 11
   sta PF1			;+3 14
   lda PLAYF2,y	        	;+4 18
   sta PF2			;+3 21
   lda PLAYF3,y	        	;+4 25
   sta PF0			;+3 28
   lda PLAYF4,y	        	;+4 32
   sta PF1			;+3 35
   lda PLAYF5,y 		;+4 39
   sta PF2			;+3 42
   LDA (player0),y	        ;+5 47
   AND (mask0),y		;+5 52
   sta GRP0			;+3 55
   LDA (player1),y              ;+5 60
   AND (mask1),y                ;+5 65
   sta GRP1                     ;+3 68
   dey
   BNE kerneloop
