What is this music I am working on?
chiptune coleco commando music soundfx rom
32 replies to this topic
#1 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Tue Feb 27, 2018 5:45 PM
I'm leaving here the first draft of a music I'm currently working on. It's based on a famous chiptune many should recognize. It took me about 3 hours to figure out the proper notes, sound effects and what overall feels nice to my ears (essentially means, I am able to listen without the feeling that something is out of place). Keep in mind that I code music note by note, no help of any music tracker, it's all done by hand which takes a lot of time, patience, a minimum of music knowledge, and listening to the original material over and over again.
You can try to compile the music data in a program with the proper calls to the Coleco OS sound routines, check the coding guides, OS7 ColecoVision BIOS listing. It should also work with ADAM EOS sound routines since they are essentially the same. You can also try to use a keyboard and play the notes mentioned in the comments. You can also play directly the data with one of my sound tools without compiling anything.
Hint: the capital letters HS refer to the words High Score.
And for those who really can't try the music data listings, at least you can listen to the result.
March 31, 2018 - MODIFIED (ROBHUBBARDIFY) MUSIC INTRO LEVEL Attached File  commando-musicbox-2018-revJ.zip   4.29KB   57 downloads
March 30, 2018 - ADDED FX-FREE, MUSIC INTRO LEVEL with FX-CHOPPA Attached File  commando-musicbox-2018-revI.zip   4.22KB   49 downloads
March 29, 2018 - ADDED FX-SUPPLY, FX-MOTOR Attached File  commando-musicbox-2018-revH.zip   3.99KB   51 downloads
March 26, 2018 - ADDED FX-LETTER Attached File  commando-musicbox-2018-revG.zip   3.87KB   52 downloads
March 21, 2018 - ADDED FX-LIFE Attached File  commando-musicbox-2018-revF.zip   3.77KB   58 downloads
March 20, 2018 - ADDED FX-GRENADE Attached File  commando-musicbox-2018-revE.zip   3.68KB   62 downloads
March 17, 2018 - ADDED AREA COMPLETE + FX-DEATH Attached File  commando-musicbox-2018-revD.zip   3.7KB   61 downloads
Version March 7, 2018 - Melody completed. Tweaked some volume-effects.
; Daniel Bienvenu
; March 7, 2018
; Music Data
music_HS_ch0_A:
.db 0x00,0x00,0x84,0x02
.db 0x02,0x23,0x0e,0x12,0x21
.db 0x00,0x00,0x64,0x01
.db 0x00,0x00,0x33,0x0f
.db 0x02,0x45,0x10,0x1c,0x21
.db 0x18
music_HS_ch3_A:
.db 0xc0,0x88,0xf0,0x80 ; A1
.db 0xc0,0x98,0xf0,0x80 ; G1
.db 0xc0,0x66,0xf0,0x80 ; D2
.db 0xc0,0x5a,0xf0,0x80 ; E2
.db 0xc0,0x51,0xf0,0x80 ; F#2
.db 0xc0,0x6c,0xf0,0x80 ; C#2
.db 0xc0,0x66,0xf0,0x40 ; D2
.db 0xc0,0x5a,0xf0,0x40 ; E2
.db 0xd8
music_HS_ch1_A:
;; A4
.db 0x40,0xFE,0x80,0x01
.db 0x40,0xFC,0x71,0x01
.db 0x40,0xFE,0x70,0x01
.db 0x40,0x00,0xf0,0x04
;; E5
.db 0x40,0xAA,0x80,0x01
.db 0x40,0x53,0x71,0x01
.db 0x40,0xAA,0x70,0x01
;; A5
.db 0x40,0x7F,0x80,0x01
.db 0x40,0x7F,0x70,0x01
;; E5
;; A5
;; A5
;; E5
;; A5
.db 0x58
music_HS_ch2_A:
;; - 1 -
.db 0x82,0xCA,0xc0,0x30,0xe4,0x11 ; C#5
.db 0x81, 0xcd, 0x60, 0x03, 0x22, 0xFd
.db 0x81, 0xC7, 0x60, 0x03, 0x22, 0x03
.db 0x81, 0xC7, 0x70, 0x03, 0x22, 0x03
.db 0x82,0xE2,0xc0,0x20,0xe4,0x11 ; B4
.db 0x82,0xBE,0xc0,0x10,0xe4,0x11 ; D5
.db 0x82,0xCA,0xc0,0x20,0xe4,0x11 ; C#5
.db 0x82,0xFE,0xc0,0x30,0xe4,0x11 ; A4
.db 0x81, 0x01, 0x61, 0x03, 0x22, 0xFd
.db 0x81, 0xFB, 0x60, 0x03, 0x22, 0x03
.db 0x81, 0xFB, 0x70, 0x03, 0x22, 0x03
.db 0x82,0xFE,0xc0,0x20,0xe4,0x11 ; A4
.db 0x82,0xFE,0xc0,0x10,0xe4,0x11 ; A4
.db 0x82,0x0D,0xc1,0x20,0xe4,0x11 ; Ab4
.db 0x82,0x2E,0xc1,0x30,0xe4,0x11 ; F#4
.db 0x82,0x0D,0xc1,0x10,0xe4,0x11 ; Ab4
;; - 2 -
.db 0x82,0x2E,0xc1,0x20,0xe4,0x11 ; F#4
.db 0x82,0x53,0xc1,0x30,0xe4,0x11 ; E4
;; - 3 -
.db 0x81, 0x56, 0x61, 0x03, 0x22, 0xFd
.db 0x81, 0x50, 0x61, 0x03, 0x22, 0x03
.db 0x82,0x2e,0xc1,0x10,0xe4,0x11 ; F#4
.db 0x81, 0x10, 0x61, 0x03, 0x22, 0xFd
.db 0x81, 0x0A, 0x61, 0x03, 0x22, 0x03
.db 0x82,0xE2,0xc0,0x10,0xe4,0x11 ; B4
.db 0x81, 0xE5, 0x60, 0x03, 0x22, 0xFd
.db 0x81, 0xDF, 0x60, 0x03, 0x22, 0x03
.db 0x82,0xCA,0xc0,0x10,0xe4,0x11 ; C#5
.db 0x82,0xBE,0xc0,0x20,0xe4,0x11 ; D5
;; - 2 -
;; - 4 -
.db 0x80,0x00,0xf0,0x10
.db 0x82,0x7d,0xc1,0x10,0xe4,0x11 ; D4
.db 0x82,0x53,0xc1,0x10,0xe4,0x11 ; E4
.db 0x82,0x0d,0xc1,0x10,0xe4,0x11 ; Ab4
;; - 5 -
;; - 4 -
;; - 5 -
.db 0x98
Version February 28, 2018 - 1 more hour of work on it. Tweaked a little the volume and added more to the melody.
; Daniel Bienvenu
; February 28, 2018
; Music Data
music_HS_ch0_A:
.db 0x00,0x00,0x74,0x02
.db 0x02,0x23,0x0e,0x1b,0x31
.db 0x02,0x63,0x0e,0x1b,0x31
.db 0x02,0x35,0x10,0x1c,0x21
.db 0x02,0x23,0x0e,0x1b,0x21
.db 0x18
music_HS_ch3_A:
.db 0xd8
music_HS_ch1_A:
.db 0x41, 0x7F, 0x70, 0x02, 0x11, 0x7F ; A5
.db 0x41, 0x7F, 0x80, 0x02, 0x11, 0x7F
.db 0x41, 0x7F, 0xa0, 0x02, 0x11, 0x7F
.db 0x41, 0x7F, 0xd0, 0x02, 0x11, 0x7F
.db 0x41, 0x55, 0x70, 0x02, 0x11, 0x55 ; E6
.db 0x41, 0x55, 0x80, 0x02, 0x11, 0x55
.db 0x41, 0x55, 0xa0, 0x02, 0x11, 0x55
.db 0x41, 0x55, 0xd0, 0x02, 0x11, 0x55
.db 0x41, 0x40, 0x70, 0x02, 0x11, 0x40 ; A6
.db 0x41, 0x40, 0x80, 0x02, 0x11, 0x40
.db 0x41, 0x40, 0xa0, 0x02, 0x11, 0x40
.db 0x41, 0x40, 0xd0, 0x02, 0x11, 0x40
.db 0x58
music_HS_ch2_A:
.db 0x82,0xCA,0xc0,0x30,0xe5,0x11 ; C#5
.db 0x81, 0xcd, 0x40, 0x03, 0x22, 0xFd
.db 0x81, 0xC7, 0x40, 0x03, 0x22, 0x03
.db 0x82,0xE2,0xc0,0x20,0xe5,0x11 ; B4
.db 0x82,0xBE,0xc0,0x10,0xe5,0x11 ; D5
.db 0x82,0xCA,0xc0,0x20,0xe5,0x11 ; C#5
.db 0x82,0xFE,0xc0,0x30,0xe5,0x11 ; A4
.db 0x81, 0x01, 0x41, 0x03, 0x22, 0xFd
.db 0x81, 0xFB, 0x40, 0x03, 0x22, 0x03
.db 0x82,0xFE,0xc0,0x20,0xe5,0x11 ; A4
.db 0x82,0xFE,0xc0,0x10,0xe5,0x11 ; A4
.db 0x82,0x0D,0xc1,0x20,0xe5,0x11 ; Ab4
.db 0x82,0x2E,0xc1,0x30,0xe5,0x11 ; F#4
.db 0x82,0x0D,0xc1,0x10,0xe5,0x11 ; Ab4
.db 0x82,0x2E,0xc1,0x20,0xe5,0x11 ; F#4
.db 0x82,0x53,0xc1,0x30,0xe5,0x11 ; E4
.db 0x81, 0x56, 0x41, 0x03, 0x22, 0xFd
.db 0x81, 0x50, 0x41, 0x03, 0x22, 0x03
.db 0x82,0x2e,0xc1,0x10,0xe5,0x11 ; F#4
.db 0x81, 0x10, 0x41, 0x03, 0x22, 0xFd
.db 0x81, 0x0A, 0x41, 0x03, 0x22, 0x03
.db 0x82,0xE2,0xc0,0x10,0xe5,0x11 ; B4
.db 0x81, 0xE5, 0x40, 0x03, 0x22, 0xFd
.db 0x81, 0xDF, 0x40, 0x03, 0x22, 0x03
.db 0x82,0xCA,0xc0,0x10,0xe5,0x11 ; C#5
.db 0x82,0xBE,0xc0,0x20,0xe5,0x11 ; D5
.db 0x98
Version February 27, 2018 - First draft, 3 hours of work. Base line and 1st mesure of the melody.
; Daniel Bienvenu
; February 27, 2018
; Music Data
music_HS_ch0_A:
.db 0x02,0x25,0x10,0x1c,0x12
.db 0x18
music_HS_ch3_A:
.db 0xd8
music_HS_ch1_A:
.db 0x41, 0x7F, 0x50, 0x02, 0x11, 0x7F ; A5
.db 0x41, 0x7F, 0x60, 0x02, 0x11, 0x7F
.db 0x41, 0x55, 0x50, 0x02, 0x11, 0x55 ; E6
.db 0x41, 0x55, 0x60, 0x02, 0x11, 0x55
.db 0x41, 0x40, 0x50, 0x02, 0x11, 0x40 ; A6
.db 0x41, 0x40, 0x60, 0x02, 0x11, 0x40
.db 0x58
music_HS_ch2_A:
.db 0x98
I hope someone will give it a try. Maybe someone new to Coleco programming will enjoy figure it out.
Do not spoil the mystery! I will reveal when I am done composing the music.
Leave a comment!
Edited by newcoleco, Sat Mar 31, 2018 7:13 PM.
#2 digress OFFLINE
digress
  • 1,118 posts
Posted Wed Feb 28, 2018 8:48 AM
I don't recognize the tune but it sounds good. i tried setting it so i could turn off /on the various music parts. must be a nes game but i i'm not sure.
#3 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,446 posts
Posted Wed Feb 28, 2018 9:23 AM
I believe it could be this one?
Spoiler
Edited by carlsson, Wed Feb 28, 2018 9:32 AM.
#4 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Wed Feb 28, 2018 2:08 PM
I give you this... it's not from any console video game, but could be. It was originally composed as part of a PAL adaptation of an arcade game. Chiptune fans surely have heard this music before.
Edited by newcoleco, Wed Feb 28, 2018 2:09 PM.
#5 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,446 posts
Posted Wed Feb 28, 2018 5:39 PM
Yup, the composer finished all music in one night. By 8 AM he was done, by 10 AM he was on the train back home.
#6 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Wed Feb 28, 2018 7:09 PM
You got it!
Updated the music data - a bit more melody added to it ;-)
Edited by newcoleco, Wed Feb 28, 2018 7:19 PM.
#7 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,446 posts
Posted Thu Mar 1, 2018 6:43 AM
Actually my first post already gave it away, if you do some creative searching. I don't know if you have heard that remix before.
#8 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Thu Mar 1, 2018 9:58 AM
True, I saw your spoiler. I wanted to wait for others to give it a try and then realised I could just reply to your more recent post. ;-)
#9 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Sat Mar 17, 2018 7:46 PM
Well, the time is come to reveal the identity of the mysterious music. It was simply the Commodore 64 version of the Commando HIGH SCORE screen composed originally by Rob Hubbard.
I've added a ROM file for everyone to enjoy, plus some extra ;-)
DOWNLOAD AND DREAM!
#10 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,446 posts
Posted Sat Mar 17, 2018 7:56 PM
And this is the remix I spoiled about: http://www.remix64.c...x.php?id=148100
#11 nanochess ONLINE
nanochess
    Processorus Polyglotus
  • 5,778 posts
  • Coding something good
Posted Sat Mar 17, 2018 8:08 PM
#12 youki OFFLINE
youki
  • 2,446 posts
Posted Sun Mar 18, 2018 12:55 PM
AWESOME! :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
#13 digress OFFLINE
digress
  • 1,118 posts
Posted Sun Mar 18, 2018 4:25 PM
we should make the game for coleco next eh?  The msx version looks like crap so no conversion version. I think it could be done reasonably nice.
#14 youki OFFLINE
youki
  • 2,446 posts
Posted Mon Mar 19, 2018 2:00 AM
Already some versions of Commando (or commando like) on colecovision has been started by few homebrewers.   I have played already 3 versions  at different stages of progress :)   All Looks very promising.
the MSX version is very crap indeed.
#15 artrag OFFLINE
artrag
  • 1,211 posts
Posted Mon Mar 19, 2018 7:37 AM
True, the msx version is terrible
#16 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Mon Mar 19, 2018 1:01 PM
Have you seen the "remastered" Commando for the Commodore 64 released in 2016 (I think)? There are now cutscenes, more options/musics/sfx.
#17 youki OFFLINE
youki
  • 2,446 posts
Posted Mon Mar 19, 2018 2:14 PM
Yes, this version is faboulous!
Did you see also the remastered version of Ghost'n Goblins and  Donkey Kong ?
#18 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Tue Mar 20, 2018 6:37 PM
March 20, 2018
Rev E
+ Tweaked High-Score music noise effect
+ Added Sound FX throw grenade (shorter than the original but sound similar enough)
#19 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Wed Mar 21, 2018 6:30 PM
March 21, 2018
Rev F
+ Tweaked in-game music with shaker/cabasa effect in the first half of the music
+ Added Sound FX bonus life (free man)
#20 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Mon Mar 26, 2018 8:33 PM
March 26, 2018
Rev G
+ Tweak noise for all the music
+ Added noise effect at the start of every note for the victory (end level) music, to give it more punch
+ Added Sound FX when shooting letters to enter your name (High Score)
The missing sound effects are a bit hard to compose similar as the original sounds by Rob Hubbard, so I will just go with what I feel is good enough and end this music+sfx project this week.
#21 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Thu Mar 29, 2018 5:37 PM
March 29, 2018
Rev H
+ Added 2 Sound FX: SUPPLY when you collect more grenades, MOTOR when a tank or jeep is passing by.
There are at least 2 sound effects left in my todo list; I would like to add the helicopter bringing the commando guy, and the bonus for freeing a soldier (an SFX not in the original C64 version). I don't have much planned time left in my schedule to continue and the sound data is taking pretty much 16KB already, so I make no promise.
#22 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Fri Mar 30, 2018 12:35 PM
March 30, 2018
Rev I
+ Added Sound FX FREE CAPTIVE-SOLDIER
+ Added Music Intro Level with Chopper (helicopter)
MUSIC BOX COMMAND COMPLETED
ROM FILE
Attached File  commando-musicbox-2018-revI.zip   4.22KB   64 downloads
I consider the sound part to be complete... some might want even more, like an explosion, but there is a time when we have to say "Okay, time to focus on something else!"
I've started a title screen with, of course, the 1985 action movie Commando starring Arnold Schwarzenegger.
https://en.wikipedia...ndo_(1985_film)
BONUS !
AND TO SHOW AGAIN TO THE WORLD THAT I DO THIS AS A HOBBY
COMMANDO ROM + SOURCE FILES (TNIASM)
Attached File  COMMANDO.zip   30.21KB   68 downloads
If you wanna continue this project and have fun with it, please give credits where credits are due.
And yes, this project is powered by DAN2 data compression, so it's all my codes made from scratch.
Edited by newcoleco, Fri Mar 30, 2018 12:53 PM.
#23 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Fri Mar 30, 2018 6:41 PM
Note: Tested all the ROM files with a real unmodified ColecoVision game system running on a good old CRT (Cathode Ray Tube) TV set and everything works fine. But, I've noted the loud sounds are distorted, so I will try to tweak the volume down for the "END LEVEL" music and the "CHOPPA" sound effect which are the 2 loudest ones of the bunch to make it sound fine on my retro gaming set.
#24 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Sat Mar 31, 2018 7:15 PM
March 31, 2018
Rev J
+ ADJUSTED VOLUME
+ MODIFIED INTRO MUSIC
It sounds fine on real hardware, I'm keeping this version. Mission Complete!
#25 alekmaul OFFLINE
alekmaul
    Chopper Commander
  • 206 posts
Posted Wed Apr 11, 2018 1:11 PM
Thanks a lot for sharing source code Daniel,I have tried it on emu and the music is FANTASTIC  !!! :o  !m!
Also tagged with one or more of these keywords: chiptune, coleco, commando, music, soundfx, rom
