Rust on nes 72-pin connector
NES Retro Rust repair
9 replies to this topic
#1 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Tue Feb 27, 2018 5:51 PM
Hi,
As the title implies there is rust on my NES motherboard 72-pin connector.
Here's a pic:
https://imgur.com/uq73MtE
Is this an issue? if so how do I treat it? I've already applied oil to it to prevent further rusting.
Thanks
#2 SignGuy81 OFFLINE
SignGuy81
  • 1,661 posts
Posted Tue Feb 27, 2018 6:08 PM
I would buy a new pin connector on ebay they are around 7 or 8 bucks or so.
#3 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Tue Feb 27, 2018 6:11 PM
please look at the picture provided. there's no rust on the actual connector that games connect to (the black piece) there's rust on the pins of the motherboard where the connector connects to, (confusing right?)
#4 SignGuy81 OFFLINE
SignGuy81
  • 1,661 posts
Posted Tue Feb 27, 2018 6:16 PM
My bad.  Instead I would clean that up with a scotch pad and coat it with some solder and remove any excess.
#5 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Tue Feb 27, 2018 6:52 PM
Do you think there are any alternatives?  I don't think I'd be able to pull something like that off with my soldering skills, and I'm about to spend about $200 on modwork on this motherboard so I want to make sure it doesn't fail on me.
#6 SignGuy81 OFFLINE
SignGuy81
  • 1,661 posts
Posted Tue Feb 27, 2018 6:55 PM
Any decent mod service you are going to be spending $200 on should take care of that issue for you as long as you tell them about it, and most I don't even think would charge to fix that as I know I wouldn't.
PS:
What are you having done to it?
Edited by SignGuy81, Tue Feb 27, 2018 6:56 PM.
#7 TheDash OFFLINE
TheDash
    Space Invader
  • 34 posts
Posted Tue Feb 27, 2018 8:53 PM
Does the NES actually work? If you're going to spend around $200 on getting one modded (I assume it must be HDMI at that cost) then it would be worth getting one in decent order first. Here in the UK you can get a NES in good working order for around £30, or $40 US - they are pretty readily available.
#8 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Wed Feb 28, 2018 7:26 AM
there are absolutely no issues with the system, everything is so clean that (I'm not exaggerating) ever since I've cleaned it up I've literally never had to remove a cartridge and re-insert it because of a bad connection.
#9 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Wed Feb 28, 2018 7:27 AM
PS:
I hope to get a Hi-Def NES board installed, replacement caps and a disabled lockout chip. all of this work will be done by retrohacks.net
Edited by GoodAtBeingNoob, Wed Feb 28, 2018 7:28 AM.
#10 GoodAtBeingNoob OFFLINE
GoodAtBeingNoob
    Combat Commando
  • 6 posts
Posted Wed Feb 28, 2018 8:01 AM
PS:
update: I just contacted the modder that I hope to use and he said that he can do that for me when I send it in.
Also tagged with one or more of these keywords: NES, Retro, Rust, repair
