STUNT CAR RACER?
498 replies to this topic
#476 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,921 posts
Posted Fri Sep 28, 2018 6:20 PM
So Commodore's just went with external ram expansions like the 600XL, while Atari's went with mostly internal in the 800 through XE with 800 ram cards or XL/XE internal dram. Until recent years anyway with the external PBI ram expansions released a few years back or like the Syscheck 512K I have plugged in my PBI port. Too bad the Commodore community doesn't support it better these days as the Atari community does.
#477 Level42 OFFLINE
Level42
  • 2,593 posts
Posted Sat Sep 29, 2018 4:34 AM
TT030, Amiga, and Falcon030, anything less is close to a felony :) ... well sort of... a modded STe avoids being a misdemeanor ... all stf fm and mega's needed the memory upped and the sound mods as well as the graphics updates...
You forget the Mega STE...... for me the best Of the ST series.
#478 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Thu Oct 4, 2018 7:56 PM
Such a great port! How about we try to make a mod of this to make Accolade's Test Drive? ;)
#479 Level42 OFFLINE
Level42
  • 2,593 posts
Posted Fri Oct 5, 2018 3:17 AM
Yugh.
Worst "racing" game ever.
Why did that game ever get such great following is beyond me.
The speed of the graphics.....man you could write it in Turbo Basic on the A8......
Edited by Level42, Fri Oct 5, 2018 3:18 AM.
#480 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,251 posts
Posted Fri Oct 5, 2018 8:28 AM
Same here, saw it and thought "racing game?", its so clunky...
Nice idea at the time but hardly an Adrenalin thrill ride :)
Didn't realise it had a following, all the folks I knew thought the same sort of thing, sure when it hit a console in later life but the initial versions were er over taken by a granny with a walker...
#481 flashjazzcat OFFLINE
flashjazzcat
  • 14,167 posts
Posted Fri Oct 5, 2018 9:05 AM
Not sure how the graphics actually work, but I fancy that flood-filling an arbitrary region of a colour bit-mapped graphics display with green pixels ten or twenty times a second might present some challenges even for Turbo BASIC.
#482 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,251 posts
Posted Fri Oct 5, 2018 9:12 AM
I can't imagine it would have been a mega optimised specially written fill routine, they probably spent more time on just getting the car and what physics there were used right..
Still a 'plodder' though...
#483 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Fri Oct 5, 2018 10:36 AM
You can cheat a bit with fill on the C64 by using attributes, though they only apply to foreground colours.
You can do the same thing on Atari but have to use the multicolour text mode.
#484 emkay OFFLINE
emkay
  • 9,646 posts
  • What's up?
Posted Fri Oct 5, 2018 11:34 AM
Using the PMg shapes is faster and saves a lot of characters.
#485 Wrathchild OFFLINE
Wrathchild
  • 2,128 posts
Posted Fri Oct 5, 2018 2:45 PM
You'd only need 4 characters, 1 each filled with the colour patterns $00, $55, $AA and $FF, but you could probably get away with two, for example for the sky rock colours.
Writing to one memory byte in the screen's memory in Antic 4 character mode will have the effect of covering a 4*8 pixel area of the display. Therefore 2 writes cover an 8*8 area, 4 covers a 16*8 and 8 covers a 32*8 area.
Alternatively handling this with Player data (i.e. DMA enabled) would require the following:
A double-line mode player of normal, double and quadruple width needs 4 writes to fill the same vertical height.
This can handle a 4*8 area when you set half the pixels in normal width player. So this is 4 times slower.
This can then handle an 8*8 area if you set all the pixels in normal width. So this is twice as slow.
It can handle a 16*8 area when you set all the pixels in double width. So this is works out as the same.
It can also handle a 32*8 area by setting all the pixels in quadruple width. So yes, this would be twice as fast.
A single-line mode player of normal, double and quadruple width needs 8 writes to fill the same vertical height, so:
A 4*8 area setting half the pixels in normal width, this is 8 times slower.
An 8*8 area setting all the pixels in normal width, this is 4 times as slow.
A 16*8 area setting all the pixels in double width, this is twice as slow.
A 32*8 area setting all the pixels in quadruple width, works out as the same.
Of course there is the option of not using PM DMA but then you are responsible for managing the turning on the pixels at the right ypos and off again, the overheads of which I should think are again going to be more or less the same or worse when comparing with the overheads of the DMA. Especially if you consider having to also set various player's xpos over the height of the screen too.
I'd therefore suggest that this method would be a more sensible approach. As far a I can see, only the quad-width players may offer something comparable but would argue here that handling the granularity, i.e. working out if 1..8 pixels need to be set (e.g. when the wall edge gets closer to the edge of a screen) would again be a greater overhead.
This simplistic math may have missed something so I'm more than happy to have it demonstrated where the Player/Missile approach works better for a whole screen. Perhaps two g2f's of a captured screen with an explanation of the fill loops for the solid areas would help?
#486 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Fri Oct 5, 2018 11:45 PM
So... What about that steep hill? could we make the hill be a brown PM, like Elektra Glide did with the tunnels, that should give a believable illusion of 3d?
#487 emkay OFFLINE
emkay
  • 9,646 posts
  • What's up?
Posted Fri Oct 5, 2018 11:53 PM
That's one of those relevant points.
The hills have a limited animation. You could store that in the Player. Use one or two players in single width and set another to fill the rest. Then just some commands for the x position of the players will build the hill animation for the full height. The game could be build on Antic 4 then , without any problems.
Using the PMg for filling up ranges in games to have more colors with Softwaresprites is surely "underused" ...
#488 emkay OFFLINE
emkay
  • 9,646 posts
  • What's up?
Posted Sat Oct 6, 2018 12:17 AM
Could you imagine a "hill racing game" ? No need for 50fps. Just 14-16 fps would do well by the given resolution.
But it could run at "50fps" ...
Not to mention that Test Drive was intended to be a racing game within a Sportscar simulation ?
Edited by emkay, Sat Oct 6, 2018 12:19 AM.
#489 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Sat Oct 6, 2018 12:19 AM
The other available cheat is the hardware exploit with SIZE for PMs to make them persistent.  Though for a driving game the options are probably a bit limited.
#490 emkay OFFLINE
emkay
  • 9,646 posts
  • What's up?
Posted Sat Oct 6, 2018 1:02 AM
You'd only need the raw shapes. You could also use some characters to do some additional "line-up" .
Not to miss the point that masking is easily possible.
#491 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Sat Oct 6, 2018 10:17 AM
Could we also do MCS for the cars? Also, could we implement the mirror functionality?
#492 Wrathchild OFFLINE
Wrathchild
  • 2,128 posts
Posted Sat Oct 6, 2018 10:44 AM
Worth staring a new thread... ? this has nothing to do with SCR
#493 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Sat Oct 6, 2018 11:54 AM
Actually, I started a thread about porting Hard Drivin’ to the Atari, as it seems to be a game that’s more worth the time than working on Test Drive.
#494 zetastrike OFFLINE
zetastrike
    Moonsweeper
  • 415 posts
Posted Tue Nov 27, 2018 7:17 PM
I'm trying to run this from my Uno Cart on my 130XE. I can't get past this screen. What am I doing wrong, or is it not compatible with my setup?5217fbdb448fcd07430aacb5a9e5c1e7.jpg
Sent from my SAMSUNG-SM-J727AZ using Tapatalk
#495 xxl OFFLINE
xxl
  • 1,120 posts
Posted Wed Nov 28, 2018 2:51 AM
you must run this game from a device connected to the Peripheral not Cartridge connector.
or look for a crack version without a save option.
Edited by xxl, Wed Nov 28, 2018 3:06 AM.
#496 BoatofCar OFFLINE
BoatofCar
    Dragonstomper
  • 515 posts
Posted Fri Nov 30, 2018 4:08 PM
For those without access to an emulator or hardware, I made a quick gameplay video:
No quips about my playing ability! :grin:
#497 _The Doctor__ OFFLINE
_The Doctor__
  • 5,949 posts
Posted Sat Dec 1, 2018 8:09 AM
Nitro stunt racing (twisted)... hard drivin... stunt track driver...  stunt driver  and stunt driver 2....  get's to be a jumble...
anybody remember stunt cycle or for a real blast of the pat stunt pilot (mechanical)  ?
Edited by _The Doctor__, Sat Dec 1, 2018 8:28 AM.
#498 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 744 posts
Posted Sat Dec 1, 2018 12:29 PM
Did the latest two posts in this thread disappear, including mine?
#499 Albert OFFLINE
Albert
  • 35,080 posts
Posted Sat Dec 1, 2018 12:33 PM
Yes, the poster who made the post you responded to asked us to remove it as he made a mistake.
