Constants place in assembler code?
4 replies to this topic
#1 zilog_z80a OFFLINE
zilog_z80a
    Chopper Commander
  • 102 posts
Posted Thu Mar 1, 2018 3:27 PM
Hi, this is a humble post to know where is the correct place to put in code our constants, i found this code (below) time ago...
and i think that constant data should go after ORG $F000
Please can somebody correct me if i'm not right?
cheers!! ty in advance.
                processor 6502
                include "vcs.h"
                include "macro.h"
SPRITE_HEIGHT0 equ 37
Joy0Right equ 128
Joy0Left equ 64
Joy0Down equ 32
Joy0Up equ 16
                SEG.U RAM
                ORG $80
Player0X ds 1
Player0Y ds 1
Player0PTR ds 2
time_of_jump ds 1
                SEG ROM
                ORG $F000
Reset
                CLEAN_START
    lda #%00001000
    sta REFP0
;SHALA LALALALALALA....... FOO FOO FOO.... TONS OF CODE FROM HERE.... YEH!
Edited by zilog_z80a, Thu Mar 1, 2018 8:29 PM.
#2 RevEng ONLINE
RevEng
    Bit Player
  • 5,082 posts
Posted Thu Mar 1, 2018 6:01 PM
Functionally, it doesn't really matter where they go, since the generated code will be the same. Ideally you'll place them prior to being referenced, to save the assembler a pass.
Aesthetically, I tend to gather them all at the top, just before or after the RAM definitions. It works better for me to have most symbol definitions in one place, so I know immediately where to go to change them. (the exception being labels, of coure.) If some symbols are very local in scope, I might consider placing their definition close to where they're used, though truthfully I can't recall having done so.
In a similar vein, just above any semi-complex routine that uses temp memory locations, I'll redefine a symbol for temp locations to give them more meaningful names. e.g. "deltax = temp3"
#3 zilog_z80a OFFLINE
zilog_z80a
    Chopper Commander
  • 102 posts
Posted Thu Mar 1, 2018 8:26 PM
tnx RevEng, this text now is a reference and a guide for me, and tnx for your time to write and explain.
cheers!!
#4 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,861 posts
  • Always left from right here!
Posted Fri Mar 2, 2018 1:59 AM
A good idea is also to separate game specific constants (e.g. SPRITE_HEIGHT) which may change and general Atari 2600 constants (e.g. Joy0Right), which have a fixed value.
Also it is a best practice to use all UPPER_CASE for constants (BTW: GRP0, HMOVE etc. are all just general Atari 2600 constants too).
#5 zilog_z80a OFFLINE
zilog_z80a
    Chopper Commander
  • 102 posts
Posted Fri Mar 2, 2018 9:44 AM
ty Thomas, great, always wanted to know about constants spots and all related, will take note about this too.
if somebody else wants to add something about constants is really really welcome.
cheers!
