PG's POKEY corner
POKEY Atari Chiptune
46 replies to this topic
#26 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Sat Mar 3, 2018 11:40 AM
So what you are doing is start your envelope with a very high note to create an effect similar to sta STIMER, but for one channel only, and after that you fiddle about with command 6 one up or one down?
Both channels get the shortest wave playing. That builds the start for a 99% sure modulation. Then the start is needed. This depends on the common height of the notes, to have the needed wavelength. The fiddling with one pitch up and down, causes a shift in the offset of both channels, that results in a different wave length.
As this is all "passive" programming, it is recommended to listen to the melodic part several times. It may toggle in several notes. There a different wave length / offset has to be used.
You have to understand how POKEY works, to create the instrument for any tune.
That's why I offered cooperation to do some optimizations.... but...
How do you determine when to go up or down or is that just a matter of taste? And shouldn't I have every instrument start with a high, unhearable note, or a short silent pause? It seems to me that otherwise all the other instruments start playing slightly earlier.
No! Just play the instruments as they are. Only the short ones need some special handling. In double VBI speed, you won't really recognize it. In standard VBI you could play the instruments one cycle later and or just put the loudest pulse to the point where it fits to the rest of the volume.
In other Threads we very often explained the workaround for this. Just add a command into a Tracker for an "instrument start" then play the highest note, do something for more than 32 cycles, then set the real tone for the Instrument start.
If you really want people to learn and use your superior instruments, why don't you release a collection of instruments (.rti files) with a description of how to use them, for everybody to use for their next compositions/covers?
Because the passive programming needs different settings, depending on the note range and used melody.
This is one of the biggest hurdles "foreign" (i.e. NES or C64) chiptune creators have to overcome when they think about doing a Pokey song with RMT. And even those familiar with RMT and Pokey do not know all these tricks.
Because no one read my prior threads ?
Edited by emkay, Sat Mar 3, 2018 11:41 AM.
#27 ivop ONLINE
ivop
    Dragonstomper
  • 861 posts
Posted Sat Mar 3, 2018 12:18 PM
OK, so one might need different instruments for certain ranges of notes.
 I see. I assume it won't hurt though if one was to start all instruments from scratch?
Exactly ;)
But seriously, the information is all over the place and really hard to find, especially for people not familiar with the (inner) workings of pokey.
#28 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Sat Mar 3, 2018 12:34 PM
Yepp, I agree. :) It's my peronal problem too. And you would need also some how to use or readme files for some sounds. Especially the 16 bit stuff need to explain, how to use them. 1st and 2nd tone ...
It's possible only by TEAMWORK.
Exactly. Not to mention various other POKEY modes like 15kHz, or 2x/3x/4x-speed versions of the instruments.
Edited by pseudografx, Sat Mar 3, 2018 12:35 PM.
#29 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Sat Mar 3, 2018 1:29 PM
Yes.
But that is not the end of the road ;) .
You could chose between 8 different "original sounding" starts of a note , you can slide it up or down, the sweep is obvious.
Note D#2 for example , uses an intentional cancelling point.
Not sure, what you're asking for?
But, sometimes, when things get really nifty, you could place some attending sounds to another voice, before a Drum.
Exactly ;)
That's why I recommended a POKEY Tracker, where you could do the needed preparations by functional definitions, just commands with a referring description. To understand by musicians who want to try to make POKEY music.
#30 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Mon Mar 19, 2018 1:07 PM
This was my contribution to the Forever 2018 Atari music compo, which gained the 2nd place. Hope you like it!
https://soundcloud.c...grafx/atlantida
#31 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Mon Mar 19, 2018 6:31 PM
And my other entry for the compo, which ended up fourth.
https://soundcloud.c...x/atari-goes-on
#32 NRV OFFLINE
NRV
    Moonsweeper
  • 392 posts
Posted Tue Mar 20, 2018 7:13 PM
Nice..
The rhythm and some of the instruments remember me a little of the Wings of Death music (or was it Lethal Xcess?).
Edited by NRV, Tue Mar 20, 2018 7:18 PM.
#33 MARIO130XE OFFLINE
MARIO130XE
    Chopper Commander
  • 186 posts
Posted Wed Mar 21, 2018 3:16 AM
Wow, very nice tunes!!  :thumbsup:
#34 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Sun Oct 28, 2018 12:26 PM
As per request, I am providing my cover of the Alternate Reality: Waves song. I am not completely satisfied with it and I may get back to it in the future to polish it. If you want to replay the .rmt file in RMT, set the tracker to NTSC timing to get the right speed. Also, do not forget to enable stereo in the emulator.
Attached File  ARWaves.xex   9.98KB   66 downloads
Attached File  ARwavesB.zip   1.82KB   42 downloads
Edited by pseudografx, Sun Oct 28, 2018 12:45 PM.
#35 Poison OFFLINE
Poison
    Moonsweeper
  • 385 posts
Posted Sun Oct 28, 2018 12:34 PM
attachicon.gifARWaves.xex
attachicon.gifARwavesB.zip
mě to nehraje :(
#36 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Wed Jan 23, 2019 5:10 PM
Hi, my latest song is a cover of the song Opa-Opa! from the arcade game Fantasy Zone. Done in Raster Music Tracker, with mono POKEY.
https://soundcloud.c...sy-zone-opa-opa
Attached File  Fantasy Zone - Opa Opa!.xex   5.34KB   23 downloads
Enjoy!
#37 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Tue Feb 12, 2019 9:21 PM
Hi, another cover of an arcade classic After Burner. This time in stereo.
https://soundcloud.c...fx/after-burner
Hope you'll like it!
Attached File  After Burner.xex   16.31KB   22 downloads
#38 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Wed Feb 13, 2019 9:58 AM
The After Burner track sounds really good even by not being "Stock" compliant, so the "waste" of resources is granted ;) . But it seems to run at NTSC Speed ? This means 2,4 times of PAL speed ;)
Edited by emkay, Wed Feb 13, 2019 10:00 AM.
#39 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Wed Feb 13, 2019 10:07 AM
Indeed, in PAL mode I would not be able to get the right bpm without resorting to alternating tempo values on each tick.
#40 Stephen OFFLINE
Stephen
  • 7,460 posts
  • A8 Gear Head
Posted Wed Feb 13, 2019 10:27 AM
The drum / percussion sounds are fantastic in this.  Are any "digi" effects being used or is that all done with RMT instrumentation?
#41 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Wed Feb 13, 2019 12:32 PM
Thanks! it's all pure POKEY, no samples.
Edited by pseudografx, Wed Feb 13, 2019 12:32 PM.
#42 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Wed Feb 13, 2019 1:38 PM
Well, 120Hz means sampled frequencies for up to 60Hz with fast manipulations for 120Hz. In fact "sampling" happens there, as it reaches the hearable range.
#43 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Wed Feb 13, 2019 3:23 PM
If you look at it like this, then the standard 50/60Hz mode is also sampling.
#44 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Wed Feb 13, 2019 3:28 PM
In theory.
But for real 50Hz means 25Hz samples. Not much usable for the hearable range. 30Hz is slightly different... 60Hz is clearly distinguishable.
#45 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Fri Feb 15, 2019 10:03 AM
Doom for the Atari? Well, kinda :-)
This time I tried to mess with the 15kHz mode, which I am not very skilled in, but I think the result is not too bad. Enjoy!
https://soundcloud.c...dooms-gate-e1m1
Attached File  E1M1.xex   8.57KB   20 downloads
#46 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Fri Feb 15, 2019 2:48 PM
Sounds well. But how about a version of this one, using a stock Atari plus one VBI ?
A 3 channel rendition would be a great start.
#47 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Fri Feb 15, 2019 4:00 PM
Feel free.
Edited by pseudografx, Fri Feb 15, 2019 4:00 PM.
Also tagged with one or more of these keywords: POKEY, Atari, Chiptune
