working on a nano peb 3d case
31 replies to this topic
#1 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Tue Mar 6, 2018 10:08 PM
i have not had any luck  finding a nano peb 3d printable case  that is "shared"  out on the web
so since i have a new 3d printer thought i would try my hand at it for my first foray into 3d modeling
well i actually  did a bit of it (3d modeling) back when halo 2 was new doing halo mods , but most of that was just editing existing  models
here is my initial test design
will print this tonight (8 hour print time) to make sure the  bottom layer is thick enough and that everything fits tight
then i will tweak the openings to look better/ and be more correct to size and position  , and then work on a lid
i didn't have my dial caliper here at my house   so i was stuck using a ruler  and converting inches to mm (pain in the butt lol)
so hopefully it will fit
Edited by discgolfer72, Tue Mar 6, 2018 10:13 PM.
#2 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Tue Mar 6, 2018 10:56 PM
OK started the print then paused
the opening for the  expansion connector was to small
so small edit  and trying again
Edited by discgolfer72, Tue Mar 6, 2018 10:57 PM.
#3 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Wed Mar 7, 2018 10:22 AM
sweet woke up today with it fully printed wooo
and its actually a  perfect fit
so did some tweaks  (hopefully the power  jack hole is sized right  and in the right spot (still have my micrometer at my shop not at home )
and will print this version while im at work today
so hopefully i come home to a  good print with everything still fitting right
i did increase the left wall thickness to match the other 3 walls  4
Edited by discgolfer72, Wed Mar 7, 2018 10:26 AM.
#4 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Wed Mar 7, 2018 10:39 AM
Can you show some pix of the bottom side please?
Also, are you building an enclosure here, or is that one side going to be exposed?
Sorry if Im missing something obvious. :)
Nice work!!!
#5 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Wed Mar 7, 2018 11:04 AM
the plan is for it to be fully enclosed
(like the current cases being sold )
For now ,until i find a better 3d design program (one im using now is pretty basic  and take more work than it should to do certain things )
i will probably leave the lid with an opening to remove the cf card
and access the power switch
i know several people sell a case
but after searching the web i  can only find files  for the  cart shell (and fr99)  seems no one has shared the  nano peb case files
so thought i would make something  so cheapskates like myself can run to their local library or shop class and print their own
in not promising anything fancy  but it will at least be a layer of protection for your nanopeb
if anyone has any design change tips let me know
for me i just needed something better than the cardboard ive been using to prevent shorting out on the speech synth
Edited by discgolfer72, Wed Mar 7, 2018 11:27 AM.
#6 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Wed Mar 7, 2018 2:22 PM
slow morning at the store today
so built the lid
before I left for work today  I test fitted the  peb on my speech synth and fond that due to some of the  component legs  on the solder side of the peb
I'm going to have to add a couple shims  in the underneath side so that the peb's pcb  wont flex when installed into the computer
#7 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Wed Mar 7, 2018 2:26 PM
Lookin pretty slick!!
#8 arcadeshopper OFFLINE
arcadeshopper
  • 3,611 posts
Posted Wed Mar 7, 2018 3:15 PM
cool once they are done I can print these as well and put them in the store for those without a printer (with your permission)
#9 digdugnate OFFLINE
digdugnate
  • 1,678 posts
Posted Wed Mar 7, 2018 3:30 PM
super cool.  i love seeing folks that have the know-how making projects like this to share.
#10 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Wed Mar 7, 2018 3:52 PM
here is where I'm at now   will test print tonight and tomorrow
and se if it works
https://youtu.be/quh4zmbL4d0
thanks
no problem I'm going to put it up on  https://www.thingiverse.com/ for anyone to do with as they please
I would not say I have the know-how lol   only just got my printer 3-4 days ago
and yesterday was the first time I used the tinkercad software
just a bit of internet searching and some trial and error  is all it took lol
I did make some stuff like 15 years ago  for halo 2 but way different software and it was more just importing models over existing ones and then blending them , or   slightly modifying existing models
#11 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Wed Mar 7, 2018 6:46 PM
reminder to myself not to  forget to bring my caliper home from the store today
#12 GTchill OFFLINE
GTchill
    Combat Commando
  • 4 posts
Posted Wed Mar 7, 2018 8:08 PM
I've had a lot luck using sketchup. You can add an stl export add-on that makes the process pretty painless. If you decide to go this route I can give you a lot of pointers.
Sent from my VS987 using Tapatalk
#13 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Thu Mar 8, 2018 1:21 PM
thanks ill  check it out (tried real quick but it does not support IE and that's what I use on this pc)
well  got the lid and revision 2  case fully printed
everything seems to be good
for rev 3 (and hopefully the final one )
had to move the power jack hole a bit more to get it centered
make the  opening for the serial port  larger
the lid is perfect  except having to move one mounting hole because I'm having to make the serial connector  opening larger
#14 jonecool OFFLINE
jonecool
    Chopper Commander
  • 123 posts
Posted Thu Mar 8, 2018 2:32 PM
Looks awesome, great job!  I was going to design one for my nanoPEB but glad you've already got an excellent start to it.  If you need another tester, I have a FlashForge Creator Pro and a nanoPEB here, I'd be happy to run a test print here if you want/need.
#15 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Thu Mar 8, 2018 3:47 PM
if you want to try out this  revision (should be about perfect)
and let me know if it fits your peb
any help would be great
ive been printing them at 8 fill  for faster printing  and  even at that low fill the screws stuck and they feel pretty sturdy
im printing a  lid now (hopefully last one lol) at 25 fill  to see if it makes a difference
i might to my final case  at 100 fill just so im certain that the screws are going to have something to hold on to
Edited by discgolfer72, Thu Mar 8, 2018 3:52 PM.
#16 jonecool OFFLINE
jonecool
    Chopper Commander
  • 123 posts
Posted Thu Mar 8, 2018 5:14 PM
Awesome, thank you!  I just sliced it and it's printing now.  Hopefully, in about 5 hours it will be done.  I used 25% infill using ABS.
#17 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Thu Mar 8, 2018 5:31 PM
ugg lol  I need a faster bigger printer  mine is taking  6 hours just for the lid at 25%  pla lol
it was only 140$ at microcenter open box and other than being small and slow it seems to do ok for a cheap machine
http://www.microcent...Mini_3D_Printer
I was a bit ticked   since they website says 5.9x5.9 inch print size and its not  its actually 5.1 inches
thanks let me know if it fits
the one I just printed  was great  but it blocked the serial screw holes  so the one I posted for you I  widened  that opening a bit more
and the  power  plug hole was  off center to the left  a bit so I adjusted it also
made this little doodad  to  help with removing the  cf card lol
Edited by discgolfer72, Thu Mar 8, 2018 5:36 PM.
#18 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Fri Mar 9, 2018 9:28 AM
so
as long as jonecool reports back that it fits on his  nano
I'm calling the above revision final
lol
printed the  final  lid last night and  installed it  and everything looks good
here she is
the lower case I'm using  is before an edit I made to uncover the serial ports mounting holes  , and center the power jack better
but I'm not using the serial port anyway
EDIT
I may have to make the bottom of the shell thinner
it fits great  direct on my  ti99  but  when installing on the  speech synth  it takes a bit of  work to get it to  install
on my speech synth  the  connector door cover has a lip that   sticks out a bit causing the nano to sit at an angle
so I have several options
try and make a slot in the case that that  little lip on the door will rest in
make the  bottom of the case thinner  (don't like this idea its already pretty thin )
take apart my speech synth ad ditch its door  lol
I like 3 the best lol
Edited by discgolfer72, Fri Mar 9, 2018 9:37 AM.
#19 bchamb88 OFFLINE
bchamb88
    Space Invader
  • 11 posts
Posted Sat Mar 10, 2018 5:03 PM
Attached File  IMG_0502.JPG   607.57KB   3 downloads
Fantastic!.... Spent the day printing it and it's just perfect.  You know I also have the nanoPEB version 2 and if the power supply hole was moved a half inch or so then it would work for it too.
Edited by bchamb88, Sat Mar 10, 2018 5:06 PM.
#20 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Sat Mar 10, 2018 5:14 PM
great did the last revision uncover the  serial mounting holes   and is the power jack pretty centered
wich way would the  power jack hole need to be moved to accommodate the ver 2
#21 bchamb88 OFFLINE
bchamb88
    Space Invader
  • 11 posts
Posted Sat Mar 10, 2018 5:25 PM
The serial mounting holes are still tight ( a dremel tool can resolve that)  and the power supply jack is perfectly centered.  The version 2 power jack is about 1/2 inch closer to the serial port.
#22 bchamb88 OFFLINE
bchamb88
    Space Invader
  • 11 posts
Posted Sat Mar 10, 2018 5:46 PM
Attached File  IMG_0517.JPG   825.34KB   2 downloads
On the nanoPEB version 2, the serial port lines up perfectly with version 1.  On version 2, from the right edge of the serial connector to the center pole of the power supply is 15mm.
#23 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Sat Mar 10, 2018 9:09 PM
ok thanks
 so instead of doing 2 different cases
how about a universal case for both
if you want to try this one for your version 2
i  increased the opening for the serial connector some more (hopefully that's enough )
and just made a large square opening for the power jack that should cover both versions
oh also added a link to the little thumb grip i made
makes it  easier to  insert / remove the cf card
i used some double sticky tape that's used for automotive emblems i had , to attach it   (its not going anywhere lol)
Edited by discgolfer72, Sat Mar 10, 2018 9:14 PM.
#24 jonecool OFFLINE
jonecool
    Chopper Commander
  • 123 posts
Posted Sun Mar 11, 2018 12:06 AM
Sorry for not posting back, I had my splicer settings set wrong, I had a bit of a mess as a result -unrelated to your models :)  Re-printing with your latest .stl's tonight.
#25 discgolfer72 OFFLINE
discgolfer72
    Moonsweeper
  • 271 posts
Posted Sun Mar 11, 2018 9:20 AM
i did have one failed print of the lid due to not refreshing the glue stick  on y bed
the middle part of the b  lifted uout and  wrecked the print half way thru
