TI and the MiniPro TL866 EPROM Programmer
100 replies to this topic
#26 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Wed Mar 14, 2018 9:35 AM
AMD AM27C49 adapter
This chip is a direct replacement for the "almost mythical" TMS2564 (the 24-pin version) that is used in the TI DSDD Disk controller and is upwards compatible with the TMS2532 chip.
You will need to build your own adapter but it is a fairly simple build. In this case, the bottom socket is a 28-pin socket with one or more 24-pin sockets stacked on top of it. The sockets are bottom justified (i.e., pins 1, 2, 27, and 28 are uncovered).. The wiring goes like this:
Bottom socket pin #1 to Top socket pin #20 (Vpp)
Bottom socket pin #2 to Top socket pin #18 (A12)
Bottom socket pin #28 to Top socket pin #24 (Vcc)
Bottom socket pin 21 to Top socket pin #21 (A10)
Bottom socket pin # 23 to Top socket pin #19 (A11)
Pins 27 (PGM), 26 (N/C), 22 (OE), and 20 (CE) from the bottom socket are not connected.
You will have to change the Vpp to 13.5V,  Vcc to 5.00V,  Vdd to 5.50V and Pulse Delay to 1000us
Select AMD AM27C64 to use as your template to program the chip.
The important thing to remember when making any adapter is that the bottom socket (i.e., the one plugged directly into the TL866) MUST be the one you use for your programming template. The top socket is the one that the EPROM you wish to program is plugged into.
Edited by atrax27407, Wed Mar 14, 2018 10:38 AM.
#27 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,517 posts
  • Distracted at the Keyboard
Posted Wed Mar 14, 2018 10:39 AM
Here's a link for a built adapter for 27C400, etc. chips:
https://www.ebay.com...sQAAOSwA~VaQhkB
CHUE:
I'm actually trying to do the same thing, which is to use a minpro to program a DiagRom.
You will need an adapter.  I ordered this one:
https://www.ebay.com...872.m2749.l2649
The listing above is just for the bare board, so if you go that route, you'll need to buy the parts and do some soldering. The parts for mine are still en-route from China.
Oh boy, well, glad I can use it, now I have to order one more thing. *sigh* - OK well it is what it is... Thanks felluhs for answering so quickly. :)
#28 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sun Mar 18, 2018 7:16 PM
Here are the directions for programming an ATMEGA1284P.
#29 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Apr 3, 2018 8:41 PM
I have discovered that the TI specifications for the TMS2564 (24 pin package) have an error in the pin outs. The datasheet has A6 listed as both Pin 2 and Pin 15. That is an impossibility. Pin 15 should be Q6. Therefore, it requires an adapter when inserted in a 24-pin socket for the TMS2564 which is used in the TI DSDD FDC. Make the following changes:
AM27C49                                      TMS2564 (24 pin)
Pin 21 (A10)                                  Pin 19 (A10)
Pin 19 (A11)                                  Pin 18 (A11)
Pin 18 (A12)                                  Pin 21 (A12)
#30 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,517 posts
Posted Fri Apr 6, 2018 12:30 PM
My adaptor finally arrived today - Here's the one I got. Hope to use it this weekend sometime.
>>eBay Listing<<
Attached File  2018-04-06 14.24.55.jpg   511KB   7 downloads
#31 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,488 posts
Posted Fri Apr 6, 2018 12:35 PM
Just out of curiosity, for future reference.  If I wanted to update the TIPI in the future with an EEPROM instead of using the EPROM that it comes with.  (I don't have a UV eraser).  Which EEPROM and which adapter should I purchase?
#32 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Apr 6, 2018 2:26 PM
What is the original EPROM?
#33 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,488 posts
Posted Fri Apr 6, 2018 2:36 PM
Oh jeez, I'm not sure.  I remember looking up alternate chips at one time (so I must have had that information at one point) and I even remember a discussion about the pins being different, but that's it.  If Matt does not pop in with the answer, I'll have do a little re-research.
#34 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,488 posts
Posted Fri Apr 6, 2018 2:55 PM
Okay... it looks like a << AMD 27C256 >>
#35 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Apr 6, 2018 3:29 PM
A 29F256 should work. Check the pinouts on the data sheet to make sure.
#36 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,488 posts
Posted Fri Apr 6, 2018 3:43 PM
It looks the same to me.  Can I please get a second set of eyeballs to see that everything matches up and is within tolerances?
The Datasheet is attached below...
#37 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Apr 6, 2018 4:17 PM
The Minipro doesn't list the TMS29F256 as supported. However, you can look for another "flavor" of 29F256 and, if the pin outs and Vpp match, use it as your template. Just uncheck the Chip ID box before you start programming.
#38 pnr OFFLINE
pnr
    Chopper Commander
  • 108 posts
Posted Fri Apr 6, 2018 4:50 PM
Maybe this is common knowledge, but just to be sure: there is an open source program to drive the TL866 from Linux/macOS.
It's on github here: https://github.com/vdudouyt/minipro
#39 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Sat Apr 7, 2018 7:25 AM
Looking at this one, it looks like the TI chip was the only 32K flash chip that built them on the 28-pin package format. The 28F256 uses a 32-pin form factor that is mostly pin-compatible (only the VCC and VPP pins are shifted to pins 32 and 1, with pins 30 and 3 (equivalent to 28 and 1 on the 29F256) as N/C. You would have to bend some pins and run a jumper wire to get VCC to pin 32 in order to use this on a TIPI, and then you have to have enough space to put it in there too--and once you bend the pins you lose the advantage you were looking to get by using a flash chip. This is not really an option unless you modify the TIPI board to jumper between a 32-pin flash chip and the 28-pin EPROM. I'll have to look to see if any other programmers I have support the 29F256, as looking at the two chips, the erase/programming cycle is radically different between the two chip families.
I have done some digging, and I found out that my TOPWIN3000 will program the 29F256. My Advin and Xeltek programmers will program the 29F010 and 040 chips, but don't have the smaller chips from the family in their libraries.
Edited by Ksarul, Sat Apr 7, 2018 9:35 PM.
#40 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Apr 17, 2018 5:18 PM
New upgrade for the MiniPro. Version is now 6.71 which adds some more chips. Also an upgrade to the TL866II. Now up to 7.11
#41 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,517 posts
Posted Wed Apr 18, 2018 2:12 PM
>>eBay Listing<<
I just wanted to report success with this adaptor in programming a 27c400 chip in the miniPro TL866.
#42 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Thu May 17, 2018 6:09 AM
New upgrade to the TL866II - current version is now 7.21
#43 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Sun Jun 3, 2018 3:19 PM
I might have asked this same question 2-3 years ago - is the 29c040 Atmel chip supported?  Swim and I have a number of these chips that we can no longer program.  Our programmers say they will write to them, but seem to screw up the boot sectors and/or lock the boot pages.  Once locked, the chip is pretty much unusable for our needs.
Be great if we could find someone capable of writing to the chip and validating that the full 512k could be programmed.
#44 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Sun Jun 3, 2018 3:31 PM
Are you trying to program the PLCC or the DIP version? ISTR Gazoo used to program the PLCC version all the time with this programmer (he was always having trouble with the 49F040 chips that I use, but that was just a programming socket issue, as I program them on his old programmer all the time using a flap-style socket). I've never tried the DIP variants. . .
#45 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Sun Jun 3, 2018 3:34 PM
DIP variants, 32 pin.  I have a few chips that worked up until I made the mistake of trying to reprogram with my GX4Q programmer.  I know some of the SNUG cards use this chip or a variant.  Maybe there is a compatible 512k chip that could be used in its place?  It has to be programmable by 128 or 256 byte sectors, like the 29c040 or 29c040a.  I thought Winbond made some similar chips, but I have no experience using those varieties.
#46 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Sun Jun 3, 2018 3:47 PM
Give me some time. I just bought some of the ATMEL chips and some of the equivalent WINBOND chips (both in DIP variants). I'll do some testing once they show up. . .as I'll probably need some of these eventually too (I have lots of SNUG cards).
#47 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Sun Jun 3, 2018 4:33 PM
thank you, sir.  Having both varieties will certainly be a good check and balance.
#48 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sun Jun 3, 2018 4:40 PM
The chip list shows the Atmel 29C040 is supported. I doesn't say if it is specifically  the  DIP32 version (that field is blank) but it also supports the TSOP and PLCC configurations. It also supports several configurations of the 29C040A.
#49 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Sun Jun 3, 2018 5:45 PM
Looking at data sheets, the AT49C040A and the Winbond chip both program in 256-byte sectors. The chip list for the programmer also lists the DIP versions, @Atrax27407
#50 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Mon Jun 4, 2018 4:40 PM
New version for the TL866II - now Vn 7.22. Fixed an algorithm and added Spanish language.
