TI and the MiniPro TL866 EPROM Programmer
100 replies to this topic
#51 jonecool OFFLINE
jonecool
    Chopper Commander
  • 136 posts
Posted Mon Jun 4, 2018 6:05 PM
Received my TL866, never used an EPROM programmer until yesterday.  But, it was very easy.  Erased the EPROM with the eraser.  Identified the ERPOM, verified the EPROM reported "FF"'s for all addresses, took the TIP-dsr file and loaded it up in the MiniPro software and wrote the code to the EPROM.
Haven't popped it into the TIPI yet, I'll wait for a bigger upgrade.  But, wanted to make sure I knew how to do it so I'm ready to go when it's time.  I'm sure I'll be able to use it for my classic arcade games at some point.
Thanks to this thread, I'm good to go.  I appreciate it!
#52 helocast OFFLINE
helocast
    Chopper Commander
  • 175 posts
Posted Sat Jun 23, 2018 1:17 PM
My TL866CS has more than paid for itself in three years of use - at last count I have about two dozen adapters I've acquired over the years.
So ..., I pried open my piggy bank to buy just the new base TL866II+ model and cables, hoping all the money I've put into collecting every CS adapter would not be wasted.
I can happily report that the Windows installer also keeps both devices in separate paths as well as distinguishing between the two different USB drivers.
It appears the II+ recognizes the several common adapters I use with my older CS unit (just grabbed a few random/workhorse ones out of my collection). I'll let you know if I find one that doesn't work.
Also very stoked with the new SPI port on the II+ too - versatility is good for future projects!
Still, I think I'll be keeping my older CS unit for those times that I need the 21 volts (vs. 18 volts max) programming ability for older chips. :-D
#53 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sat Jun 23, 2018 2:21 PM
I doubt that the TL866II will do TMS2532s. Even 21V is pushing the envelope a bit. A Vpp of 18V would likely be insufficient.
#54 fabrizio OFFLINE
fabrizio
    Space Invader
  • 16 posts
Posted Wed Jun 27, 2018 7:42 AM
I've used my Minipro to test a lot of different 74LS chips. . .it does this quite well.
ok, it does not work well for me-
#55 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Wed Jun 27, 2018 7:47 PM
I also use my TOPWIN 3000 a lot, as I've found that it tests a lot more chips than the Minipro. . .
#56 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sun Jul 1, 2018 11:11 AM
New upgrade for the TL866II - now at Vn 7.30. Fixed a couple of errors and added some more chips.
#57 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Jul 20, 2018 7:25 PM
 New upgrades for both products. The TL866CS is upgraded to Vn 6.81 and the TL866II is upgraded to Vn 7.32 with several more chips added. Also, there is a piracy notice on the site to identify
"cloned" programmers.
Edited by atrax27407, Tue Jul 24, 2018 7:16 AM.
#58 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Jul 24, 2018 7:18 AM
New upgrade for the TL866CS/A. I don't see any difference in what has been added or changed. However, it is now Vn 6.82 and dated 7/24/18.
#59 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Thu Jul 26, 2018 7:39 AM
Jim Fetzner suggested that, since there is no obvious reason for the version update from 6.81 to 6.82, there might be some 'security" code in Vn 6.82. It is indeed possible since the version change occurred simultaneously with the piracy announcement. It is likely that the latest version (and subsequent versions) will include code that is either hostile or destructive to "cloned" copies of the TL866. I can't blame the manufacturer. Check the pictures to make sure you have the genuine article!
Edited by atrax27407, Thu Jul 26, 2018 7:40 AM.
#60 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Thu Aug 23, 2018 7:06 AM
The TL866II has been upgraded to Vn 7.35. A bunch of chips added and the total is above 15,000.
#61 arcadeshopper OFFLINE
arcadeshopper
  • 4,066 posts
Posted Tue Aug 28, 2018 4:23 PM
yes but it doesn't work on modern os's.
#62 Ksarul OFFLINE
Ksarul
  • 5,027 posts
Posted Thu Aug 30, 2018 7:41 AM
I use the TOPWIN on Windows 7, and version 8 of the Topall software works with WIN8 and WIN10 as well.
#63 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Thu Sep 6, 2018 7:58 AM
TL866II has been updated to Vn 7.38 on 9/5/18. A bunch more chips added.
#64 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sun Sep 30, 2018 9:04 PM
TL866II has been updated to Vn 8.00 on 09/30/18. More chips added.
#65 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Oct 9, 2018 10:53 AM
tl866II has been updated to Vn 8.01 effective 10/9/18.
#66 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Wed Oct 17, 2018 6:01 PM
TL866II has been upgraded to Vn 8.02 as of 10/16.
#67 arcadeshopper OFFLINE
arcadeshopper
  • 4,066 posts
Posted Thu Oct 18, 2018 6:35 PM
got mine in the mail today and tried getting 8.02.. and winderz defender says "no"
https://www.microsof...atid=2147725998
#68 RickyDean OFFLINE
RickyDean
  • 1,022 posts
Posted Fri Oct 19, 2018 5:59 AM
Are you using the Windows 10 version, I just downloaded with Windows 7 and there was no issues. Just updated the definitions yesterday morning.
#69 arcadeshopper OFFLINE
arcadeshopper
  • 4,066 posts
Posted Fri Oct 19, 2018 7:13 AM
Yep 10
Sent from my LG-H872 using Tapatalk
#70 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Oct 19, 2018 8:16 AM
TL866A/CS has been updated to Vn 6.85 on 10/19/2018. A couple of fixes and an addition. Now supports 14337 chips. FYI, you might have to "negotiate" with Windows Defender and Norton since the software presents a reputation issue since it is a new software package.
#71 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Sat Oct 20, 2018 11:44 AM
TL866II has been updated to Vn 8.05 as of 10/20/2018. Total supported chips at 15360
Edited by atrax27407, Sat Oct 20, 2018 12:15 PM.
#72 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Oct 23, 2018 6:20 AM
TL866II updated to Vn 8.07  on 10/23/18 - total chips: 15401
#73 Southerner OFFLINE
Southerner
    Combat Commando
  • 3 posts
Posted Fri Oct 26, 2018 12:40 AM
I thought version 8.xx was for the TL866 plus and not for the TL866A or TL866CS?  Or is the TL866 II the same as the TL866 plus?
#74 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Fri Oct 26, 2018 5:53 AM
The series starting with Vn 7.0 are for the TL866II which is the same as the TL866 plus. It is designated as the TL866II on their website.
#75 atrax27407 OFFLINE
atrax27407
  • 1,178 posts
Posted Tue Oct 30, 2018 7:43 AM
The TL866II has been updated to Vn 8.08 (10/30/18) with more chips added. Total is up to 15411.
Edited by atrax27407, Tue Oct 30, 2018 11:23 AM.
1 user(s) are browsing this forum
1 members, 0 guests, 0 anonymous users
