TI and the MiniPro TL866 EPROM Programmer
148 replies to this topic
#101 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Mon Jan 7, 2019 9:12 AM
I got the following disheartening message from SEE-IC. They had some TL866CS units listed on eBay.
Hello there,
This item is actually not available.
We are going to delete the listing.
Genuine TL866CS is not available now.
If you have any other question, pls be free to let us know.
Thanks & Regards
#102 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Wed Jan 23, 2019 11:40 AM
Effective 01/23/19 TL866II is upgraded to Vn 8.30. Several more chips added and several bug fixes.
Edited by atrax27407, Fri Jan 25, 2019 12:40 PM.
#103 arcadeshopper OFFLINE
arcadeshopper
  • 4,406 posts
Posted Wed Jan 23, 2019 3:46 PM
Effective 01/23/19 TL866II is upgraded to Vn 8.30. Several more chips added and several bug fixes.u
FINALLY now i get to see if they fixed the virus false alarm
#104 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Wed Jan 23, 2019 4:11 PM
Likely won't have any effect. The problem is not the download from Autoelectric itself but rather the email/virus detection program that you are using and don't like .rar archives or .chm files within the archive (i.e., gmail). Another problem is anti-virus programs that reject the archive because of reputation violation (i.e., no experience with the program because it is new). Most of the anti-virus programs allow you to override the quarantine and run the program anyway - Norton does. See post #16
Edited by atrax27407, Fri Jan 25, 2019 12:42 PM.
#105 arcadeshopper OFFLINE
arcadeshopper
  • 4,406 posts
Posted Fri Jan 25, 2019 1:46 PM
they fixed it..
Greg
#106 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Wed Mar 6, 2019 9:25 PM
The old 2716 (2K) EPROMS (NOT TMS2716 which is incompatible with other 2716s) are getting a bit difficult to find and can be relatively expensive. The Chinese "rogue" suppliers have them but they are usually trash. For example, I ordered five of them a while ago and four of the chips were counterfeit and would not program. There is however, a substitution that can be made. This tip comes courtesy of Jim Fetzner:
Replacing a 2716 with a 2732 EPROM
A 2732 EPROM is backwards compatible – almost pin for pin – with a 2716 EPROM. There are only minor differences between the two chips. Pin 20 on the 2732 is G*/VPP  and G* on the 2716. That means there is no problem between the two of them signal-wise. Pin 21 is A11 on the 2732 and Vpp on the 2716. Again, there are no problems there as well. The direct substitution is a “no brainer” as long as one only programs the first 2K of the 2732 chip since A11 is held low when in a circuit.
Both of the EPROMs are a 24-pin package and all of the other signals with the exception of those two pins are identical. Since you aren’t using the one address pin that is different, and it is always held low when in circuit, there won’t be any issues with it at all.
The only consideration is to set the program range of the 2732 as >0000 to >07FF (or 2K) before starting the programming procedure on the MiniPro . This will restrict all of the code to the first 2K of the 2732 and it will function as a 2716.
#107 BeeryMiller ONLINE
BeeryMiller
    Dragonstomper
  • 957 posts
Posted Sat Mar 9, 2019 9:54 AM
Got a question.  I've got an original Myarc 512K card eprom without the Myarc XB Eprom upgrade.  It can not be read.
Can I erase that Eprom, and burn an image onto it that has the XB support?  What I am not sure is whether because it can not be read/locked, that erasing the eprom will allow subsquent write/read/verify.
What I am wanting to do is to change the boot path of Myarc Basic to TIPI.128KOS, instead of DSK1.128KOS.
Thanks for the feedback.
Beery
#108 RickyDean OFFLINE
RickyDean
  • 1,141 posts
Posted Sat Mar 9, 2019 12:40 PM
I am not the expert here of course, Beery, but it should be a piece of cake. If you are using a mini pro, just be sure to remove the check from the id field if it is not a listed eprom. And be sure the eprom holds the amount of data, not to small, which you are more than likely aware of.
#109 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Sat Mar 9, 2019 12:54 PM
I have several different "flavors" of Myarc 512K EPROMS. Is there a version number on the one you have? Maybe I can match it. If so, it should be a relatively easy chore to edit the code with a hex editor and re-burn an EPROM. The DSR is an 8K DSR so you can use most any 2764 chip for it.
Edited by atrax27407, Sat Mar 9, 2019 1:06 PM.
#110 BeeryMiller ONLINE
BeeryMiller
    Dragonstomper
  • 957 posts
Posted Sat Mar 9, 2019 4:12 PM
I've got an image, I just want to make sure before I erase an eprom that was pulled from the card that was working, that with an erasure, I could still reprogram it.  If there was some kind of fuse that prevented reading, I wanted to make sure I did not trash the eprom from ever being useable again.
I don't know how the chip is made "not readable", but want to make sure a chip that was "not readable", could be erased and reprogrammed.
#111 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Sat Mar 9, 2019 5:38 PM
Probably - try it and see.
#112 arcadeshopper OFFLINE
arcadeshopper
  • 4,406 posts
Posted Wed Mar 13, 2019 4:32 PM
eproms are readable.. or they are broken.. so likely.. its broken  easily replaced by a 2764 or 27128 burned 2x with the same image
Greg
#113 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Thu Mar 14, 2019 12:38 PM
Not completely accurate - EPROMs have an encryption byte that, when set, renders them unreadable by an EPROM programmer. When they are erased, the encryption byte is also erased and the chip can be re-used. There is a way around the encrypted chip dilemma, however. Tony McGiovern wrote a program years ago that will do a non-destructive read of the DSR of a card or peripheral device "in situ".  All you need is the CRU address and the file length(which can be easily changed in the source code). It runs exclusively from F'WEB and saves a complete eprommable file to disk. In essence, you are indirectly reading the EPROM.
Edited by atrax27407, Thu Mar 14, 2019 12:52 PM.
#114 BeeryMiller ONLINE
BeeryMiller
    Dragonstomper
  • 957 posts
Posted Thu Mar 14, 2019 12:53 PM
OK, thanks for that information.  I'm probably going to move some hardware around this weekend to setup a TI with a TIPI and Myarc 512K card with a FinalGrom 99.
Beery
#115 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Fri Mar 15, 2019 11:22 AM
SEE-IC has 55 TL866CS eprommers listed on eBay. I don't know if they are original, authentic units or counterfeit. However, SEE-IC has proven to be reliable in the past as far as chips are concerned, Caveat Emptor. Contact the seller for details. I don't know if this is a new listing or a re-post of the one taken down earlier.
https://www.ebay.com...p8AAMXQ8odRHahe
Edited by atrax27407, Fri Mar 15, 2019 11:44 AM.
#116 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Fri Mar 15, 2019 6:58 PM
Observe the software version shown--it is pretty old. . .
#117 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Fri Mar 15, 2019 7:18 PM
If the software version # is correct and goes with the hardware, these would be legitimate units. That particular version (5.90) is from 3/4/2013 when the TL866CS was still in active production by AutoElectric. These may very well be NOS units.
#118 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Thu Mar 21, 2019 9:05 AM
There is a new notice on the TL866 site.It appears that A:LL of the TL866CS/A units on eBay, Alibaba, etc. are counterfeit. The original manufacturing run by Autoelectric has been recalled and destroyed. and they are taking enforcement measures against sellers on those sites.
#119 RickyDean OFFLINE
RickyDean
  • 1,141 posts
Posted Thu Mar 21, 2019 9:13 AM
Wow!!! :-o  :-o
#120 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Thu Mar 21, 2019 9:27 AM
Here is the entire notice (complete with grammatical errors in Chinglish):
Notice : Old model TL866A/CS programmer is off the shelf
1. We has already recycled and destroyed the TL866A and TL866CS programmers that are not sold by authorized dealers. If there are some TL866CS/A programmers in stock, please contact us for return processing. (return time limit: 2019-6-30 )
2. The stores immediately stopped selling the old TL866CS/TL866A programmer. At the same time, all e-commerce platforms (Taobao, Ebay, AliExpress) are off the shelves.
3. Please note that the TL866A/CS be stopped delivery in February 2018. It can be confirmed that the TL866CS TL866A products sold on e-commerce platforms such as AliExpress, Ebay and Taobao are all pirated and counterfeit products. We are proceeding to defend the rights. At the same time, warn the user, do not buy the old TL866A/CS model by listening to letter.
Haikou Xingong Electronics Co.,Ltd
2019-3-16
Edited by atrax27407, Thu Mar 21, 2019 9:28 AM.
#121 electricfling OFFLINE
electricfling
    Space Invader
  • 15 posts
Posted Sun Mar 24, 2019 1:17 PM
Edited by electricfling, Sun Mar 24, 2019 1:19 PM.
#122 electricfling OFFLINE
electricfling
    Space Invader
  • 15 posts
Posted Sun Mar 24, 2019 1:19 PM
Is there a real replacement or a pin-compatible alternative for the chip AT49F040-90JC?
The chip is hard to come with, contains lead and is not RoHS compliant.
I got the Mini Pro and two pieces of PCB Fetzner Ubergrom board and will buld my own Cartridge. The problem is that the 1284P is easy to get, but the AT49F040 ... chip is not.
Nice greetings
Gernot
#123 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sun Mar 24, 2019 2:18 PM
You can use the 29F040 as a suitable substitute for the 49F040. Pinout and voltages are the same.
I use the 49F040 mainly because I still have something in the range of 1,000 of them to supply parts for my projects.
Edited by Ksarul, Sun Mar 24, 2019 2:19 PM.
#124 electricfling OFFLINE
electricfling
    Space Invader
  • 15 posts
Posted Sun Mar 24, 2019 3:49 PM
Thank you for  the information.
is good for me, because otherwise the project Self-Catrige would be over again.
#125 atrax27407 ONLINE
atrax27407
  • 1,272 posts
Posted Mon Mar 25, 2019 6:34 AM
TL866II (or plus) is now updated to Vn 8.33. Multiple new chips added.
