2600 Works for Split Second then Dies? Help Please
6 replies to this topic
#1 BlimpPixel OFFLINE
BlimpPixel
    Star Raider
  • 60 posts
Posted Fri Mar 9, 2018 8:09 AM
Here's a problem I've not seen before.  I have a 4 switch that once you turn it on works brilliantly... for not even a full second.  It then goes wonky and/or dies.  I had a new voltage regulator sitting around, so I figured why not throw that on.  I know a bad one can make a system crash, usually after more like 15 minutes but I figured why not try it.  But it made no difference.
If I'm lightening fast, I can hit the Reset switch in time and see that the game loads successfully.  Channel select switch works.  Color/B&W switch works.
Any ideas before I continue throwing crap at a wall and seeing what sticks?
Thanks!
#2 Nathan Strum OFFLINE
Nathan Strum
  • 8,250 posts
  • Enjoying a sandwich
Posted Fri Mar 9, 2018 10:42 AM
This affects all games?
#3 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,549 posts
  • Medieval Mayhem
Posted Fri Mar 9, 2018 10:56 AM
Might be cracked solder (reply #4) on the power socket.
#4 BlimpPixel OFFLINE
BlimpPixel
    Star Raider
  • 60 posts
Posted Fri Mar 9, 2018 11:03 AM
It effects all games, yes.
I reheated the joints on the power socket for good measure, but it's not that.  It's not really losing power, it's almost like it just loses the ability to read a game.  It responds the way a non-functioning games does.  Either a black screen or a bunch of waves lines, or maybe a combination.
It may be worth saying that if I turn it off and back on immediately, the game probably won't load at all, even for a split second.  But if I wait a few moments, it will.
#5 BlimpPixel OFFLINE
BlimpPixel
    Star Raider
  • 60 posts
Posted Fri Mar 9, 2018 10:09 PM
In case anyone is curious, I continued throwing more crap at the wall and something did indeed stick eventually.  Turns out it was the CPU chip.  Very interesting.
#6 Nathan Strum OFFLINE
Nathan Strum
  • 8,250 posts
Posted Fri Mar 9, 2018 10:17 PM
Glad you got it sorted out. I was about to suggest you might check the chips. I had to swap mine out about a year ago..
#7 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Fri Mar 9, 2018 10:29 PM
I have had so many bad cpu's refurbing 2600's its usually the first ,and  about 8 out of 10 times, the last chip I swap, I think they get a little toasty, it couldnt hurt to slap a little self stick heat sink on the center of them
