TI-99/4A Stuff - The "what I'm looking to buy" topic.
65 replies to this topic
#1 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,096 posts
Posted Fri Mar 9, 2018 4:55 PM
Eventually we all want a specific item for our TI setups.  Problem is, sometimes no matter how much searching you do, the wanted item may never show up.  This topic is to "put the word out" that you are looking for something specific.  Who knows, the guy reading it may have one lying around that they no longer need or want.
#2 Schmitzi OFFLINE
Schmitzi
  • 4,317 posts
  • ToXiC
Posted Fri Mar 9, 2018 4:57 PM
I want a SCSI controller :)
and I want to break free ♪♪
#3 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,096 posts
Want To Buy - A dust cover for my Texas Instruments program (cassette) recorder.  Has to be in good shape (not yellowed).
Please send a PM if you have one to you want to get rid of.  --- Thanks.
#4 acadiel ONLINE
acadiel
  • 1,390 posts
  • www.hexbus.com
Posted Fri Mar 9, 2018 5:50 PM
Need a working DSDD full height (or a half height and a blank) I can retrofit into my TI external SSSD disk enclosure. :)
#5 OX. OFFLINE
OX.
    Moonsweeper
  • 497 posts
Posted Fri Mar 9, 2018 6:13 PM
A Nanopeb,I'm just not willing to pay 79 Euros for what looks like an inferior product from Stargames which looks like the only European supplier available and besides that the components that make up the nanopeb are cheap as chips to buy.
#6 tuf OFFLINE
tuf
    Chopper Commander
  • 232 posts
Posted Fri Mar 9, 2018 6:15 PM
I'd be interested in a case for either the NanoPeb or the FGROM99 or both.  Conversely I've got the older FR99 card available and it's got a case :)
#7 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,096 posts
Posted Fri Mar 9, 2018 6:29 PM
I think ArcadeShopper gets these from Ralph and sells these on his website.
Ralph also makes NanoPEB and CF7 cases as well that Greg might have in stock as well.
#8 tuf OFFLINE
tuf
    Chopper Commander
  • 232 posts
Posted Fri Mar 9, 2018 6:33 PM
On the off chance someone has a spare I'd be interested - I've already ruled out the new ones as out of budget :)
#9 Arnuphis OFFLINE
Arnuphis
    Moonsweeper
  • 306 posts
  • Loading...Please Wait
Posted Fri Mar 9, 2018 6:43 PM
A FG99 and case.
Case for the NanoPEB
#10 digdugnate ONLINE
digdugnate
  • 1,394 posts
Posted Fri Mar 9, 2018 6:49 PM
actually, i have been looking for some plastic-type buttons for my FG99.
it's one of the preassembled boards, but I have it inside a old TI cart that sacrificed its life for the cause; the holes are drilled to access the switches, but right now I'm using a bamboo skewer to push the switches on the board ;)
they'd need to be about the diameter of the switches, and roughly the same height as the front side of a TI cart.  (if that helps)
#11 jedimatt42 OFFLINE
jedimatt42
  • 1,633 posts
Posted Fri Mar 9, 2018 10:23 PM
I believe the 3D printed cases are coming from c0d3m4str
-M@
#12 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,096 posts
Posted Fri Mar 9, 2018 11:09 PM
-M@
Oh gawd, I know that!  I even made a couple of YouTube videos about his stuff too (as shown below).  What can I say, 'memory issues' again.  :skull:
#13 Ed in SoDak OFFLINE
Ed in SoDak
    Moonsweeper
  • 412 posts
Posted Fri Mar 9, 2018 11:29 PM
Being a cheap bastidge, I've used short bits of tubing to contact the switch and clear the case enough to work. If the microswitch ends in a little post sticking up, a small inner diameter tube might grip the post well enough. Or fill the end of the tube with something. Even a short dowel might work. Keep it in the case with an o-ring on the tube inside. Not too elegant but might be better than stabbing semi-blindly though the hole with a stick.
Or, yeah, actual buttons. :ponder:
#14 Romko343 OFFLINE
Romko343
    Space Invader
  • 37 posts
Posted Fri Mar 9, 2018 11:48 PM
Hello, does anyone know how much a PGRAM+ card can go for ? I have one and need to sell it.
#15 Opry99er OFFLINE
Opry99er
  • 9,717 posts
Posted Fri Mar 9, 2018 11:59 PM
Hmmm.... Id love to tell you that theyre cheap and then steal it off you for a song but theyre rare and desirable. :)
If its functional, in good shape, maybe docs(?) youre looking at some bucks... probably not as much as a GRAM Kracker, but definitely more than a hill of beans. :)
Ksarul can give you historical numbers, but Id say youre looking somewhere between a benji and dos benjis... eBay will get you the best price, but I bet youll have some takers on here.
Good luck... wish I was in the mix. :)
#16 arcadeshopper OFFLINE
arcadeshopper
  • 3,355 posts
Posted Sat Mar 10, 2018 1:35 AM
wanted: all ti stuff ;)
specifically tho;
a hfdc or scsi ctlr for the Geneve so i can use my other hfdc on the 4/a
Geneve memory card(s)
sidecar disk controller
cp/m card (either one morningstar or foundation)
forti card
#17 arcadeshopper OFFLINE
arcadeshopper
  • 3,355 posts
Posted Sat Mar 10, 2018 1:36 AM
i can 3d print buttons.. those are easy
#18 digdugnate ONLINE
digdugnate
  • 1,394 posts
Posted Sat Mar 10, 2018 4:37 AM
Sweeet. I'll PM later :-)
#19 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,494 posts
  • Distracted at the Keyboard
Posted Sat Mar 10, 2018 7:06 AM
Almost everything I want is readily available but a bit pricey. Especially when it all adds up.
Modded rs232 card for PEB.
1MB SAMS for PEB.
3D printed cases for side cart 32k (x2), and nanPEB.
Dust cover for console.
BreakFree cart.
Things I want that aren't out yet but are in the works.
TiPi for PEB.
Dragon's Laire cart.
Things I want that no one has made yet.
3D printed case for TiPi side cart.
Things I want that could help me get others things I want.
3D printer.
Winning lotto ticket for tens of millions.
Edited by Sinphaltimus, Sat Mar 10, 2018 7:07 AM.
#20 Casey OFFLINE
Casey
    Chopper Commander
  • 246 posts
Posted Sat Mar 10, 2018 9:57 AM
I actually would love a beige case for the NanoPEB to match my beige console.  I know the beige consoles don't get a lot of love around here, but I really do love mine.
#21 arcadeshopper OFFLINE
arcadeshopper
  • 3,355 posts
Posted Sat Mar 10, 2018 10:35 AM
Modded rs232 card for PEB.   Mod your own the daughterboard is only 10$ parts are not that much soldering is not hard the worst part is removing the original rom
1MB SAMS for PEB.  80 bucks is not that pricey for a built one or again, build your own its not that bad of soldering either
Dust cover for console. i should really start carrying these, I had a guy talking about making them
BreakFree cart.  me or jim are the only source for these
#22 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,494 posts
Posted Sat Mar 10, 2018 11:05 AM
*I don't currently own an RS232 card for my PEB.
1MB SAMS for PEB.
80 bucks is not that pricey for a built one or again, build your own its not that bad of soldering either.
*Trying to get 80 bux approved by my handler to cover a single retro-computer purchase is not an easy task. Then add the price of everything else to that.
*That would be great, and a less expensive upgrade on my path to having it all. :)
BreakFree cart.
*Yep I know. Well i didn't know about Jim, I thought you were the only game (hehe see what I did there?) in town. ;)
what typically happens is, I get funds and am about to buy something but electronic parts here, a tool there, seems to take priority. with all the TI stuff mentioned above, it's always, *maybe next paycheck*.. My handler takes the time to add these things up and show me what I've spent at the end of the month. That usually puts a damper on the $30 and up purchases. I have a small budget for these things.... I should probably get over my hoarding dilemma and sell things to get more things.
#23 Andrewmacattack OFFLINE
Andrewmacattack
    Space Invader
  • 20 posts
Posted Sat Mar 10, 2018 12:03 PM
Would love a boxed MINER 2049ER and sealed boxed ATARISOFT POLE POSITION.
#24 mdilling OFFLINE
mdilling
    Space Invader
  • 11 posts
Posted Sat Mar 10, 2018 1:23 PM
I would love to obtain a TI Solid State Thermal Printer PHP1900. It was my very first of many many printers and deserves a place of honor.
#25 Schmitzi OFFLINE
Schmitzi
  • 4,317 posts
  • ToXiC
Posted Sat Mar 10, 2018 3:16 PM
ah, I would like to find some of the thermo paperrolls for the PHP1900 printer (or similar working ones)
