OX. Posted March 11, 2018 Share Posted March 11, 2018 Is it possible to do a DIY build? Does it need the external 5V power source if it's the only item on the sidecar slot? Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 11, 2018 Share Posted March 11, 2018 Definetely needs the 5 Volts (+ on inside pin), AND a regulated (!!) power supply. The more mA the better (maybe 1000-2000 mA is good) Don´t buy a cheap one. And yes, with the wrong or a cheap and unregulated PSU it supports sudden DIY (Destroy it yourself), I can tell you Quote Link to comment Share on other sites More sharing options...
OX. Posted March 11, 2018 Author Share Posted March 11, 2018 Definetely needs the 5 Volts (+ on inside pin), AND a regulated (!!) power supply. The more mA the better (maybe 1000-2000 mA is good) Don´t buy a cheap one. And yes, with the wrong or a cheap and unregulated PSU it supports sudden DIY (Destroy it yourself), I can tell you Why, if other sidecar peripherals are made to use the TI's power can't a nanopeb be made to do the same? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted March 11, 2018 Share Posted March 11, 2018 I believe there are posted mods to make that modification. Note, however, the Speech Synthesizer does not pass power through to its expansion port. The PEB "firehose" cable is powered by the PEB. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 11, 2018 Share Posted March 11, 2018 Is it possible to do a DIY build? There is no DIY kit for the nanoPEB. ...lee Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 11, 2018 Share Posted March 11, 2018 Is it possible to do a DIY build? Does it need the external 5V power source if it's the only item on the sidecar slot? No yes 5v REGULATED many have tried screwing around with cheap power supplies and they regretted it and OPB is only made by him Sent from my LG-H872 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 11, 2018 Share Posted March 11, 2018 yes, better do not fry ahh try this. Quote Link to comment Share on other sites More sharing options...
OX. Posted March 11, 2018 Author Share Posted March 11, 2018 So if a 5v regulator was fitted to the nanopeb and the power passed through from the TI there would be no issue? A DIY build of a Nanopeb looks quite simple so I'm surprised nobody has tried to make their own, although if the cpld code isn't freely available then I can see why. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 11, 2018 Share Posted March 11, 2018 So if a 5v regulator was fitted to the nanopeb and the power passed through from the TI there would be no issue? A DIY build of a Nanopeb looks quite simple so I'm surprised nobody has tried to make their own, although if the cpld code isn't freely available then I can see why. Tapping console power has been described in many threads on this forum. Here are a couple: Stuart Sparkdrummer ...lee 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 11, 2018 Share Posted March 11, 2018 So if a 5v regulator was fitted to the nanopeb and the power passed through from the TI there would be no issue? A DIY build of a Nanopeb looks quite simple so I'm surprised nobody has tried to make their own, although if the cpld code isn't freely available then I can see why. Yep you can take the console apart and use the 5 volts or put a connector on the back of your speech synthesizer if you have one and steal 5 volts from that that's already regulated from the ti power supply the only issue is that the ti power supply has a limited amount of amperage in the more stuff you plug into it the more likely you are to underpower something Sent from my LG-H872 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 11, 2018 Share Posted March 11, 2018 The developer has been working on a new version of the NanoPEB. This one will not have a RS232 built into it, but he is also developing a stand alone RS232 for it. This reminds me I need to reach out to him again to find out the latest status. As it was supposed to be released late in 2017. 1 Quote Link to comment Share on other sites More sharing options...
