Classic 99 Freakouts
10 replies to this topic
#1 unhuman OFFLINE
unhuman
  • 1,224 posts
Posted Sun Mar 11, 2018 8:47 AM
I don't know if this is Classic99 or my just doing crazy stuff (probably not), but it seems like Classic99 is crashing quite a bit, particularly when I paste.
I can't restart - when entering XB, it freaks out again, with similar screen + beeping and booping.  I'm a Notepad developer, so cut & paste means I don't lose much.  :)
I also intermittently get line too long.  Sometimes I can past and it works other times, not.  This seems to happen when lines are between 5 & 6 screen lines long.
I get unresponsive screens like this:
Attached File  Classic99Crash.jpg   293.67KB   3 downloads
Edited by unhuman, Sun Mar 11, 2018 8:51 AM.
#2 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,517 posts
  • Distracted at the Keyboard
Posted Sun Mar 11, 2018 10:19 AM
can you share what exactly you are pasting?
#3 Lee Stewart ONLINE
Lee Stewart
  • 3,872 posts
Posted Sun Mar 11, 2018 10:20 AM
In XB, you are using “Paste XB”, right?  There is a problem with longer lines otherwise.
...lee
#4 unhuman OFFLINE
unhuman
  • 1,224 posts
Posted Sun Mar 11, 2018 11:03 AM
No, I can't share.  Otherwise you might be able to guess what I'm working on.
It's interrmittent.  And, yes, Paste XB.  :)
#5 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,870 posts
  • Technology Samurai
Posted Sun Mar 11, 2018 11:28 AM
Somebody sign the NDA :)
#6 Tursi OFFLINE
Tursi
  • 5,426 posts
  • HarmlessLion
Posted Sun Mar 11, 2018 9:45 PM
Usually a continual freakout is caused by corruption in scratchpad RAM - the GPL startup is not 100% solid and can have trouble with certain values. A cold reset instead should clear that.
I've not run into any issues as you describe in any other way, but if you're using user interrupt vectors, that's where a lot of the console ROM issues occur. Paste XB assumes a normal scratchpad layout and hacks a couple of vectors to allow the longer lines... you can try normal paste if you don't have long lines. Paste XB isn't guaranteed to work if you're using user interrupts or any language except the built-in TI Extended BASIC.
You can also try pasting the memory dumps when it's in this state - we could use those to try and reproduce your issue. But otherwise not much we can do. ;)
#7 Tursi OFFLINE
Tursi
  • 5,426 posts
  • HarmlessLion
Posted Sun Mar 11, 2018 9:46 PM
And, as always a debug log capture would be useful... you can copy and paste right out of the debug window... :)
#8 unhuman OFFLINE
unhuman
  • 1,224 posts
Posted Mon Mar 12, 2018 6:44 AM
Thanks Tursi!  I'm not doing anything special, other than having some long lines....  I had one go in that actually made it to the 7th line.  Unbelievable!
#9 RXB OFFLINE
RXB
  • 3,460 posts
Posted Mon Mar 12, 2018 9:43 AM
Are you using RXB as unlike other XB versions made it will accept longer lines.
At video 7:10 is the Version and LONG LINE DEMO
Edited by RXB, Mon Mar 12, 2018 9:47 AM.
#10 unhuman OFFLINE
unhuman
  • 1,224 posts
Posted Mon Mar 12, 2018 11:10 AM
No.  One day I'd like to experiment with it, but I'm just trying to leverage my nostagia.
#11 Tursi OFFLINE
Tursi
  • 5,426 posts
  • HarmlessLion
Posted Mon Mar 12, 2018 7:02 PM
You may just be corrupting scratchpad RAM. :) I thought the new limits I entered were safe but it's a hack, and not guaranteed to be. ;)
