poorcomputerman Posted March 20, 2018 Share Posted March 20, 2018 I accidently posted this in another section. Is this the ram needed for an 800xl? Need to try to fix black screen. https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&pa=41662&productId=41662 Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 20, 2018 Share Posted March 20, 2018 That should do. Brand not mentioned but no business wanting to remain open would go pushing NOS parts from MT or other known bad brands. Quote Link to comment Share on other sites More sharing options...
ACML Posted March 21, 2018 Share Posted March 21, 2018 (edited) I accidently posted this in another section. Is this the ram needed for an 800xl? Need to try to fix black screen. https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&pa=41662&productId=41662 Looks like from the data sheet that its 256 cycle refresh (4ms). I not 100% sure, but I think you have to have the newer ANTIC C021697 that has the 8 bit refresh counter. The older ANTIC C012296 only has the 7 bit refresh counter and needs 128 cycle refresh (2ms). Look up the refresh on the data sheet for the RAM you are replacing. Who made the original RAM? What's it say on top of the RAM chips? Edited March 21, 2018 by ACML 1 Quote Link to comment Share on other sites More sharing options...
poorcomputerman Posted March 21, 2018 Author Share Posted March 21, 2018 It does have the co21697 Antic. I will check the ram manufacturer. I wonder if the Antic is bad. Pins look a little white as does side of the chip. Sceen is black but you can also see slight green texture. When I ran it without antic screen was black. Quote Link to comment Share on other sites More sharing options...
