Entry 2018: Boot Hill
89 replies to this topic
#1 digress OFFLINE
digress
  • 1,124 posts
Posted Wed Mar 21, 2018 9:51 AM
I'm going to attempt to port my recent colecovision game "Boot Hill" to intybasic. I'm not sure if I can do it as i'm less familiar with intybasic than c++ but I'll give it a try. Here is some mockups. I'll probably have to go with the tiny characters due to need more room to roam around the screen.
mockup higher res
mockup V2  higher res
Edited by digress, Wed Mar 21, 2018 9:55 AM.
#2 fsuinnc OFFLINE
fsuinnc
    Moonsweeper
  • 488 posts
Posted Wed Mar 21, 2018 8:08 PM
Great classic game.  Excellent choice.  Good luck.
#3 emerson OFFLINE
emerson
    Chopper Commander
  • 170 posts
Posted Fri Mar 23, 2018 9:23 PM
It seems like this game could port fairly well to Intellivision. 16 line sprites might be your friend here. I posted some code in the "Slalom" thread for scrolling background tiles that may help with the wagon. Looking forward to an update!
#4 digress OFFLINE
digress
  • 1,124 posts
Posted Sun Mar 25, 2018 4:32 PM
Ok I got some stuff working. I think I can get the majority of things working in intybasic. Had to figure my way to convert some functions into GOSUBS and the like but they seem to be working good so far.
here is a video of what I got on the go so far:
#5 emerson OFFLINE
emerson
    Chopper Commander
  • 170 posts
Posted Sun Mar 25, 2018 5:21 PM
Cool! The music sounds really good.
#6 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,836 posts
  • Coding something good
Posted Sun Mar 25, 2018 7:12 PM
Nice graphics and music! :)
I would suggest to used Color Stack mode in options screen in order to be able to use lowercase letters. Also to abbreviate your menu items using other words.
#7 Rev OFFLINE
Rev
    IntellivisionRevolution
  • 16,405 posts
Posted Sun Mar 25, 2018 10:12 PM
Pretty neat, part'ner
#8 digress OFFLINE
digress
  • 1,124 posts
Posted Mon Mar 26, 2018 7:53 AM
will do with the lower case letters and trunicated text.  Nice programming language. I might even be able to then port the basic final program to atari 7800.
I get an occasional glitch with the mode seeming to change back to color stack mode without me doing it and the colors are messed up. . I temporarily added the foreground/background mode into the main loop to keep it from showing too often.
Now i need to finish getting the a.i. in there.
#9 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,821 posts
  • Busy bee!
Posted Mon Mar 26, 2018 8:10 AM
This is probably a bug in your code because IntyBASIC should remain in the mode you last set it to. Personally, I would try and track the bug down now instead of applying a sticking plaster that will come back to bite you down the line.
#10 nanochess OFFLINE
nanochess
  • 5,836 posts
Posted Mon Mar 26, 2018 8:19 AM
This means some of your screen writing code is using trash as input and writing to address $0021, the result is the change of video mode.
I think you can trap writes to a certain address using jzintv integrated debugger.
#11 digress OFFLINE
digress
  • 1,124 posts
Posted Mon Mar 26, 2018 11:20 AM
I tracked it down. It was caused by the psg playback call
ON FRAME GOSUB play_sound
When I disable it the problem goes away. So it might be my sound data needs fixing.
confirmed when I switched the sound data it went away also. So it doesn't like something in my song.
#12 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,821 posts
  • Busy bee!
Posted Mon Mar 26, 2018 11:25 AM
:cool: I'm glad you took the time to track it down.
#13 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
  • The P-Machinery AGE is almost here!
Posted Sat Mar 31, 2018 6:07 AM
The game is looking good.  Nice work! :thumbsup:
Here are some suggestions for improvements:
  • Change to Color Stack mode in options screen to use lower-case letters.  Or even better: define your own cowboy-themed custom fonts in GRAM and use that instead.  (The Intellivision GROM fonts suck balls.)
  • If you intend to keep the options screen as part of the game (and not just for debugging), you may want to consider organizing and laying it out a bit to make it more pleasant.  Try to use the space more effectively.
  • It looks like you are re-drawing the entire options screen on every input (all the text flashes with the sprites).  You may want to avoid doing this and only update the necessary parts.  Flicker can get distracting to the user.
  • You should highlight more the options that the player is changing.  For example, "SPEED IS FAST" should perhaps have "FAST" in reverse video so that it catches the attention of the player as he changes it.
  • When the screen transitions from "options" to "game-play," there is a brief glitch as the colors are not set correctly.  It is common to blank out the screen during transitions, then synchronise with the frame interrupt, and try to draw it all at once so as to avoid the glitch and flicker.
  • One of the strengths of the Intellivision (at least in its hey-day) was that it was easy to make colourful screens.  Other platforms, in contrast, required painting the backgrounds systematically and so avoided it by sticking to a black screen.  Unless you are trying to adhere to a specific style, I recommend using a more colourful background that fits your western theme.  :)
  • I suppose that "SC:00" on each side of the HUD bar stands for the score.  If so, I recommend just putting the numbers, not the "SC," which is superfluous and confusing.
  • There is something definitely flakey with the way you are drawing the screen:  I see many glitches as the score is being updated, and even a yellow field flicker as the bullet ricochets (1:46 in the video).  You may want to review your drawing techniques to see what's going on.
That's it for now.  I know you are just starting, so some of the things above may not be as important right now as getting the game done.  I like the music and the game-play so far.  Nice job!
    -dZ.
#14 digress OFFLINE
digress
  • 1,124 posts
Posted Sat Mar 31, 2018 9:34 AM
More colourful menu
Both fighters can now shoot & kill each other
collision detection (you can bump into things & shoot holes in them
still playing with the music & fx
collision of bullets at wrong tile
and some weird glitch with 2 bullets. will check it out.
#15 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Sat Mar 31, 2018 10:42 AM
More colourful menu
Looking good!  The colourful menu looks much better.  I'm not too fond of the music -- it's fine, it just doesn't fit as well as the other one.  When I think of a "western" theme, bebop rock from the '50s does not spring to mind.
    -dZ.
#16 digress OFFLINE
digress
  • 1,124 posts
Posted Sat Mar 31, 2018 11:19 AM
The other music is only temporary as I needed to track down what was casusing the mode to revert to color stack in the middle of a game. It's actually still happening. I thought it was fixed but it's not.
#17 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Sun Apr 1, 2018 4:29 AM
You can use the jzIntv debugger with a read-watch on the mode register to see who's modifying it.  You'll have to get your hands dirty, though.
We could help you if you post a binary and the assembly listing (".lst") file.  If you do not feel comfortable posting it publicly, just send a private PM.  Any of the judges would be very happy to help you.
Alternatively, you could post a snippet of the code you use to set the screen.
   -dZ.
#18 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Sun Apr 1, 2018 4:33 AM
By the way, what makes you think that the problem is the mode being changed?  If that were to happen in the middle of the game, it would screw up the colours badly, but I just don't see that.
#19 digress OFFLINE
digress
  • 1,124 posts
Posted Sun Apr 1, 2018 9:42 AM
good point.. it didn't actually show this time.. It had happended since in other tests. I thinks its the On gosub play_sound call that does it.
I might try the regular play_music and see if that works better for me but I want to concentrate on getting the additional features working first such as a moving stage coach & correct tile collision.
#20 Kiwi ONLINE
Kiwi
  • 1,675 posts
Posted Mon Apr 2, 2018 11:39 AM
You can insert STACK_CHECK into your code to see if the stack is overflowing. It'll stop your game and display Stack overflow on the top. This is a good way to determine when there's strange thing happening in your game.  This involve jumping out of a gosub via goto.
#21 digress OFFLINE
digress
  • 1,124 posts
Posted Sat Apr 14, 2018 4:08 PM
had a little bit of time to work on this again. I got several things improved and the beginnings of  an a.i. opponent and a fort bg alternate scenery. here is a test rom if anyone wants to try out this in progress version.
Edited by digress, Sat Apr 14, 2018 4:09 PM.
#22 digress OFFLINE
digress
  • 1,124 posts
Posted Sun Apr 15, 2018 7:18 PM
I put up a video for others whom might just want a quick peak but not emulator setup.
I'll get the stage coach moving next and improve the collision detection.
a.i opponenet will go for the bullet reload if he runs out of bullets.
#23 artrag ONLINE
artrag
  • 1,254 posts
Posted Sun Apr 15, 2018 11:51 PM
He could go for bullets also if he has room for them and the bullets are within a given range
#24 digress OFFLINE
digress
  • 1,124 posts
Posted Mon Apr 16, 2018 3:04 AM
 Premptive reload. perhaps. I love the idea of chasing him down trying to shoot him in the back as he runs for the reload and hoping he doesn't reach it just as you run out of bullets.
after round 5 he has unlimited bullets anyways just to make it harder. so he wouldn't ever pursue it then unless...he had a premptive ammo run just to play keep away.
Edited by digress, Mon Apr 16, 2018 3:07 AM.
#25 mthompson OFFLINE
mthompson
    Dragonstomper
  • 881 posts
Posted Mon Apr 16, 2018 10:03 AM
Thanks for posting the ROM. It's fun to try out a game that's quite a ways along but is still a work in progress.
This is going to be fun. I already like shooting my opponent in the back, though I'm sure that says more about me than it does about the game.
– It's frustrating right now when bullets pass through without getting a kill. Do you have to get a head shot?
– The timer is really slow. It takes 2:18 to count down from 60.
– The menu is... OK. It's not clear to me why the two gunfighters are on the screen and why they react for some options and not others. Going back to saying "Normal Mode" and "Zombie Mode" would make that choice clearer. "Music On" and "Off" instead of "ON" and "OFF" would lessen the collision of letters with the line above.
– Should black (invisible) be a color choice for a player? Seems like the left player can't pick that color.
– I agree with DZ about the "SC" used to indicate the score. Using the player color for the number should make it obvious. If the player color is black, you'd need a background color for the digits.
– It's not apparent that pressing 1 starts the game. That should either be in the list or at the bottom instead of the second copyright notice.
– The Intellivision side buttons aren't normally referred to as Fire, and "Fire 2 Change Colour" just looks clunky. Better to just list it in the menu as "8 - Change Colour"
– On the subject of the side buttons, they should all work in this game, whether it's on the menu or shooting. Some players will prefer shooting with the top buttons, and right now they're not used.
I'm looking forward to playing this again. With a human opponent, it should be a lot of fun.
