Trying to configure RamExpress II+
4 replies to this topic
#1 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 24, 2018 12:33 PM
I purchased a RamExpress II+ from a2heaven and have installed it in my Apple IIc plus.
The basic memory test works fine as listed in the instructions, however, I can't figure out how to set the time. There is a .dsk (140k) image he supplies on his website. I am booting to that with my FloppyEmu which is configured as a 5.25 disk. It boots up fine, but a couple things differ from the PDF instructions on a2heaven.com:
Nowhere on the screen do I see " DClock Copyright ©19AppliedEngineering" and there is no "Clock Utilities menu" to set the clock.
Does anyone have experience with the RamExpress II+ ?
There are a few menu entries to test the memory, which work fine, but no "Clock Utilities menu".
I've attached the 2 disk files in question from the a2heaven site along with the PDF manual for convenience.
#2 cybernesto OFFLINE
cybernesto
    Space Invader
  • 39 posts
Posted Sat Mar 24, 2018 1:23 PM
Have you tried the DCLOCK.dsk image as well? This is the one with the driver and the clock utilities. Make sure you are selecting it correctly on the floppyemu.
#3 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 24, 2018 1:51 PM
No, I didn't try that one because I thought it only contained the driver that you will need to install on your DOS disk. I can give it a shot though, maybe I'm mistaken.
I was just configuring the CFFA3000 on my Apple II+.  At least that is working as expected.
Update: Yeah, that DCLOCK.dsk image is not a boot disk, it just dropped me to the monitor when I tried to boot from it.
#4 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 24, 2018 7:54 PM
OK, I took a look at the DLOCK.DSK in CiderPress and it does have a lot more files than the driver
"AE.CLOCK.PTCH" "BIN" "$D742" 21-Oct-88 12:15 ProDOS 125
"AE.CLOCK.UTIL" "BIN" "$4000" 27-Oct-88 10:29 ProDOS 361
"AE.IIC.PTCH" "BIN" "$4300" 27-Oct-88 10:34 ProDOS 36
"BASIC.SYSTEM" "SYS" "$0000" 14-Dec-87 16:43 ProDOS 10240
"CLOCK" "BIN" "$B800" 15-Nov-88 17:43 ProDOS 1128
"CLOCKWORKS" "BAS" "$0801" 15-Nov-88 17:58 ProDOS 6226
"DCLOCK.DOC" "TXT" "$0000" 28-Nov-88 12:16 ProDOS 1834
"DCLOCK.SYSTEM" "SYS" "$2000" 27-Oct-88 11:48 ProDOS 1131
"PRODOS" "SYS" "$0000" 23-Nov-88 09:38 ProDOS 15485
"READ.ME" "BAS" "$0801" 28-Nov-88 11:49 ProDOS 990
"SOURCE.UTIL" "TXT" "$0000" 31-Oct-88 12:49 ProDOS 27731
"STARTUP" "BAS" "$0801" 15-Nov-88 13:49 ProDOS 12128
#5 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Mar 25, 2018 2:49 PM
What is odd, this disk starts up without issue in AppleWin (the DCLOCK.DSK) but it will not boot on my Apple IIc plus using the BMOW FloppyEmu.
Anyway, I think I'm going to give up on this and go back to using my plain IIc. Maybe get a no-slot clock in the future. It's not worth all the time I'm wasting trying to get it going on the Apple IIc plus.
I originally bought the RamExpress II+ for my Apple IIc, but I never checked to see if I had the proper motherboard so had to install it into the IIc plus.
Update: Plamen came through with a different disk image. With the one I've attached, I was able to boot to it finally and configure my clock on the Apple IIc plus!
Reply to this topic
