$00 = NOP, BRK or other?
opcodes z80 6502 2650 9900 f8 1610 1802 8048 8080
9 replies to this topic
#1 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,850 posts
Posted Mon Mar 26, 2018 8:00 AM
The Wikipedia page about the 1292 Advanced Programmable Video System claims it was particularly difficult to program:
The user had to be familiar with programming in Signetics 2650 assembly language and the unconventional ways and register architecture of the Signetics 2650 processor. For example, on many other processors an opcode 0 indicates "no operation" whereas on the 2650 it instructs the processor to Branch To Address In Immediate Register B. This was a source of many software debugging hassles for budding home programmers.
It made me curious. Did nearly every other processor and microcontroller back in the 1970's default to opcode $00 equals NOP? So far I have found the following:
Zilog Z80 and Intel 8080: $00 = NOP (No Operation)
Intel 8048 : $00 = NOP (No Operation)
RCA 1802: $00 = IDL (Idle)
So far, so good. But how about the others?
MOS 6502: $00 = BRK (Break, causes an interrupt)
GI CP-1610: $0000 = HLT (Halt, not sure what it does but likely not NOP)
Motorola 6809: $00 = NEG $nn (not entirely sure about this syntax, but at least NEG)
Signetics 2650: $00 = Branch to address in immediate register B (per the Wikipedia article)
I failed to look up what the TMS-9900 and the Fairchild F8 do with opcode $00 or $0000. It seems that Motorola 6801/03 doesn't define $00 at all.
Likely I have missed some relevant processors and microcontrollers of the time, but it seems like the article describes how a programmer used to Intel or Zilog would be confused about the Signetics. Programmers used to MOS, GI or Motorola may have been confused too, but at least not expecting NOP.
Now machine code programming has far more interesting challenges than which instruction equals which value when encoded as binary/hex/decimal data, I would think that works out rather quickly, in particular if you were able to have a cross assembler on some mini computer or similar when developing software for the 1292 APVS series.
#2 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,876 posts
  • Coding something good
Posted Mon Mar 26, 2018 8:41 AM
Yep, the writer's background in Z80 shines thru.
In 80x86 the NOP opcode is $90 and in 6502 it's $ea.
So it's a non-sense. You cannot simply expect $00 to be NOP because you used Z80 once.
#3 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,850 posts
Posted Mon Mar 26, 2018 8:59 AM
Am I right that on the 9900, an opcode may be 3-11 bits and the rest are operands? It doesn't seem that any instruction has eight leading bits of 0 in any case.
On the F8, it appears $00 equals LR A,KU which loads the accumulator with register 12, the upper part of K so that is yet one more strike against the NOP theory.
Besides that Wikipedia article has for years mentioned Activision games, but I can't find any proof elsewhere they ever made any since they didn't even release for the Arcadia 2001. I think the contributor might think about Acetronic or mixing it up with a different system, like Advision (Arcadia 2001 clone).
Edited by carlsson, Mon Mar 26, 2018 9:12 AM.
#4 nanochess OFFLINE
nanochess
  • 5,876 posts
Posted Mon Mar 26, 2018 9:44 AM
All instructions are 16-bits and there isn't a NOP instruction defined officially, but you can always do MOV R0,R0
Probably you're right, I don't know enough of obscure consoles :)
#5 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,850 posts
Posted Mon Mar 26, 2018 9:51 AM
Actually I was looking to find out what happens when the CPU or MCU hits $00 when it expects an instruction, not how to perform NOP on various architectures but both probably are useful bits of information. The UK based poster who contributed lots of information later removed from the Wikipedia article never signed with name or handle, just their IP address showing so rather anonymous for being someone with so much insight. Then again Wikipedia generally doesn't like own research, no matter the degree of accuracy unless you elsewhere can prove you are a reliable source.
If all types of architectures would be equally common, it seems to be a 40% chance that $00 will cause a NOP and 60% that it will do something completely different.
Edited by carlsson, Mon Mar 26, 2018 9:54 AM.
#6 nanochess OFFLINE
nanochess
  • 5,876 posts
Posted Mon Mar 26, 2018 10:07 AM
Oh, I see.
The TMS9900 apparently doesn't have an exception mode, so a $0000 instruction would do nothing.
https://en.wikipedia.../Illegal_opcode
More misleading information because you know the undefined opcodes can crash a 6502.
#7 nanochess OFFLINE
nanochess
  • 5,876 posts
Posted Mon Mar 26, 2018 10:11 AM
And in 80x86 the 00 00 opcode would translate to ADD AL,[BX+SI]
Years since I saw that trying to disassemble games using DEBUG :)
#8 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,850 posts
Posted Mon Mar 26, 2018 10:32 AM
And on the 68000, an MSB of $00 seems to be an ORI instruction. The 6800 though doesn't have $00 defined just I assumed on the 6801/6803.
The Intel 8008 seems to be HLT on $00, $01 or $FF, which is quite different from the Intel 8080 doing NOP. I wonder how many Intel programmers got confused when the opcodes changed?
If we put those CPUs and MCUs ordered by year, it gets even more interesting:
1972: Intel 8008 - HLT
1973: Signetics 2650 - Branch ...
1974: Intel 8080 - NOP
1974: Motorola 6800 - N/A
1975: Fairchild F8 - LR A,KU
1975: MOS 6502 - BRK
1976: RCA 1802 - IDL
1976: Zilog Z80 - NOP
1976: Intel 8048 - NOP
1976 (?): GI CP-1610 - HLT
1978: Motorola 6809 - NEG
So by the time of the Signetics 2650, possibly nobody else had NOP'ed at $00 and even by 1975, it was more common to HLT/BRK than NOP.
Yes, I know this is an entirely pointless discussion and probably I should just log onto Wikipedia suggesting a change in the wording.
Edited by carlsson, Mon Mar 26, 2018 10:33 AM.
#9 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Mon Mar 26, 2018 6:27 PM
Maybe I am missing something here but why would it matter what the opcode was. The assembler would generate the correct code.
#10 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,850 posts
Posted Tue Mar 27, 2018 1:47 AM
I think the idea is that you hand code your program byte by byte and somehow have enough knowledge of the platform to address it correctly, but mistake the opcodes between different platforms. A very unusual scenario.
Also tagged with one or more of these keywords: opcodes, z80, 6502, 2650, 9900, f8, 1610, 1802, 8048, 8080
