Session 14: Playfield Wierdness
47 replies to this topic
#1 Andrew Davie OFFLINE
Andrew Davie
  • 1,829 posts
  • Dr.Boo
Posted Sun Jun 1, 2003 5:28 AM
The diagram below shows the bizarre way that bits in the TIA playfield registers (PF0, PF2) map to the onscreen pixels in reverse order. We have already seen how PF1 works - it is shown in this diagram, too.
This strange backwardness (not to mention inconsistency!) is probably a result of the fact that it was simpler (cheaper) to design the hardware to operate in this fashion. Among other things, this layout of pixels in our TIA registers makes scrolling horizontally a major pain in the neck!
The bits marked with a cross are not used by the '2600 (including the low bit in the colour registers), and you may write any value to these - it is ignored.
The diagram shows a shadowy "right-side" - where the 20 pixels of the left side are duplicated. Be aware that this right-side may also be mirrored, further complicating things.
#2 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Sun Jun 1, 2003 6:14 AM
Any exercises ?
#3 Andrew Davie OFFLINE
Andrew Davie
  • 1,829 posts
  • Dr.Boo
Posted Sun Jun 1, 2003 6:34 AM
Any exercises ?
I'll be delivering this session in stages. I'll give some exercises once I've gotten through the explanations.
If you want to play with some things then....
1. Confirm that PF0 and PF2 have reverse pixel to bit position ordering (Hint: using binary for your values will assist you to see exactly what pixel corresponds to what bit (ie: lda #%01000000, sta PF0)
2. What happens if you write PF0, PF1 or PF2 in the middle of a scanline? What would you expect to happen? Can you see any use for this? (Hint: how do you think an asymmetric playfield - a different pattern on the left and right of the screen - is created?)
3. Write some solid shape(s) to PF0, PF1, PF2 (ie: lda #%01011110, sta PF0, sta PF1, sta PF2) and then play with changing the playfield colour several times during a scanline. How many colour changes (maximum) do you think you can get on any line? Why is there a limit?
4. How would a game do horizontal scrolling? This is a difficult question - but I'm trying to get you to think about the implications of the odd playfield->pixel correspondence, and the implications for game writing.
5. How would you make a "wall" which was 8 scanlines high, full screen width, followed by left and right walls just 1 pixel wide each, at extreme left/right edges of the screen, 176 scanlines high, followed by another horizontal "wall", full screen width and 8 scanlines high?
Note: this would form a "box" border around the entire playfield.
There we go, that should keep you busy!
I'll answer last sessions sessions with example code, shortly.
#4 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Sun Jun 1, 2003 7:26 AM
1: write same value to both PF0 and PF1
                lda #%00100000
                sta PF1
                sta PF0
Posted Image
2: add during scanline
                sleep 40
                lda #%00010000
                sta PF2
Posted Image
#5 Andrew Davie OFFLINE
Andrew Davie
  • 1,829 posts
  • Dr.Boo
Posted Sun Jun 1, 2003 7:40 AM
                lda #%00100000
                sta PF1
                sta PF0
                sleep 40
                lda #%00010000
                sta PF2
Happy, if you do these exercises and post your results... please explain in detail what you think you are doing/seeing. It will help others (rather than just pictures and code snippets), and also let me see if you're on the right track. The above samples... don't let me determine that.
In short, a bit more blurb, thanks.
Cheers
A
#6 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Sun Jun 1, 2003 8:25 AM
Alrighty then :D
I fixed the code to be more obvious
1:
                lda #%10000000
                sta PF1
                sta PF0
This is showing the relation between PF1 and PF0. both in their 1st position. (now)
They appear as 1 line (because PF0's 1st position is really it's last )
2:
                sleep 40
                lda #%00010000
                sta PF2
I really didn't think this one through. If you change halfway through the
scan, you'll have to change back at the begining or end of the scan :dunce:
                lda #%000100000
                sta PF1
                sta PF0
                sleep 12
                lda #%00011100
                sta PF0
                sta PF1
This code changes the playfield mid scan and does what I thought the first
bit of code was doing. Because its iterated 192 times it needs to load each
side of the playfield on every pass...
well hows that for a second attempt ?
#7 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Thu Jun 5, 2003 10:05 AM
Oh yeah I got a "playfield" working :D
It's ugly but it works :)
      ;Top line
                lda #15                 ; A nice whitish colour
                sta COLUPF
                lda #%11111111    ; Fill the whole playfield
                sta PF0                  ; left
                sta PF1                  ; mid
                sta PF2                  ; right
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC            ; make it 8 scanlines please
                lda #%00000000    ; Reset Playfield
                sta PF1
                sta PF2
     ;Side lines
Picture      lda #15                 ; load up the white
                sta COLUPF
                lda #%00010000    ; PF0's left
                sta PF0
                sleep 2                   ; wait for it to draw
                lda #$0
                sta COLUPF               ; then kill it
                sleep 25                  ; for 25 cycles
                lda #15                     ; mmmm White
                sta COLUPF               ; Colour Ready to draw some more.
                lda #%10000000      ; PF2's right
                sta PF2                    ; Now draw the right side and
                sta WSYNC              ; Snooze for the rest of the scanline
                inx
                cpx #176
                bne Picture
;bottom line - same as top (GOTO TOP to read comments :P )
                lda #15
                sta COLUPF
                lda #%11111111
                sta PF0
                sta PF1
                sta PF2
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                lda #%00000000
                sta PF1
                sta PF2
As for horizontal scrolling - I wish I knew :P :ponder:
#8 Galaga_Freak OFFLINE
Galaga_Freak
    Chopper Commander
  • 179 posts
Posted Thu Jun 5, 2003 7:03 PM
Finally got this to work on a real tv with no flipping :)
;Scrolling color border thingy
            processor 6502
            include "vcs.h"
            include "macro.h"
COUNTER1	= $80
COLOROFFSET     = $81
TIMETOCHANGE    = 2                   ; speed of "animation"
            SEG
            ORG $F000
Reset
; Clear RAM and all TIA registers
                ldx #0
                lda #0
Clear           sta 0,x
                inx
                bne Clear
       ; Once-only initialisation...
                lda #0
               ;lda #$45
                sta COLUPF             ; set the playfield colour
StartOfFrame
   ; Start of vertical blank processing
            lda #0
            sta VBLANK
            lda #2
            sta VSYNC
               ; 3 scanlines of VSYNCH signal...
                sta WSYNC
                sta WSYNC
                sta WSYNC
            lda #0
            sta VSYNC
               ; 37 scanlines of vertical blank...
                ldx #0
VerticalBlank   sta WSYNC
                inx
                cpx #36; Now waiting 36 lines
                bne VerticalBlank
	;do some color offset calcs
  ldx #$02
  stx COLUBK;redundant as we never change COLUBK, but... :)
  ldx #0
  ldy COUNTER1
  cpy #TIMETOCHANGE
  bne notyet
  inc COLOROFFSET
  ldy COLOROFFSET
  lda #0
  sta COUNTER1
notyet
  inc COUNTER1
  ldy COLOROFFSET
  sta WSYNC ;  wait for last line of vblank
DrawField
Top  sty COLUPF
  lda #$FF
  sta PF0
  sta PF1
  sta PF2
  lda #0
  inx
  iny
  sta WSYNC
  cpx #15
  bne Top
  SLEEP 3 ; sync up middle
Middle
  sty COLUPF
  lda #$F0
  sta PF0
  lda #0
  sta PF1
  sta PF2
  lda #0
  SLEEP 15
  sta PF0
  lda #$F0
  sta PF2
  lda #0
  sta WSYNC
  inx
  iny
  cpx #177
  bne Middle
Bottom
  sty COLUPF
  lda #$FF
  sta PF0
  sta PF1
  sta PF2
  sta WSYNC
  inx
  iny
  cpx #192
  bne Bottom
            lda #%01000010
            sta VBLANK                     ; end of screen - enter blanking
                ldx #0
  stx COLUPF
Overscan        sta WSYNC
                inx
                cpx #30
                bne Overscan
                jmp StartOfFrame
            ORG $FFFA
            .word Reset          ; NMI
            .word Reset          ; RESET
            .word Reset          ; IRQ
       END
Now this has worked for a while on the emulators, but I came to discover that my vblank period was off because of the offset code which I assume put the rest of the frame out of sync slightly each pass which eventually caused the screen to hop or roll on a real tv (using cuttle cart).
I fixed this once but then noticed that my scanline count was 264 not 262 as the code above produces. This actually worked on my tv, so my question is: How far out of the range of 262 can you be for the game to work on most tvs (NTSC) or is it a matter of the atari used (jr vs 4 switcher for example)? Also, is there a way to reproduce the effects (flipping, etc) on an emulator that you would see on a tv other than counting scanlines?
#9 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Thu Jun 5, 2003 8:21 PM
I'd like to know how that works with 384 in picture scanlines ?
I was under the impression stella only had 242 scanlines at the most (pal) :ponder:
#10 Galaga_Freak OFFLINE
Galaga_Freak
    Chopper Commander
  • 179 posts
Posted Thu Jun 5, 2003 8:39 PM
Where did you get 384? There's 3 vsych + 37 vblank + 192 picture + 30 overscan = 262 total scanlines of which only 192 are visible :)
#11 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Thu Jun 5, 2003 8:47 PM
Mabey I'm reading it wrong but ....
Top      sty COLUPF
      lda #$FF
      sta PF0
      sta PF1
      sta PF2
      lda #0
      inx
      iny
      sta WSYNC
      cpx #15
      bne Top
Middle
      sty COLUPF
      lda #$F0
      sta PF0
      lda #0
      sta PF1
      sta PF2
      lda #0
      SLEEP 15
      sta PF0
      lda #$F0
      sta PF2
      lda #0
      sta WSYNC
      inx
      iny
      cpx #177
      bne Middle
Bottom
      sty COLUPF
      lda #$FF
      sta PF0
      sta PF1
      sta PF2
      sta WSYNC
      inx
      iny
      cpx #192
      bne Bottom
15 lines for the top 177 scanlines for the middle and 192 for the bottom = 384 not including overscan and vblank. :?
#12 Galaga_Freak OFFLINE
Galaga_Freak
    Chopper Commander
  • 179 posts
Posted Thu Jun 5, 2003 8:54 PM
Ahh, I see how you got that number now.
The x index register is never reset so after the top is done x = 15, after middle x = 177 after bottom x = 192. Basically it is the counter for the entire visible portion, not individual portions of the visible screen. :wink:
#13 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Thu Jun 5, 2003 9:06 PM
I see now :dunce:
#14 Happy_Dude OFFLINE
Happy_Dude
  • 4,212 posts
  • Forum Slacker
Posted Thu Jun 5, 2003 9:36 PM
Galaga_Freak if COLUBK is never changed you should initalize it after Clear and before StartOfFrame.
No use doing it once every frame ;)
I cleaned my code up a bit. There was a lot of weirdness going on.
      ;Top line
                lda #%11111111         ;fill playfield
                sta PF0
                sta PF1
                sta PF2
                lda #15                ; It looks like white
                sta WSYNC              ; all thats visable so wait
                sta COLUPF             ; before writing the line
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC              ; Give me 7
                lda #%00000000         ; Clear the 2 PF's that arn't PF0
                sta PF1
                sta PF2
     ;Side lines
Picture         lda #15                ; Re-initalize whiteness
                sta COLUPF
                lda #%00010000         ; And PF0
                sta PF0
                sleep 2                ; let it write
                lda #$0                ; now get rid of the damn thing
                sta COLUPF
                sleep 25               ; and wait until the reflected bit has been written black
                lda #15                ; and Re-initalize the colour (again)
                sta COLUPF
                lda #%10000000         ; Line up PF2
                sta PF2
                sta WSYNC              ; wait till end of scanline
                inx
                cpx #176
                bne Picture            ; do it till it's done
;bottom line (yadda yadda yadda...)
                lda #15
                sta COLUPF
                lda #%11111111
                sta PF0
                sta PF1
                sta PF2
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
                sta WSYNC
  lda #$0               ; Clear to return
  sta COLUPF
#15 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,869 posts
  • Always left from right here!
Posted Fri Jun 6, 2003 1:06 AM
That's a question hard to answer. The scanline range of NTSC games I have seen so far is somewhere between 241 (Artillery Duel, a few people have reported problems here!) and ~280 scanlines (e.g. Desert Falcon).
And many TV (especially with a vertical hold) can even display PAL games (standard: 312 scanlines, but there are some with up to 342 scanlines like Acid Drop).
So I assume +/- 15..20 scanlines should be no problem.
#16 8BIT 1337 OFFLINE
8BIT 1337
    Chopper Commander
  • 209 posts
Posted Fri Jun 6, 2003 10:11 AM
This might be a stupid question, but does altering the number of scanlines affect the number of FPS displayed? Seems to me that if you went with, say, 280 scanlines (keeping 192 for the picture), that the FPS would drop below 60. Or is there something else that comes into play that I'm not aware of? (I'm just talking NTSC numbers here).
Another semi-related question - what if I decided to 'use' all my overscan time under VBlank? Why do the non-picture scanlines get split before/after the picture? (Or is that just a best practices standard - if so, what game(s) have done this out of curiousity?)
#17 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,869 posts
Posted Fri Jun 6, 2003 12:46 PM
Yup, exactly!
You can calculate that quite easily:
Artillery Duel: 60/241*262 = ~65Hz
Demon Falcon: 60/280*262 = ~56Hz
PAL games: 60/312*262 = ~50Hz
This is done to center the visible part on the screen. After OverScan we are doing a Vertical Sync to bring the beam back to the top of the screen. So both parts (called Overscan and VBLank) below and above the visible area are about the same size.
#18 8BIT 1337 OFFLINE
8BIT 1337
    Chopper Commander
  • 209 posts
Posted Fri Jun 6, 2003 1:45 PM
I understand what you're saying, but I've played with this a bit (I had a simple playfield with only one scanline of overscan, the rest under VBLANK) and the image was still centered as far as I can tell. Was that 'cause I was using an emulator?
#19 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,869 posts
Posted Fri Jun 6, 2003 1:53 PM
Did you increase the VBlank time then and still had 262 scanlines?
If you only cut some blank lines at the bottom you won't notice that. ;)
#20 8BIT 1337 OFFLINE
8BIT 1337
    Chopper Commander
  • 209 posts
Posted Fri Jun 6, 2003 2:04 PM
Yup - I made sure my total scanlines were still 262 (using z26 to verify my math was correct).
Seems like it would be simpler to use the 67 scanlines all together in one place instead of splitting code up into the 37 VBlank and 30 Overscan portions. Generally speaking of course.
#21 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,869 posts
Posted Fri Jun 6, 2003 3:49 PM
Looks like the emulator did some centering then. Definitely won't work that way on the real thing.
#22 dew2050 OFFLINE
dew2050
    Space Invader
  • 32 posts
Posted Fri Jun 6, 2003 5:43 PM
Any exercises ?
I modified the kernel code to use ASL commands to shift the bits in my playfield variable to the left. Since I didn't want the playfield to repeat itself twice on the screen, I added a second variable to the original kernel lesson sample.
The code only uses PF0 to draw the screen. The result is that the playfield scrolls horizontally from left to right, jumping the center and edges of the screen (everything else not drawned by PF0). The scrolling feels a lot like Vanguard. It's not smoothy like say, Chopper Command. I think for that you would need to use the HMOVE register with something other than the playfield, but that's ok for now.
On PCAEWIN it works fine, but on Z26 it draws some garbage at the top of the screen. Take a look at the code:
; 2600 for Newbies
; lesson 14 - playfield
; Question 4 - One way to do horizontal scrolling with the playfield.
	processor 6502
	include "vcs.h"
	include "macro.h"
; OBJECTIVE:  This variation of the lesson 14 kernel does horizontal scrolling with the playfield.
;  Only PF0 is used. The program uses to variables to store the left and right side values
;  of the playfield. These are declared below:
PATTERN_LEFT	= $80
PATTERN_RIGHT	= $82
TIMETOCHANGE	= 20
	SEG
	ORG $F000
RESET
; Clear RAM and all TIA regs
 LDX #0
 LDA #0
CLEAR
 STA 0,X
 INX
 BNE CLEAR
 LDA #$45
 STA COLUPF
 LDY #0
; Here we assign the pattern values to our left and right side of the playfield.
; Try using different values.
 LDA #$0
 STA PATTERN_LEFT
 LDA #$01
 STA PATTERN_RIGHT
STARTOFFRAME
 LDA #0
 STA VBLANK
 LDA #2
 STA VSYNC
 STA WSYNC
 STA WSYNC
 STA WSYNC
 LDA #0
 STA VSYNC
 LDX #0
VERTICALBLANK
 STA WSYNC
 INX
 CPX #37
 BNE VERTICALBLANK
; HANDLE A CHANGE IN THE PATTERN ONCE EVERY 20 FRAMES
; WRITE THE PATTERN TO PF1
 INY
 CPY #TIMETOCHANGE
 BNE SCROLLCOMPLETE
 LDY #0
; The following code uses arithmetic left shift commands (ASL) to make the scrolling happen.
; We shift the bits of the playfield variables to the left. Original bit 7 is shifted to the Carry.
; The program uses BCC to check if a bit was dropped. Dropped bits are inserted to the
; opposite pattern variable by the INC command. The INC command can mess up the pattern if
; the original bit 0 is turned on. To avoid this we shift everything to the left before incrementing.
SHIFTRIGHT
 CLC
 ASL PATTERN_RIGHT
 BCC SHIFTLEFT
 ASL PATTERN_LEFT
 INC PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
 JMP SCROLLCOMPLETE
SHIFTLEFT
 ASL PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
SCROLLCOMPLETE
; DO 192 SCANLINES OF COLOR CHANGING (OUR PICTURE)
 LDX #0
 STX COLUPF
; Load the left pattern into PF1 register.
 LDA PATTERN_LEFT
 STA PF1
; Wait enough cycles before drawing right pattern.
 SLEEP 20
; Load right pattern to PF1.
 LDA PATTERN_RIGHT
 STA PF1
 STA WSYNC
 INX
 CPX #192
 BNE PICTURE
 LDA #%01000010
 STA VBLANK
; 30 LINES OF OVERSCAN
 LDX #0
OVERSCAN
 STA WSYNC
 INX
 CPX #30
 BNE OVERSCAN
 JMP STARTOFFRAME
	ORG $FFFA
INTERRUPTVECTORS
	.WORD RESET
	.WORD RESET
	.WORD RESET
END
The tricky code is the bit shifting. Here is the pseudocode:
[color=blue]; Pseudocode:
; Clear Carry
; Shift bits in variable PATTERN_RIGHT to the left. Original bit 7 is shifted into the Carry.
; if no bit was dropped from PATTERN_RIGHT (Carry Clear) then
;	Shift the bits in PATTERN_LEFT
;	if no bit was dropped from PATTERN_LEFT then
;  Scroll is complete. Continue program flow.
;	else
;  Insert dropped bit from left pattern into PATTERN_RIGHT (Using the INC command).
;	end
; else
;	Shift bits in PATTERN_LEFT
;	Insert dropped bit from right pattern into PATTERN_LEFT.
;	If no bit was dropped from PATTERN_LEFT then
;	else
;  Insert dropped bit from left pattern into PATTERN_RIGHT.
;	end
; end[/color]
This translates to:
SHIFTRIGHT
 CLC
 ASL PATTERN_RIGHT
 BCC SHIFTLEFT
 ASL PATTERN_LEFT
 INC PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
 JMP SCROLLCOMPLETE
SHIFTLEFT
 ASL PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
SCROLLCOMPLETE
I am sure there is a better way of doing this without so many BCC's and ASL's (perhaps getting rid of the JMP altogether).
#23 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,869 posts
Posted Sat Jun 7, 2003 1:35 AM
:idea: Hint: Have a look at ROL.
This will make your code much simplier.
#24 Zach OFFLINE
Zach
  • 1,620 posts
Posted Sat Jun 7, 2003 2:57 AM
Thanks Andrew,
It took me a lot of frustrating trial and error before I concluded that the bits in PF2 were displayed in reverse. I'm glad someone is making the TIA's quirks clear.
Zach
#25 dew2050 OFFLINE
dew2050
    Space Invader
  • 32 posts
Posted Sat Jun 7, 2003 9:38 AM
Thanks Thomas. With your help I was able to take this:
CLC
 ASL PATTERN_RIGHT
 BCC SHIFTLEFT
 ASL PATTERN_LEFT
 INC PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
 JMP SCROLLCOMPLETE
SHIFTLEFT
 ASL PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
SCROLLCOMPLETE
Into this:
CLC
 ROL PATTERN_RIGHT
 ROL PATTERN_LEFT
 BCC SCROLLCOMPLETE
 INC PATTERN_RIGHT
SCROLLCOMPLETE
Wow, what a difference ROL makes! I am glad I did it the hard way first, otherwise I wouldn't had appreciated the difference. I have a newbie assembler question: How many machine cycles does the ROL commands above take? Is it 5 for zero page?
