Some new (not really) hardware made by tfhh
1050 Memory Expansion
118 replies to this topic
#26 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
  • I escaped Targ... Twice.
Posted Fri Apr 6, 2018 12:14 PM
Looking forward to getting my Stereo PCB soon so I can enjoy the extra POKEY chip I bought. Thanks tfhh.
#27 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 742 posts
Posted Sat Apr 7, 2018 8:40 AM
Have finished today new Stereo Boards.
Jurgen
#28 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
Posted Thu Apr 12, 2018 7:50 AM
Jurgen
Got my first Stereo board today Jurgen and everything is working brilliantly!  :thumbsup:  :thumbsup:  :thumbsup:  thanks for helping get a decent stereo board the two POKEY's finally work not just one ;) . Sound is louder, clearer and has more ooomph!. :music: :music: :music:
Just need to start saving for the Sys-Check 2.2
#29 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Thu Apr 26, 2018 5:42 PM
tf_hh - sent you a PM. Posting here as well to see if anyone else has any thoughts...
Finally getting around to installing the 512 KB in my 600XL. Ran into a snag that I couldn't find any info on. This motherboard is fully socketed (AWESOME!!!), which poses a problem. The back of the boards pins will not sit flush in the ANTIC socket. The board is sitting against the upper chip. If I push it in, the board is slanted upward in rear.
After further testing, even if I get a low profile riser socket - even with the shield removed, the keyboard/top case will not sit flush with the unit. About a 1/4-1/2" gap.
So, it appears this expansion is not compatible with a "socketed" 600XL.
Thoughts, suggestions, ideas?
#30 Nezgar ONLINE
Nezgar
  • 1,457 posts
Posted Thu Apr 26, 2018 5:54 PM
Hmm, shave 3mm off each pin on the headers? :P
#31 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Thu Apr 26, 2018 5:57 PM
HA! I thought of all kinds of not so smart things to try.
As you can see, it'ss not even in the soccket at that moment. Just sitting on top of it to show the amount of gap between the pins and the socket due to it resting on the 74LS08 IC.
#32 Stephen OFFLINE
Stephen
  • 7,375 posts
  • A8 Gear Head
Posted Thu Apr 26, 2018 8:19 PM
My guess would be, that the device was meant to plug into a machine pin socket.  I do not really trust any other type of socket, especially when using a device with machine pins.  If that were my machine, I would remove the dual wipe socket, and install a machine pin socket in its place.
#33 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Thu Apr 26, 2018 9:03 PM
That's not the concern/issue. Even if I do replace the dual wipe socket with a machine pin socket, it will still sit too high in the rear due to the IC that is mounted under the board sitting on the 74LS08 IC. The only possible way this might fit the 600XL is to remove the 74LS08 socket, solder the IC directly to the board, remove the ANTIC socket and solder the 512 KB expansion board to the 600XL directly.
Two things happen...
1. I've removed the use of sockets of the 600XL
2. The expansion board still might not clear the 74LS08
It's a tight fit with little to no tolerance.
Also, even if I get it to fit, the bottom of keyboard hits the expansion board not allowing case to close properly.
Edited by NISMOPC, Thu Apr 26, 2018 9:06 PM.
#34 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Thu Apr 26, 2018 9:08 PM
My goal was to add the din output to the 600XL and use it as my main 8-bit because of the small factor and top loading cartridge slot. I now have to rethink my alternatives. I have my original 800XL from when I was a teen, a 65XE and a 130XE. So might have to choose one of those as my daily now...
#35 Nezgar ONLINE
Nezgar
  • 1,457 posts
Posted Thu Apr 26, 2018 9:10 PM
I guess you could test if it fits by removing the two sockets and just placing the board and the LS chip into the through-holes and see if it closes before soldering anything... but yeah, that sucks for future work if you commit to it.
#36 JR> OFFLINE
JR>
    Moonsweeper
  • 332 posts
Posted Thu Apr 26, 2018 9:20 PM
That's too bad.  The Antonia 4mb fits the 600xl nicely.  Add a UAV to feed the AV DIN, and you've got a great compact 8-bit that will run just about everything, with beautiful video and very minimal soldering.  Then put the 500kb in your 800xl.
Edited by JR>, Thu Apr 26, 2018 9:21 PM.
#37 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
Posted Thu Apr 26, 2018 10:45 PM
@NISMOPC Is that the standard 512K expansion or the 600XL version Jurgen was talking about earlier in the thread?
Edited by Vyper68, Thu Apr 26, 2018 10:48 PM.
#38 flashjazzcat OFFLINE
flashjazzcat
  • 14,183 posts
Posted Fri Apr 27, 2018 2:51 AM
There is a clearance issue on the 800XL as well. My solution was to solder the device direct to the motherboard after removing the ANTIC socket. Ideally, if all forty connections are direct (not diverted), the pin headers on the bottom would be replaced by a single precision socket sat flush with the adapter board, whose legs would in turn plug into the ANTIC socket. See the VBXE ANTIC adapter for a suitable low-profile solution.
#39 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
Posted Fri Apr 27, 2018 3:01 AM
What type of board were you working on Jon? My new 800XL ( Don't tell Mrs Vyper68 ;) i went and did it again ) is the one without the Freddie and it doesn't foul on any other chips unless it was the RF shielding you were referring to.
#40 flashjazzcat OFFLINE
flashjazzcat
  • 14,183 posts
Posted Fri Apr 27, 2018 3:18 AM
The raised ANTIC was blocking the keyboard. I'll qualify this observation by the fact there are almost certainly keyboards of a lower profile which will not block the raised IC. But the case top with keyboard I tested would not sit correctly. The RF shield was completely omitted.
Jurgen makes really great gear, and my suggestion of using a countersunk socket instead of socket/header pins is just a suggested improvement which would guarantee clearance in all circumstances. Sometimes there are technical reasons why this isn't possible, of course (for example, if one of the ANTIC signals has to be intercepted and modified before actually reaching the motherboard).
Edited by flashjazzcat, Fri Apr 27, 2018 3:18 AM.
#41 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
Posted Fri Apr 27, 2018 3:32 AM
I have just looked at mine through the air vents with an LED light and it is very tight there is not much between the ANTIC and the underside of Keyboard PCB which is the type called Issue #1 based on the forum. I stored the RF shield away when i cleaned the XL. I 100% agree with you about Jurgen's items. The Stereo PCB is really good and it sounds great so i never even looked when i put the XL back together after fitting the RAM expansion.
Edited by Vyper68, Fri Apr 27, 2018 3:33 AM.
#42 slx OFFLINE
slx
  • 1,631 posts
Posted Fri Apr 27, 2018 4:37 AM
Got a package from tf_hh yesterday. Very quick and he was right on the mark with his predicted delivery time. Very well labeled and packed, I've never seen anti-static zip-loc bags before! Ideal for the pack-rat who always buys more enhancements than he can handle at the time and then has to think what those little boards were meant to do when rummaging through storage boxes... :grin:
#43 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Fri Apr 27, 2018 7:22 AM
It's the standard board - based on everything I read and understood, there was only one version (I have the newest one with the 3 pin connector). Did I overlook that there was a version made specifically for the 600XL???
#44 manterola OFFLINE
manterola
    Moonsweeper
  • 251 posts
Posted Fri Apr 27, 2018 7:38 AM
What about using something like this:
https://www.ebay.com...em=282937326207
and a ribbon cable (old ide cable) to move the board far from the lower edge?
Edited by manterola, Fri Apr 27, 2018 8:14 AM.
#45 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Fri Apr 27, 2018 8:29 AM
I LIKE that idea. Hmmm....
Might look into this! Thank you!!
#46 Vyper68 OFFLINE
Vyper68
    Star Raider
  • 54 posts
Posted Fri Apr 27, 2018 9:44 AM
If you look at post #10 in this thread Jürgen talks about a version specifically for the 600XL which I take to mean that the layout of the PCB to be altered to take account of the space constraints of the 600XL. I do not know for sure but that was how I read it. I don't know if that version is out yet as not owning a 600XL so I never chased that.
Edited by Vyper68, Fri Apr 27, 2018 9:47 AM.
#47 JR> OFFLINE
JR>
    Moonsweeper
  • 332 posts
Posted Fri Apr 27, 2018 9:51 AM
Had a recent PM conversation about using his Sys-Check board on a 600xl (which works great BTW) and he said this:
But, if you can wait... I´m working on a new expansion board specially for the 600XL. It´s absolute solderless, just plug-in. You get 64 KB base memory, 512 KB RAMBO & Compy-Shop compatible memory expansion, 4 or 7 (not finalized) operating systems, flash-ROM and some other goodies. Stay tuned
#48 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Fri Apr 27, 2018 9:54 AM
Sounds promising!!! I love the quality of his work, so maybe I'll be patient...
#49 manterola OFFLINE
manterola
    Moonsweeper
  • 251 posts
Posted Fri Apr 27, 2018 12:00 PM
Thanks to you for providing us with your experience.
I am looking fwd to expand the memory of a beaten 600xl I am restoring and this particular ram expansion seems to fit the bill, as long as can be adapted to the size restrictions of the computer.
#50 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 416 posts
Posted Fri Apr 27, 2018 7:21 PM
Well I almost pulled the trigger until I realized I need the opposite on the other end of the cable and apparently no one makes a 40P female socket to ribbon adapter. I would need to plug the expansion into a socket at other end. Was liking this idea until I hit that snag and seems like a breadboard soldered with 40 wires to a socket would be bulky and not ideal.
Also tagged with one or more of these keywords: 1050, Memory Expansion
