Got my first IIe ....
27 replies to this topic
#1 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 31, 2018 9:16 AM
Finally picked up a nice Apple IIe enhanced and while cleaning it up, noticed a black block plugged into the Game I/O port. Does anyone know what this is for? There are no real identifying marks on it. I was going to plug up my II plus joystick there.
The black block reminds me of a sealed battery, but being new to the IIe, I have no clue what it's for.
#2 Caterpiggle OFFLINE
Caterpiggle
    Dragonstomper
  • 766 posts
Posted Sat Mar 31, 2018 5:46 PM
it is for 6 pins Apple Paddle or Joystick instead of standard 9 sub joystick. It is Apple joystick version, NOT Atari joystick.
#3 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 31, 2018 6:01 PM
Hello, yes, what I wanted to know is, there is small black plastic object plugged into the white Game I/O port on my IIe PCB. Is this just to protect the empty socket? Or is that black plastic thing with 2 rows of pins on the bottom used for some other purpose?
#4 Caterpiggle OFFLINE
Caterpiggle
    Dragonstomper
  • 766 posts
Posted Sat Mar 31, 2018 6:16 PM
do you have an photo on it ? Sound like home-brew ?
#5 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Mar 31, 2018 8:08 PM
Sure, I apologize for the size of the image ;)
This may be nothing, just something to preserve the Game I/O socket. Since I'm relatively new to Apple II's and this is my first IIe, I was just curious.
#6 Caterpiggle OFFLINE
Caterpiggle
    Dragonstomper
  • 766 posts
Posted Sat Mar 31, 2018 8:23 PM
I has 2 of them. This is for spare piece of 6 pins. In case if at the end of game cable 's pin is broken or missing pins like that. It is good for replace the broken piece into this spare one. Mine is a little different, 2 of them are not for Apple I/O Game port and it is for something else.
#7 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Apr 1, 2018 6:13 AM
Mine seems to be sealed. I thought it might have been a sealed battery or something, but had no clue what it would have been used for in the Game I/O port. Thanks. I guess I'll hold onto it for when the joystick isn't plugged in.
#8 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Apr 1, 2018 12:35 PM
Here's a shot of the IIe, I know everyone looks for pictures in these threads. Nothing major, I have a Microsoft SoftCard and my new CFFA3000 installed. I'm waiting for the 64k 80-column card to come in.
Before the IIe purchase, I used my IIc, IIc plus and have a II+
I was looking to get an Apple IIe Platinum, but they seem to be few and far between on eBay.
  • Attached File  IIe.JPG   1.32MB   2 downloads
#9 david__schmidt OFFLINE
david__schmidt
    Chopper Commander
  • 163 posts
Posted Sun Apr 1, 2018 8:43 PM
A picture of the *other* side would be very interesting.  If it's all sealed up - it's probably a software protection dongle.  Not a particularly common thing to do with the Apple II line, but they did happen from time to time.  Not likely for protection of the socket; it's for protection of software. :-)
#10 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Sun Apr 1, 2018 8:57 PM
Yes I second the protection idea. It could be as simple as an array of resistors or a basic 74LS logic chip. C64 and Atari 8bit had that. It is NOT to protect the socket.
#11 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Apr 1, 2018 9:27 PM
Ah, I didn't even consider that! There doesn't appear to be any further identifying marks besides what is underneath.
#12 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sat Apr 14, 2018 10:23 AM
I agree, this is almost certainly a security dongle.
#13 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Apr 15, 2018 7:30 AM
Thanks, yes, I've tossed it. Not going to waste any more time on it now that I know it's nothing crucial ;)
#14 MarkO OFFLINE
MarkO
    Dragonstomper
  • 920 posts
  • Location:Albany, Oregon, USA, North Western Hemisphere, Planet Tera
Posted Thu Apr 26, 2018 3:38 PM
It would have been interesting to know how it worked...
Since there are Four Paddle Ports, that look for a Variable Resistors between 0 Ohms and 150K Ohms, you could make "a key" by using Four Resistors of the same or different values, and have your program read the values and determine if it's the Right Dongle...
MarkO
#15 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Thu Apr 26, 2018 4:15 PM
Could use the button lines in the mix as well
#16 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Sat Apr 28, 2018 1:27 PM
Too bad it was thrown away. But then again with general interest waning in Apple II hardware..
#17 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sat Apr 28, 2018 5:15 PM
I still have it, didn't quite make it to the garbage can yet ;)
Just didn't have much more interest since it wasn't anything important. This whole thing started because it was occupying the slot I wanted to use for my joystick and had no clue if it was something I needed to keep.
#18 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Sat Apr 28, 2018 6:44 PM
mail it to me ill take it apart
#19 MarkO OFFLINE
MarkO
    Dragonstomper
  • 920 posts
Posted Sat Apr 28, 2018 10:56 PM
+1
MarkO
#20 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Sun Apr 29, 2018 1:16 AM
Yes. It should be documented and examined.
#21 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Sun Apr 29, 2018 12:34 PM
Since some of you are curious, I've cracked it open and took some pictures.  I'm afraid I didn't note which way it was oriented though when I removed it from the Game I/O port since I no longer cared.
#22 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Mon Apr 30, 2018 1:01 AM
Great! Easy to duplicate. What is the part number on the transistor-looking thing?
#23 MarkO OFFLINE
MarkO
    Dragonstomper
  • 920 posts
Posted Mon Apr 30, 2018 9:14 AM
A Resistor Key.... The Two Resistors are set to a particular value...
The Values, when read let the Program know that it is a Valid Install, if the values are correct.
MarkO
#24 sm3 OFFLINE
sm3
    Dragonstomper
  • 625 posts
Posted Tue May 1, 2018 8:42 AM
OK here's the last 2 images I'll be uploading for this. Time for me to move on. Hopefully this will provide what you need.
#25 MarkO OFFLINE
MarkO
    Dragonstomper
  • 920 posts
Posted Tue May 1, 2018 1:13 PM
Thanks for the Pictures.. If one of these needs to be built, we have the Circuit and Components....
MarkO
Reply to this topic
