atarifan_1982 Posted April 1, 2018 Share Posted April 1, 2018 I have an Atari 130XE and 2 disk drives that work fine. I added and 3rd and 4th, however, even with the switches set as 3 & 4 on the new drives I can access them. They work fine if I switch them to 1&2. Is there some limit on the 130XE or version of DOS. I have Atari DOS 2.0 and 2.5. Also when using a SIO2SD card reader (from Lotharek- which emulates up to 15 drives) it still won't see but drives 1 & 2. Any help? thanks DevDude Quote Link to comment Share on other sites More sharing options...
Guest Posted April 1, 2018 Share Posted April 1, 2018 (edited) well, dos 2.5 is supposed to handle 4 drives. now here's the thing: i've just tested my setup - all three are upgraded happy drives: ■ Dos 2.5 Directory Search for drive 3 reports error #160. ■ Sdx reads drive 3 directory ■ happy 7 s'ware reads drive 3 something definitely amiss with Atari dos. you may want to ask Albert to move this to Atari 8-bit subsection - it'll get more views there. Edited April 1, 2018 by Guest Quote Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2018 Share Posted April 2, 2018 Although Dos will work with 4 drives you need to tell it that you have more than 2 drives. I think Flag 1802 needs to be set correctly - but don't know much more about it than that. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted June 18, 2018 Share Posted June 18, 2018 Atari DOS 2 by default is only configured with buffers for D1: and D2: to save RAM. For 4 drives, go to BASIC and enter: POKE 1802,15 Then go back to DOS, and choose to 'Write DOS files' to make it the default. Then reboot for the change to take effect. See page 82 of the Atari DOS II Reference Manual: https://archive.org/details/atari-dos-2-ref Quote Link to comment Share on other sites More sharing options...
