mobiusstriptech Posted April 2, 2018 Share Posted April 2, 2018 (edited) Up for sale are the citrus3000psi RGB boards for the Colecovision/ADAM. These boards are designed to be soldered to the bottom of the VDP and provide RGBS to an output connector of your choice. To properly calibrate these boards, 3 onboard POTs are used to adjust each color individually. Please note that to properly calibrate the board, you MUST use an oscilloscope. If you do not calibrate with an oscilloscope and choose to adjust by eye, please note that any compatibility issues, damage, or world ending results via the summoning of Cthulu are solely your responsibility. Each kit is sold as a DIY and fully assembled/tested before shipping. If you receive a board and have issues, please contact me. If the issues are found to be related to misuse or improper installation, you are on your own. If there appears to be a defect in manufacturing, I will work with you towards an amicable resolution. No output connectors are provided, except with install service. Output connectors can be whatever you wish but the cables themselves must be pass-through, ie no capacitors or resistors installed. If you need assistance with purchasing cables or output connectors please reach out and I can answer your questions. Each board is $30 shipped in the Continental US (CONUS). If you do not feel confident with the installation or would prefer to have it installed for you, I will be providing install services with oscilloscope calibration of the board. Cost of this service is $80 including the board, but not including return shipping. Edited April 10, 2018 by mobiusstriptech 2 Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 8, 2018 Author Share Posted April 8, 2018 I have these back in stock. I will be working to keep them in stock as best I can. I am also trying to work on the install instructions but honestly there isn't much to it, so I have been focused on building/testing more boards for stock instead. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 9, 2018 Author Share Posted April 9, 2018 Spent the better part of the day building as many boards as I could. Boards will be going through testing tomorrow but at this point I should have enough ready to not need to worry about stock for a bit. I still have plenty of blank boards and parts to build more so no risk of running out anytime soon. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 10, 2018 Author Share Posted April 10, 2018 All boards are now tested and ready to go. All pending orders have shipped. Plenty left for those that want them. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 11, 2018 Author Share Posted April 11, 2018 Installation instructions are now available. I will be continuing to update them with more information but they contain all the necessary information to get these installed. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 17, 2018 Author Share Posted April 17, 2018 Plenty of boards are still available. International shipping is also available for an extra $10USD. If you order multiple boards the price will not increase unless you order enough to raise the weight. That would be quite a few boards. Pictures of installed units are being posted to the original thread in the Colecovision section. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 23, 2018 Author Share Posted April 23, 2018 Boards still available. I will be trying to add additional updates to the installation instructions with points to tap +5v and tips for the output connectors. It might be a little bit because of other priorities, but I have been working on photos. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted April 30, 2018 Author Share Posted April 30, 2018 Bumping this up. New pictures are being posted in the original thread and on Twitter. Boards are available. I do need to get more assembled so if there are any requests for large quantities, there might be a slight wait. Just to try it I did adjust one of these by eye and checked in on my scope, it was pretty near perfect but I have done a few of these now. Quote Link to comment Share on other sites More sharing options...
Lios Posted May 2, 2018 Share Posted May 2, 2018 Would these work in other computers/consoles that use a TMS9918 series VDP that outputs YPbPr, or is this specific to the Colecovision and Adam? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted May 3, 2018 Share Posted May 3, 2018 Would these work in other computers/consoles that use a TMS9918 series VDP that outputs YPbPr, or is this specific to the Colecovision and Adam? The '18 outputs composite. Anything with a '28 would likely work, I think. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted May 4, 2018 Author Share Posted May 4, 2018 5-11under is correct. You can probably adapt this to anything with the '28. It might need some tweaking of values though. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted May 9, 2018 Author Share Posted May 9, 2018 Still have a few of these left. I will be making more very soon and after that, will judge the need before making additional units. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted May 20, 2018 Author Share Posted May 20, 2018 New batch is now ready. Interest has been slowing down on these overall so these should last a bit but you never know. The previous batch sold out completely already. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted May 23, 2018 Author Share Posted May 23, 2018 I will be planning to continue stocking these for the foreseeable future. So as long as there is demand, these will continue to be available. Quote Link to comment Share on other sites More sharing options...
