SoundGammon Posted April 3, 2018 Share Posted April 3, 2018 Recently got the Sears version of the Intellivision. Always wanted one because I love the look of it! Anyway, when I power it up, all I get is a black screen, no game video or sound. Using the rf output channel 3. Any ideas where to start? Quote Link to comment Share on other sites More sharing options...
Porte048 Posted April 3, 2018 Share Posted April 3, 2018 Did you try channel 4? Also, clean it up: Contacts, different games, compressed air, Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted April 3, 2018 Author Share Posted April 3, 2018 Did all that! Quote Link to comment Share on other sites More sharing options...
Porte048 Posted April 3, 2018 Share Posted April 3, 2018 If youve already tried stuff, tell us! What else have you tried Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted April 4, 2018 Author Share Posted April 4, 2018 I'm going to pop it open this week-end and check the power supply. I'm thinking the 5 volt supply is dead. I've seen a schematic awhile ago and do some checking! Also, I've got 2 standard units to check it against! 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 4, 2018 Share Posted April 4, 2018 (edited) You can find the service manual and test voltages here. https://console5.com/wiki/Intellivision Also test the ribbon cable for continuity; be carefull with the ribbon cable, it's delicate. The Sears Intellivision is no different than a model 2609. Remove the rf shield and give it a good visual inspection. Unless your TV gives a black screen with no signal, a black screen from Intellivision usually means the signal/channel is working but no cartridge program is running. So yes the first thing to check is the cartridge and cartridge port. Edited April 4, 2018 by mr_me Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted April 5, 2018 Author Share Posted April 5, 2018 Looking at the schematic, looks like the rf unit gets it power from 12 volts, and I know that is working! So my bet is the 5 volt supply isn't working. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted April 9, 2018 Share Posted April 9, 2018 (edited) Checking the power supply and 5 pin ribbon cable is always a good start. From my experience, the power board itself is usually good (there's just AC to DC bridge rectifier conversion, and 7805/7812 voltage regulators), it's the ribbon cable that disintegrates.Do you get a flash on the screen when you press reset?The Intellivision's cartridge connects directly to the main bus, so problems with the cartridge contacts eg dirt can cause black screen. A good clean with Deoxit is always a good idea.Also check the 2 transistors Q1 and Q2 on the main board, as these drive the clock lines on the CPU.Lastly, logic issues with the STIC, RA-3-9600 RAM or even the CPU can cause black screen. Carefully cleaning the legs and resocketing might help, otherwise replacement is the only option. At least you have a couple of other units, so you could swap ICs between them to troubleshoot (although this means cracking open the shielding on a working system).- J Edited April 9, 2018 by HunterZero Quote Link to comment Share on other sites More sharing options...
ArcadeJunkie Posted April 10, 2018 Share Posted April 10, 2018 Wouldnt hurt to replace the caps while you have it open. I have fixed plenty of 2609s and they required a cap change or replacement transformer more than anything else. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted April 12, 2018 Share Posted April 12, 2018 (edited) Wouldnt hurt to replace the caps while you have it open. I have fixed plenty of 2609s and they required a cap change or replacement transformer more than anything else. I have found that the SHOEI branded capacitors are actually good parts. That said, they are 35 year old electrolytics, so it is a good idea to replace them as preventative maintenance, and I did do this on my units. However all the old capacitors I pulled off the boards actually tested OK, and quality replacements for the larger power capacitor parts do cost several dollars (A$5.89 for the 2200uF 25V, and A$9.35 for the 10000uF 25V upgraded from 16V Nichicon branded from element14.com). I did fix one unit that had one of the 0.1uF non-polarised glass caps at C13 blown (it had catastrophically exploded), that was presenting with a black screen. YMMV... - James Edited April 12, 2018 by HunterZero Quote Link to comment Share on other sites More sharing options...
