Atari 1050 in kinda rough shape
37 replies to this topic
#26 NewKillerAmerica OFFLINE
NewKillerAmerica
    Space Invader
  • 41 posts
Posted Mon Apr 9, 2018 9:18 AM
Ok, got the shield off, and forgive my ignorance, but which chip should be replaced?
#27 Nezgar OFFLINE
Nezgar
  • 1,446 posts
Posted Mon Apr 9, 2018 10:43 AM
See attached pic for reference.
  • U10 is the OS ROM. (4 Kilobytes)
  • U9 is the 6507 CPU. (1 Mhz)
  • U8 is the 6810 static RAM (128 bytes)
Your picture shows your drive is jumpered JP1 and JP3, which configures the U10 socket for a Mask ROM or 2532 eprom (less common eprom type). If you move those 2 jumpers (soldering required) to be JP2 and JP4, you can use a (more-common) 2732 EPROM, programmed with either a stock 1050 OS (no benefit to you), or US Doubler code.
You don't NEED to do replace anything with it if you are fine with it as a stock drive, but with normal slow speed, and only Single Density, and 'Enhanced' Density, no Double Density support.
Most common upgrade options:
  • US Doubler: Replaces U10 ROM chip - most common these days is a homebrew programmed EPROM, and U8 replaced with 2 6810 RAM chip's stacked for 256byte double density sector buffer
  • Happy 1050 or Speedy 1050: Remove U10 ROM, and U9 CPU, and insert daughterboad into U9 socket.
Edited by Nezgar, Mon Apr 9, 2018 11:18 AM.
#28 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Mon Apr 9, 2018 11:11 AM
Looks reasonably clean in there :)
Happy and Mini-Speedy do not require any soldering - they come with extra features besides the double density but can have compatibility issues with original disks. Im told the US Doubler has no compatibility issues. It requires a little soldering but it is also the least costly to do.
For a USD upgrade you will have to replace the ROM with a custom 2732 EPROM, remove JP1 and JP3 and solder them into JP2 and JP4 and add a second 6810 chip on top of the existing one - with a couple of tweaks (there are numerous guides on here showing which pins)
My USD is shown below
#29 NewKillerAmerica OFFLINE
NewKillerAmerica
    Space Invader
  • 41 posts
Posted Mon Apr 9, 2018 12:28 PM
Very cool! Ok Ill kick this around a bit. Nezgar, did get some 3 in 1 today to lube the rails. Thanks everyone for the convo so far.
#30 NewKillerAmerica OFFLINE
NewKillerAmerica
    Space Invader
  • 41 posts
Posted Tue Apr 10, 2018 11:10 AM
Well after much debate with the squad around here, I decided to keep the drive stock for now. Blew it out, cleaned and lubricated the rails and cleaned the head. I fixed the little cracked areas by popping them back in place, and got the switch in the right orientation for the faceplate. Then, after a little scrubbing and shining, got it reassembled and back where it belongs. I included the 3M product pic b/c I find it really useful and non-abrasive on these aging plastics, using a soft Scotch-Brite pad. Overall Im satisfied with the result and have a PSU on its way. Thank you guys so much for your comments on this topic! Once the PSU arrives Ill update.
(Loaded the disk image you see using RespeQt) 😁
Edited by NewKillerAmerica, Tue Apr 10, 2018 11:11 AM.
#31 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
Posted Tue Apr 17, 2018 10:14 AM
nicely done - looks quite mint too :)
#32 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,253 posts
Posted Tue Apr 17, 2018 11:52 AM
Just a little note re the Speedy and Happy, Xbrevin said there are compatibility issues with them with original disks, with the Happy in its default operational it will have some problems with protected games because the drive is faster in its normal state so breaks some protection, however you can make the drive 'Un-Happy' with software so it returns to behaving like a standard 1050 and when you want the happy back you just turn it off and then on again.
Can't say for the Speedy but I imagine there's a similar situation.
Just wanted to clarify that a Happy upgrade is well worth it and once sett to un happy mode its perfectly ok with protected software..
Paul..
Edited by Mclaneinc, Tue Apr 17, 2018 11:54 AM.
#33 Nezgar OFFLINE
Nezgar
  • 1,446 posts
Posted Tue Apr 17, 2018 12:20 PM
Yep, this is as simple as just tapping '1 - 1' when booting the Happy disk. Disables the Happy's track buffer. Very close in operation to a stock 1050.
However, you have some additional options creative people have come up with using additional RAM in the happy.
  • the HAPPY.COM utility included in Steven Carden's RealDOS ( http://realdos.net/realdos.html) will upload a relocated US Doubler OS to the drive, and it will function as a native US Doubler until power-off. You can also set the drive to anything 1-8 prior to the code upload. This is how you can use a happy to format disks with an Ultraspeed skew for ultraspeed on US Doubler which has no track buffer
  • https://archive.org/...Pirate_Software- This disk has options to upload either a Chip/Archiver OS to the Happy 1050, or a Stock 1050 OS.
So concurring with Paul, these additional tools make the happy a pretty darned flexible (at least 4-in-1) upgrade!
Playing with my Mini-Speedy I've found there was some very good design around this concern. If you put in a disk, and the drive detects non a standard track layout (ie more/less than 18 sectors) it will automatically disable the track buffer as well as reduce the stepper speed back to that of a stock 1050.
On the Speedy utility disk, there is a function to programmatically disable the track buffer, but they took it one step further by also including a simple menu option to upload stock 1050 OS code to the drives RAM, and it will then function as a Stock drive until it is power cycled.
The Speedy ROM OS was updated by hias for NTSC compatibility since only early 2017, so it's a whole new upgrade for us north american users to discover!
Edited by Nezgar, Tue Apr 17, 2018 12:43 PM.
#34 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 741 posts
Posted Wed Apr 18, 2018 4:58 AM
Speedy supports the same features like the Happy 1050:
- Disable the trackbuffer (as you mentioned)
- Loading the genuine 1050 firmware into Speedy RAM
Disabling the track buffer is only enough for very old protected disks. The newer (meaning from sight of the 80s) copy protection schemes based on FDC errors, 1050 firmware flaws and some things more, so just a disabled track buffer won´t help
Using the Speedy Ulitity disk you can load the genuine 1050 firmware into the Speedy´s RAM and it will be executed - no difference to a stock 1050 anymore until next power-cycle. The same thing can be done with a Happy 1050 (or clone) using the "CSS Unhappy Maker 1050".
Jurgen
#35 Nezgar OFFLINE
Nezgar
  • 1,446 posts
Posted Wed Apr 18, 2018 8:32 AM
Is the "CSS Unhappy Maker 1050" downloadable anywhere? I have not seen this yet myself.
#36 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 741 posts
Posted Wed Apr 18, 2018 11:27 AM
Here it is. It´s a executable binary (.COM or .XEX). It just programs drive #1.
#37 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
  • What is your Alternate Reality?
Posted Wed Apr 18, 2018 4:41 PM
Looks like someone added a lot of unnecessary 'crap' around that tool.  Can't even remember the last time I started up MAC/65 but used this as an excuse to make my own version.  No magic here.  Just plain LDA/STA code.
File size decreased from $6279 to $4208 bytes ($4599 unpacked)
Single segment file
Loads at $3E16
Exit to DOS or Reboot after the upload
It also results in what is probably the most exciting screenshot ever:
Attaching a 7-Zip file doesn't seem to work so it's here:
http://atari.fox-1.n...-tools/unhappy/
edit: typo
Edited by Fox-1 / mnx, Wed Apr 18, 2018 4:44 PM.
#38 NewKillerAmerica OFFLINE
NewKillerAmerica
    Space Invader
  • 41 posts
Posted Fri Aug 10, 2018 8:27 AM
Single segment file
Loads at $3E16
edit: typo
Nice site there.
